Faulty motherboard? Hi, my PC has an ansus p5vd2-mx motherboard, intel duo core processor, pci express slot, gforce graphic card. I upgraded the graphics card for faster secondhand one which resulted in loss of video signal and 1 long and 2 short beebs from the BIOS ( faulty graphic card? ) Replaced the original graphic card but still getting the same error beebs and no video signal. The fan on the graphic card is still working so it must be drawing power from the pci express slot. My question is if I have goosed the psi express slot can it be repaired or will I need to replace the motherboard ? Any advice very welcome
    Problem Solver:
  • 16 Answers
Bullnosestep
It is possible that the new (secondhand graphics card) was faulty and sent an incorrect voltage to part of your motherboard (frying it). However in my experiance it is not likely, I have installed and un-installed 100's of video cards over the last 10 years many of them faulty and only on one ocassion did it ever damage the board.
Things to try:
Double check (triple check) that your card is seated properly in the pci-e slot, this is one of the most overlooked things and is one of the most common problems when installing a new video cards. It may be drawing power from the slot but could still be slightly out of line.
Also most new ish psi-e card require an additional power supply direct from the PSU, did you connect this up if needed. (don't know what make the graphics card is so just in case)
Remove the cards and check the slot for dust and dirt, quite often when you remove an old existing card you can dislodge dust/durt from around the slot pushing it into it, thus making a bad connection to the video card. Blow the slot clean with a compressed air cleaner, can should cost £5-£10, don't use vacuum on the motherboard as this can cause extreme levels of static.
Are you sure you didn't knock a component on the motherboard during installation?
If you have tried all these things then you may have a damaged board. You could take it to a repair outlet to check the board over. They would be able to check the voltages etc... and may be able to locate the trouble.
The Pci-e slots can be replaced and re-soldered but it is a very skilled operation, to be fair you would be much better off buying another board. Lets face it, the slot is probably ok, you may have blown something elsewhere on the board.
Hope this helps and let me know if you solve the problem
Bri
Posted on Feb 04, 2009
What cpu will my mb support
http://www.fixya.com/support/t17051839-gateway_e210882_motherboard_specs
'Always learning'
What a commendable trait to have Mr.Valle. I respect that.
[When you are a member, just click on anyone's user name to view their account. I have been here over 3 years, and am an ex-expert moderator, is how I know ]
This solution is going to be rather long, I hope you can put up with me.
1) Was not aware that Gateway has an e210882 mobo.
(MOtherBOard)
Thought that was an Intel motherboard made especially for Dell.
Things we learn,
http://www.ebay.com/itm/Gateway-eMachines-T5086-LGA775-Intel-Desktop-Motherboard-I-O-E210882-PERFECT-/300874674719?pt=Motherboards&hash=item460d87321f
Also lists it for the eMachines T5086 desktop computer, too.
My intel states the eMachines T5086 uses an Intel D945GCL motherboard.
Hmmm,....................
In the link above scroll the page down to the Specifications.
Two things to note here;
A) Processor socket
B) Motherboard chipset
The processor (CPU) socket is an Intel LGA 775 socket.
Also known as the Socket T,
http://en.wikipedia.org/wiki/Socket_T
The motherboard chipset is just listed as - Chipset.
The motherboard chipset is an Intel 915G,
Here we see the Intel 915G chipset ONLY supports Single-Core
Intel processors.
Intel Pentium 4, and Intel Celeron D.
The Intel Celeron D is NOT a dual core processor, as the D suffix may seem to imply,
http://en.wikipedia.org/wiki/Celeron_D#Celeron_D
"The Intel Celeron D processor works with the Intel 845 and 865 chipset families.
The D suffix actually has no official designation, and does not indicate that these models are dual-core.
It is used simply to distinguish this line of Celeron from the previous, lower performing Northwood and Willamette series, and also from the mobile series, the Celeron M (which also uses 3xx model numbers)
Unlike the Pentium D, the Celeron D is NOT a dual core processor."
Supports Intel Pentium 4, and Intel Celeron D processors; that have either a 533MegaHertz Front Side Bus; or an 800MHz FSB.
And use the LGA 775 processor socket,
A) http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Prescott_.2890.C2.A0nm.29_2
B) http://en.wikipedia.org/wiki/List_of_Intel_Celeron_microprocessors#Celeron_D_.28single-core.29
[Note* MT/s is MegaTransfers per Second.
Thought to be a more accurate method of measuring, than using the MegaHertz method. MHz.
[ Incidentally;
Mega = approximately 1 Million.
Giga = approximately 1 Billion.
Hertz stands for Cycles per Second.
Named after a man with the last name of Hertz.
A Processor (CPU), that is stated to operate at 2.4GHz, is the same thing as stating it will operate at 2400MHz.
2400 Million Cycles per Second.
Has a frequency rate ('Speed') of 2400 Million Cycles per Second ]
That is for CPU support.
As for graphics card support, let's go back to the Ebay link, and click on a photo.........
Immediately above the specifications are photos. One large main photo, and 5 smaller views.
I invite you to click on the Top small view, and the one to the Right.
Picture 2 of 5.
Here you see the two White - PCI expansion slots.
Motherboard mounted in the computer case, the long Black expansion slot above them; is a PCI Express x16 slot.
Below them is a Black - PCI Express x1 slot.
The expansion slot you want to use for a graphics card, is the PCI Express x16 slot.
When the PCI Express technology first came out, it wasn't even named PCI Express yet.
Upgrade versions through the years are;
PCI Express 1.0a
PCI Express 1.1
PCI Express 2.0
PCI Express 2.1
,and presently it is PCI Express 3.0
How to know which PCI Express technology, is used for your motherboard?
Simple. Look at the motherboard chipset.
Looking back at the Intel 915G chipset again,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4.2FPentium_D.2FPentium_EE_chipsets
Here we see it was brought out in June of 2004.
The PCI Express 1.1 technology did not come out, until 2005,
http://en.wikipedia.org/wiki/PCI_Express#PCI_Express_1.1
This means to me, your motherboard utilizes the PCI Express 1.0a technology.
Since it was on the cusp of development, I'll bet it is actually based on the PCI Express 1.1 technology, though.
PCI Express 2.0 and PCI-Express 2.1; are Backward Compatible, with PCI Express 1.1
Stated another way;
A motherboard utilizing the PCI Express 1.1 technology, will support a graphics card based on the PCI Express 2.0 technology, or PCI Express 2.1 technology.
"PCIe 2.0 motherboard slots are fully backward compatible with PCIe v1.x cards.
PCIe 2.0 cards are also generally backward compatible with PCIe 1.x motherboards, using the available bandwidth of PCI Express 1.1.
Overall, graphic cards or motherboards designed for v2.0 will work with the other being v1.1 or v1.0a."
[ v = Version ]
You will not get the full capability of the PCI Express 2.0 graphics card, or PCI Express 2.1 graphics card.
Will you notice? Doubt it unless you plan on running the newer intensive games. Your processor won't support them anyhow.
[ A graphics card has it's own Processor, and ram memory.
The Graphics Processing Unit {GPU}, and graphics memory.
Doesn't need to borrow from the system resources; the Processor and Ram Memory on the motherboard. (System resources)
However, the graphics information still needs to pass through the Processor. This can be a 'bottleneck', if the processor can't keep up.
Also;
I just stopped using a Gateway 7200X, whose motherboard has an Intel 915G motherboard chipset.
I was using an ATI Radeon HD5450 graphics card on it.
The ATI Radeon HD5450 is based on the PCI Express 2.1 technology.
Not really a graphics card to 'write home to Mom about'.
I am using two monitors at once though, and it supports my Adobe Photoshop 7 really well.
( HP 2009m - 20 inch widescreen LCD monitor, and an
RCA L26HD31, HDTV as a second monitor. A 26 inch HDTV ]
So you know that your motherboard will support a PCI Express graphics card, based on either the PCI-E 2.0 technology, or PCI-E 2.1 technology.
(The PCI Express slot has a Lock on one end. It looks as though you GENTLY press down, to install a graphics card.
This = No.
You Gently lift UP on the Lock a little )
The next thing you need to be concerned with, is what the Power Requirement for the graphics card is.
This should be stated in the System Requirement section, of the information about the specifications of the graphics card.
Be aware however, that the Wattage stated is for a COMPLETE computer system, and not the graphics card alone.
For example;
States 400 Watts.
Means power needed for a gamer type motherboard, the CPU, Ram Memory, optical drive/s, and fans.
The graphics card manufacturer builds a computer test system, based on the best hardware components.
This way they will know the power requirement they have stated, will work.
Still don't know of any graphics card's out there, that use more than 150 Watts by themselves. However I may be 'out of touch'.
Your motherboard probably needs 85 Watts.
Each ram memory module uses about 15 watts.
CD/DVD drive about 25 watts.
EACH fan uses 2 to 3 Watts.
If ALL of the LED lights were on at once, they would use less than 1 Watt, and are not worth worrying about when determining wattage usage.
You'll have to look your CPU up by it's spec's, and see what the Maximum Wattage used is.
This is under the heading -> TDP
Thermal Design Point.
For additional questions please post in a Comment.
If you need me to clarify any of the statements above, post back in a Comment.
Regards,
joecoolvette
Mar 12, 2013 | Computers & Internet
Does INTEL D915GLVG Motherboard supports Graphics/Video Card? OR Can I add Graphics/Video Card to INTEL D915GLVG Motherboard? - Kindly suggest me.
gaming is limited by the os that you have
gaming is limited by the speed of the cpu ( intel chip)you may even be limited by the graphic card that you can use in the mother board slot
when faced with all of these decisions and obvious lack of knowledge of what works best, find your self a computer repair shop and talk about upgrading to what you want
you say that cost is no object but to get what you want it will be a new mother board and fast chip ( probably a duel core or quad core) and a suitable graphic card for gaming
you can build a computer up from parts off the shelf and the cost will be around 1/2 the price of a computer from a retail shop and you will get exactly what you want
Mar 04, 2017 | Intel Computers & Internet
Dg41 is the best
Please get DG41/CN/TX motherboards it the best. this is due to fact that it carries a better graphic resolution card, lates technology DDR3 SD RAM ram, etc.
Intel DG41CN Motherboard
  • Form Factor: Micro ATX
  • Compatibility: PC
  • Chipset: Intel G41 Express
  • Compatible Processors: Intel Celeron, Intel Pentium, Intel Core2 Duo, Intel Core2 Quad
  • Video Interface: PCI Express x16
  • Storage Controller Type(s): Serial ATA II x 4
  • Intel DG41TX Motherboard
    • Compatibility: PC
    • Compatible Processors: Intel Celeron, Intel Pentium, Intel Xeon, Intel Core2 Duo, Intel Core2 Quad
    • Front Side Bus Speed: 1333 MHz
    Regards,
    Pourmoi
    Dec 23, 2010 | Intel DG31PR Motherboard
    I want to know that did intel d945gcr supports core 2 duo processor...............plz
    This mother board will work if we have a compatible processor like Intel Core2 Duo, Intel Pentium D, Intel Pentium 4.But the processor should be greater than 2.99Ghz if the processor is less than this then it will to work.Dual core processor means there will be two processors working
    The detailed specifications of the new Intel D945GCCR Motherboard are:
    • Form Factor:MicroATX
    • Processor:Intel Core 2 Duo, Intel Pentium D, Intel Pentium 4 and Celeron D processors in the LGA775 package
    • Supported System Bus:800 MHz / 533MHz
    • Chipset:Intel 945GC Express Chipset with ICH
    • Supports Hyper-Threading Technology
    • Graphics:Intel Graphics Media Accelerator 950
    • Graphics Connector:One PCI Express* x16 graphics connector
    • Memory Support:Dual-channel DDR2 533 / 400 MHz, 2 DIMM slots (2GB Max)
    • Expansion Slots:Two PCI connectors
    • One PCI Express* x1 connector
    • Audio:Intel High Definition Audio with 5.1 Surround Sound
    • USB Ports:Eight Hi-Speed USB 2.0 ports (4 back / 4 front)
    • Storage One IDE (ATA 100/66/33)
    • Four Serial ATA ports (3.0 Gb/s)
    • On-Board LAN:Intel PRO 10/100 Network connection
    • Warranty:3 year limited warranty
    Hope that solve your problem!
    Thanks for using Fixya!
    Dec 15, 2010 | Intel D945GCCR Motherboard
    Which graphics card for motherboard
    Hi!
    Well, you need to get more memory if you want to play newest games, if you upgrade the memory to 4GB and buy a good GPU you will be fine for a year ot two:)
    Good luck M8
    Nic
    Mar 27, 2009 | ASUS P5VD2-MX Motherboard
    Graphics card for motherboard
    Hi there.
    That motherboard will support a Gforce 8400 PCI Express card and above, and of course you will be able to play the latest games on providing you upgrade your system memory too.
    Here is a link to tech specs on the Gforce 8400 >>>>>>>>>
    http://www.nvidia.com/object/geforce_8400_tech_specs.html
    Youcan get this card or one thats higher specs if you like but the Gforce8400 is a very good card and i think you will like it.
    Have fun and thanks for using FixYa!!
    Mar 23, 2009 | ASUS P5VD2-MX Motherboard
    I have a P5VD2-MX motherboard, currently I have a Geforce 7900GS.
    Hi!
    Since there is 1 PCI Express x16 slot you can use any PCI Express GPU, like Asus GeForce GTX 260 896MB PhysX CUDA, EVGA GeForce 9800GT 512MB PhysX CUDA, Gainward GeForce 9800GT 512MB PhysX CUDA or whatever you want as long as it is a PCI EPRESS card.
    Good luck
    Nic
    Mar 22, 2009 | ASUS P5VD2-MX SE Motherboard
    I want better gaming quality for my p5vd2 mx motherboard
    You can get "any" type of PCI-X graphic card to your system, it doesnt matter if the memories on the graphic card are ddr2 ddr3 ddr4 or ddr5. It should work. If you have a C2D processor @ 1.8GHz you probably have Intel E6300. You can pair it with any graphic card. Its only up to your budget.
    For any more questions, contact me anytime
    Nov 15, 2008 | ASUS P5VD2-MX Motherboard
    Computers & Internet Logo
    270 people viewed this question
    David Payne
    David Payne
