Hp ze4800 when i turn on my computer this device keeps popping up all the time and i cant get rid of it. its trying to tell me that i need to install my printer. but how do i do it. i no longer have the cd or manual for this printer.
If you don't use your printer, just unplug it from your usb port.
Posted on Feb 02, 2009
HP PSC 1315 - TROUBLE WITH VERSION 4.2.0 INSTALLATION
Hi -- Hope this helps, it worked for me. Firstly, I strongly suggest you click http://www.revouninstaller.com/download-free-portable.php and save the file, then run the app. The built-in software uninstaller in Windows often leaves garbage behind in folders, files, and the registry that can make future installations fail. REVO is really good at getting rid of ALL of the crap so a clean re-install is possible. The above link is for their totally free portable version -- no crap and you don\'t have to install anything to use it. That said, uninstall all the software, then open your device manager and locate the entry for your device, right-click and select uninstall. DO check the box that says "delete the driver software for this device" so that you will be starting clean. After uninstalling, unplug the USB cable to your device and reboot.
After the reboot, Do NOT plug in the USB cable yet -- First, insert the driver CD and start the setup program. Wait until the software tells you, then plug in the USB cable and continue following the on-screen directions. Once everything installs, it may tell you to reboot, if so, don\'t try using the device until you do. After the reboot (or after the install finishes if it doesn\'t make you reboot) you should be good to go again.
I have had this problem repeatedly when trying to re-install drivers for various HP Products, and this has (so far, anyway) worked for me in XP, Windows 7 and Windows 8.
Good Luck!
Jun 07, 2013 | HP PSC 1315 All-In-One InkJet Printer
How do I get rid of the HP Product Assistant window that keeps popping up and trying to install on my pc?
when the pop up window appears again..
go to the settings tab..
and choose the option" do not show pop up blocks"
Oct 02, 2010 | HP Photosmart C6180 All-In-One InkJet...
Wireless connectiion keep on switching to a not
You need to check first if the wireless switch is turn on.If it is on, check the function key for the wireless. Some computers have function key. Sometimes it is combination of fn and f5. Press those keys at the same time and you should see a pop up window and check if the current status is on. If it is on, uninstall/reinstall the wireless driver in device manager. and restart your computer. If this didn't work. You need to do re installation of your operating system.
Jul 07, 2010 | HP Pavilion dv6000z Notebook
Fatalerror message keeps popping up that printer hasnt loaded aaa
Completely uninstall the software then reboot and reinstall. This message is usually the result of a failed or incomplete install, and while it won't affect the drivers, it WILL affect the additional software bundled with the printer. Remember to reboot.
Mar 07, 2010 | Computers & Internet
HP 4200 keeps reinstalling
Dont get rid of it. You have a small problem with a lengthy fix but it can all be done if you follow these instructions.
Remove and reinstall all USB controllers loadTOCNode(2, 'moreinformation'); To remove and reinstall all USB controllers, follow these steps:
  1. Click Start, click Run, type sysdm.cpl in the Open box, and then click OK.
  2. Click the Hardware tab.
  3. Click the Device Manager button.
  4. Expand Universal Serial Bus controllers.
  5. Right-click every device under the Universal Serial Bus controllers node, and then click Uninstall to remove them one at a time.
  6. Restart the computer, and then reinstall the USB controllers.
  7. Plug in the removable USB storage device, and then test to make sure that the issue is resolved.
This should do the trick
Feb 18, 2010 | HP Officejet 4215 All-in-One Color Photo...
HP product assistant
I had a similar problem on my desktop Pavilion. This program is just sitting in memory and checking for updates. If your are not worried about getting updates then you can turn it off.
In the RUN box type MSCONFIG and the screen below will appear. Go to the Startup tab and un-check the box for "HPWuSchd2". Click OK to exit. You will need to reboot for this to take effect. (You can always turn it back on if any problems arise).
Mar 18, 2009 | HP Pavilion dv9000z Notebook
I have problem with my hp laptop, when ever i restart the system it is asking insert the hp product assistant disc and then click ok to install, i dont have any other disc other than the one which comes along with printer. please kindly let me how to solve this........
thanks
kishore
Aug 29, 2008 | HP Deskjet 6940 InkJet Printer
HP Product Registration pop-up
This is caused by an entry in the Task Scheduler. To get rid of it, you need to be logged on with Administrator priveleges, then do the following:
1. Click Start, type the following in the search field and press enter: Task Scheduler
2. Cllick Continue to confirm permission.
3. Click Task Scheduler Library in the Left column.
4. Click on any of the following in the center column:
a. InternetService Offers (If your pop-up is regarding the internet)
b. Registration (If your pop-up is regarding registering your PC)
c. Service Plan (If your pop-up is regarding warrenty)
d. Extended Service (If your pop-up is regarding extended service plans)
BTW, notice that the idiot that programed these entries set them to trigger every 30 minutes, indefinatly.
Hope this helps.
Dave
Oct 04, 2007 | HP PSC 2210 All-In-One InkJet Printer
Computers & Internet Logo
David Payne
David Payne
