Question about Sharp AR 201 Copier
Photocopier Sharp ar201 not working
My photocopier Sharp ar201 is showing L than 6 when i switch on the power, moreover i don't have the operating manual to get an idea.I am unable to find a solution because i am in a remote place having internet and telephone facility.I tried to find the troubleshooting manual from the net, so i here and find you.kindly give the detail troubleshooting process for this problem,also the aprro.amount if any components or part of the machine has to be replace thanking you in anticipation uday kr.rai email : uday.rai2007@rediffmail.com
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 58 Answers
L6 - Polygon Motor Lock: The lock signal (the specified rotation speed signal) is not supplies within the specified time (about 6 seconds) after starting the polygon motor rotation. LSU connector disconnection of harness disconnection in the LSU. Replace LSU.
Posted on Aug 01, 2007
How do i reset a sharp al-1553 photocopy
Try unplugging it for 20 minutes. If that doesn't work, go online type "sharp al1553 user manual" and it will show sites to get manual. Use the trouble shooting section.
Apr 28, 2016 | Sharp Office Equipment & Supplies
Sharp Photocopy AR 5618 showing L4 when on before it start photocopy
This is what the manual says when you het a message:
25385794-klcizou1qcaa2a3cc2pjju3n-5-0.png To read other interesting things in the manual is possible, because the manual is online (PDF) on this link:
http://www.sharp-cee.com/cps/rde/xbcr/documents/documents/om/34_ppc/AR5618-D-5620-D-5623-D_OM_GB.pdf
Jan 27, 2015 | Sharp Office Equipment & Supplies
I bought new toner since then my ar-5618 sharp photocopier is showing F2 and when i press start is showing 74. please what do i do to clear it?
The problem is with the toner....there is two way solution change toner or more economic way change the chip of your existing toner....the sharp copier tend to burn the toner chip.
Oct 31, 2014 | Office Equipment & Supplies
Sharp ar 5516 maintenance reset
sharp ar 5516 showing ( - - - ) what's the solution
Sep 02, 2012 | Sharp AR-5316 Advanced Digital Imager...
Sharp AL1644 machine does not operate as a photocopier
Do you have any status lights on? If not then you may just have a print button that needs repaired. I have seen this a few times on this series. Try pressing down firmly on the print button while wigging the button around in a circular fashion. If you work a it and all of a sudden the machine makes a copy then the solder connectioons for the print switch have worked loose and will need to be re-soldered. Pretty simple repair. You may have someone locally that can do it. The operation panel comes off pretty easy and the circuit board with the switch is right under this panel. It is a small "button" type switch with small solder contacts that break loose. 10 minute job if you know what you are doing. 20 minutes if you dont. Just need someone with a solder iron and a little skill.
Good Luck and Thank You for using Fixya.
May 06, 2010 | Sharp AL 1631 Copier
Error code U2 on a AR201 copier
Hello sir; This error code it can be reset folloe the instruction;
1, press "clear", "interupt", " 0 ", "interupt"
2, enter 16 then press start.
Jun 01, 2009 | Sharp AR 201 Copier
Sharp AR 5316 E photocopier error clearing
Try reset by pressing [#] [interupt] [C] [interupt] [1] [6] [start]
May 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error Code F1 on Copier Sharp AR201
F1 means "shifter Motor Trouble". The motor that driver the shifting mechanism at the paper exit side is not functioning. The motor could be bad or there may be something binding the motor up. Take a real close look at the exit unit (where the paper comes out of the machine) and see if there is anything in the way of the shifter. It could also be a bad board issue - sending the wrong signal to the motor... or possibly a bad home position sensor for the shifter.
You could try taking the shifter unit out for a closer inspection - make sure its properly installed.
Hope this helps.
Apr 13, 2009 | Sharp AR 201 Copier
Sharp AR 201 Copier Logo
144 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
George Mclaughlin
Ed
Ed
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
