Question about Samsung RS2630WW Side by Side Refrigerator
Fridge and Freezer do not keep foods cool
We purchased our RS2630WW on Dec. 31 and for the last three weeks the temperature has been inconsistent. They are too high and the foods in the freezer melt and the fridge does not keep the foods at cool enough temperature. We have had the Samsung contracted repair man to the house and he replaced the censors on our fridge. This did not solve the problem. The freezer worked for a day and now is back to its old tricks. Does anyone have any recommendations? Has anyone been able to get their money back or at least a different fridge? Any help is appreciated. Azusa
Samsung rs2630ww i have had endless problems i have had it replaced 4 times. red hot center and side panels i have had 2 condensers burn. the problem is that it is simply badly designed!
there is not enough air flow . so if it has any restriction it kills the unit. a Samsung tech told me off the record these units are all problematic! of course he love it at 200 an hour.
Posted on Aug 15, 2009
    Problem Solver:
  • 6 Answers
Im working with Samsung right now trying to get my money back, they have treated me like crap for the past 16 months about my rs2630sh, sent tech out 8 times still has the same problem. I think this model is a lemon and they sould recall them.
Posted on Sep 17, 2007
SOURCE:
Why is the refrigerator side is freezing food
First some fridge 101, the refrigerator/freezer models cool by directly refrigerating the freezer section and the refrigerator section is cooled when "some" of the cold air from the freezer is directed over to the refrigerator side (typically by a fan) to keep food fresh and not frozen a temperature controlling damper opens and closes to regulate the temperature of the fridge by introducing more or below freezing air into the cabinet. In older models where the freezer was on top the air simply "gravity" drained into the refrigerator cabinet, if the food was too cold you turned the fridge knob up and less air sank from the freezer to the fridge, simple but effective.
When you adjust the temperature level it controls the freezer temperature and this turns the compressor on and off to keep the food frozen. There is typically a knob or lever and some even have electric dampers that open and close to direct more or less air from the freezer and direct it to the refrigerator cabinet based on your temperature requirements.
Now that you know how it works there are a couple things to check. If the condenser coil is plugged with dust the internal system pressure will rise and in some cases make the fridge an over achiever and can chill too much so check/clean the condenser coil. Check the freezer temperature control and turn in up, also make sure the fridge temperature control setting is not set too cold.
Finally as the temperature changes around the refrigerator it will have an effect on the inside of the fridge too so expect to turn it up and down as the environment changes, down in the summer and up in the winter.
Hope the novel helps to resolve your issues.
Nov 01, 2017 | Refrigerators
Frigde temperature high.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 06, 2011 | Samsung RS2630WW Side by Side Refrigerator
I cleaned out my fridge completely today. Took all the shelves out, cleaned the interior, all the glass over a three hour period. The freezer is working just fine, the fresh food area is nice and dry but...
Manufacturers suggest that it takes approximately 24 hours for the temperature to stabilize in both your freezer and fresh food compartments after being turned off for an extended period of time. Adjust temperature settings to the "half-way" mark for both freezer and fresh food compartments. Allow a period overnight and recheck the temperatures. Also check the condenser coil (usually located underneath the appliance). If clogged with dirt/lint, it needs to be cleaned (carefully) with a condenser coil brush (can be purchased at Home Depot or Lowe's). Prior to cleaning condenser coil, turn off appliance (there is a condenser fan motor and blade operating while on). Be careful not to damage copper tubing (refrigerant in tubing)!
Feb 16, 2010 | Refrigerators
The temperature alarm is beeping and the fridge and freezer continue to get warmer.
Hi i have a jenn-air side by side ice & water dispenser and the ice & water bottons keep beeping and flashing, what does this mean
Jan 26, 2010 | Jenn-Air JCD2389G Side by Side...
My 9 yr old Kenmore Elite fridge is warming up!! The freezer is fine!!!! Model 3 106*74902401 Seriel # ES423704 Manufacture date is 10/2005, I purchased it in Dec of '05 and it's been WONDERFUL!!
This problem sounds like a damper control broken or frozen.
Lowering the freezer temperature may help to fix the problem as the damper sometimes freezes and not able to open to cool down the fridge side.
If lowering the freezer temperature doesn't help, you may need to call for a technician to fix or replace the damper control.
Also, be sure the door closes properly and no air comes in or out from the fridge.
Dec 18, 2009 | Computers & Internet
Our refrigerator is not cooling at all. The freezer is working fine, but no cool air is getting to the refrigerator section. A couple of weeks ago, this problem happened after the freezer had started...
Some fridges only cool the freezer and an evaporator fan motor moves cool air from the freezer to the fridge side. If this fan doesn't spin very freely then it may need to be replaced. You should also pull out the fridge and see where the drain hose is connected to the inside of the fridge, try pouring hot water down the hose to see if it is open. It may be clogged with a pea or some food or frozen. If your fridge is really full, make sure there is nothing in front of where the evaporator fan blows air into the fridge. Make sure that the adjuster flap is open in the fridge section.
Oct 31, 2009 | Refrigerators
Blinking temperature control
You need to check the limit thermostat for the defrost in the back of the refrig section. I replace it with a standard bi-metal type from a Frigidaire to keep the problem from reoccuring.
May 16, 2008 | Refrigerators
Samsung RS2630WW Side by Side Refrigerator Logo
667 people viewed this question
Top Samsung Refrigerators Experts
Paul
Gerry Harvey
Gerry Harvey
jasbo
jasbo
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
