Question about Gigabyte GA-8SIML Motherboard
GOT THE INSIDES OF AN AMD ASUS BOARD AND A TOWER DESIGNED TO RUN GIGABYTE INTEL BOARD NEED HELP CAN I SPLIT THE FRONT PANEL WIRES AS AM UN SURE
    Problem Solver:
  • 16 Answers
Okay, first of all no tower is designed for a specific mobo,so I imagine that the front panel connections are keyed one way and the mobo jumpers aren't the same.You can do 1 of two things you spend hours trying different connections and if your luckey get the thing to start.You could also go to the perspective websites and get the jumper layouts and match them that way.re-keying is never fun.My suggestion is to get a custom box w/ each and every wire is labled for the jumpers.I bought one last week for my g.f. for 16 bucks.GET A NEW CASE
Posted on Feb 03, 2009
Installed mother to new tower case and pwr sw | hd led | reset | power led connecting to my board is the Intel dq67sw 155 matx motherboard need accurate dir to connect these please help
info found at http://downloadmirror.intel.com/19707/eng/DQ67SW_ProductGuide01_English.pdf
Front Panel Header Pin info for DQ67SW. They should be color coded too. 1 Hard disk LED + orange
2 Power LED+ green
3 Hard disk LED - orange
4 Power LED- green 5 Reset Switch - blue
6 Power switch + red
7 Reset switch + blue 8 Power switch - red
9 Power Out (do not use)
10 No pin
NOTE When connecting individual wires from your chassis front panel to the front panel header, be sure to observe the connection polarity. Positive wires are usually solid color and negative wires are usually white or striped.
There is also an alternative pin header if you have a power wire that uses a 3 pin connector instead of a 2 pin connector. It is the 3 pins just past pin 9, and it should be missing the pin in the middle of the 3 pin block. The pin closest to pin 9 is the power led + and the furthest from pin 9 is the power led -.
if you need clarification, check out page 50 of the manual posted above at intel.com
Aug 23, 2011 | Computers & Internet
What processor speed can fit my motherboard GA-75748?
Motherboards designed for AMD processors have radical differences in design from those designed for Intel processors. The most obvious of those differences is the socket which accommodates the processor, which is totally different in both case.
This means that you cannot use an Intel processor on a motherboard designed for an AMD processor, & vice versa. You have to replace the motherboard with one designed for the Intel processor you plan to use.
Jul 12, 2009 | Gigabyte Computers & Internet
Is It required to connect Tower Front Panel I/O to Motherboard
The only front panel pins you need are for the power switch. Track them from the front panel to the connector and plug them upto the 2 pins for power. Dont worry about polarity it can go either way. The connector may look a little odd but it will work just fine. In the past in that situation I have cut the plastic in such a way I have separated the different connections but its not worth the trouble in my opinion.
May 06, 2009 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Mother board - amd to be repaired
If it was under 3 years
then AMD- Asus / Gigabyte /MSI motherboards comes under warranty of three years.
Whats the brand of the Motherboard Asus / Gigabyte?
(when u switch on the PC on right side of the Screen u can read the name of the Manufacturer)
Asus Service Centre is at lamington Road, Mumbai
Gigabyte Service Centre at Kalina, Mumbai
You can approach Service center for the particular Vendor and get the board repaired. (As it is out of warranty, otherwise you cud have got the replacement)
However, they will take approximately 8 days time. :(
Dec 29, 2008 | Computers & Internet
E2180 Vs Athlon 64 X2 5000+
depends on what you plan to do with the cpu amd are good but a 3200 may only run @ 1.8 to 3.2 ghz depending while a intel 3200 will run 3.2 ghz.
I believe intel are more stable & run cooler than AMD but AMD benchmarks on Games better but run hotter (so get a good cooling fan & heatsink both pentium / celeron d & intel dou / dual core / core 2 dou and amd x2 have 2 cores (but watch your front side bus and cache the higher the better but the more $ also) then You need a good stable mobo that supports the chip you get (I preffer asus & msi for Gamers and biostar / msi for home users)
Sep 18, 2008 | AMD Athlon 64 X2 4600+, 2.4 GHz...
Wiring off tower into motherboard for gateway intel 850 motherboard scoket 478 mod. # 4000782
thanks for the help. but it ended being a inteldesktop board model D850EMV2. I now have all the paper on it from Intel, agin I say thanks for the help
Jul 21, 2008 | ASUS A7S333 Motherboard
Pluging in extra usb ports/Mic and headphone jacks from the tower
Answer me this. You're case is an Antec tower? The motherboard is the Asus P4P800 SE ? Is this correct?
If you have you're manual you can see what goes where on the board for front panel connector page. 2-31. (This diagram shows you how to connect the front mic & speaker).
To connect the Antec's front USB ports plug the case USB front connectors onto USB56 & USB78 shown on page. 2-30. Most case wires are already set within their USB connectors & the Antec's front USB connector should fit right on the mother board's pin's. If you need you're user manual, download from Asus by clicking on this link. http://support.asus.com/download/download.aspx?modelname=P4P800%20SE&SLanguage=en-us
Good Luck!
Mike
May 19, 2008 | ASUS P4P800SE Motherboard
Gigabyte GA-8SIML Motherboard Logo
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
