Question about Philips 32PT6441/37 32" TV
NO VIDEO SIGNAL
I HAVE A DAEWOO TV MODEL DTG-2596 , IT OPENS WITH ONLY VERTICAL LINES NO SOUND.
PLEASE HELP
  • MAHER657 Feb 04, 2009
    DR SIR,
    REALLY ONLY HORIZONTAL LINES APPEARS NO SOUND,NO PICTURE.
    REGARDS MAHER
    Master:
  • 505 Answers
Relay needs replacing to be honest it cheaper to get a new tv to fix it like $50 or more from a repair shop
Posted on Feb 01, 2009
Samsung LED TV, Model# UN55B6000VFXZA turns on to black screen then displays large blocks of colored vertical lines?
check every flat cable main boerd to t-con t-con to display if dont help display is a problem
Feb 24, 2017 | Samsung Televison & Video
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Lines vertical
These lines are called vertical retrace lines, and caused by the video output section; or improperly set screen voltage. All of these type of lines will be a little slanting type, across the screen all over, with an approximate one inch apart to each other. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 21, 2013 | Daewoo DTQ-14U5SC 14" TV
Vertical white lines appear on the screen. Samsung provides the following information but doesn't say what circuitry they are referring to. Samsung says: DLP TV: I Have Vertical White Lines...
That answer I agree makes no sense.
Most of these sets have NO vertical hold and if did it will not cause the lines.
A brief educated guess:
Set has a main board that communicates and controls the screen--tests for that are not simple (checking waveforms with a scope and signal generator).
The model indicated here is a DLP that uses a lamp (let me know if model listed is not the one you have).
In DLP sets aside from main/digital board you also have a optical light engine---it processes all signal in and out to the screen.
Optical engines do fail and cause some simple and some complicated picture issues.
Some will even cause the set to "lock up" with a picture or strange looking screen---clue to this is you have to shut the set off by pulling the power cord.
The set may be old enough they do not really want to help you or even talk about it.
May 22, 2012 | Samsung HL-S6187W 61 in. HDTV
2004 rear projection daewoo tv problems
No value used, no one wants this old technology anymore.
May 18, 2017 | Daewoo DSJ-5510CRA 55" Rear Projection...
Verticle lines across top of screen
This is a problem with the vertical circuit and because it "repairs" itself, sounds like either a poor solder connection or a failing capacitor. This is a fairly common problem that is easily resolved. If you have repair experience, you can fix this yourself. Please verify the model number and whether or not you plan on attempting the repair and I'll supply additional details.
Thanks,
Dan
Jun 11, 2010 | Daewoo DTQ-25S2FC 25" TV
Daewoo DTS42 plasma problems, please help!
The PDP (plasma display panel) is defective and needs to be replaced. The big problem is that Daewoo no longer carries replacement panels for this model. I'm in the same boat you're in. I hate to throw away the tv so I'm waiting to see if I can find a replacement panel on ebay.
May 13, 2008 | Daewoo DTS42 42 in. HD-Ready Plasma...
42' plasma daewoo tv with vertical color lines.
the way how you described it looks like the screen is cracked but problem can also be in VPB (video process board).But without the model name its very hard to tell you more
Feb 05, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
No video signal ,flyback lines on my 29pt philips
help is here. back off that screen control tell them lines go away.
you have these things working Powersupply, Vertical, High voltage, sound, leaves video problem , go the the video circuit on schematic and find the video out transitor or ic or whatever they use, check to see if proper voltage or better yet see if got video with a scope, I see allot of shorted video out transistors.
also check and see if you can inject video with a vcr out to the tv in.
Jan 02, 2008 | Philips 32PT6441/37 32" TV
Mitsubishi WD62530 62 in. HDTV LCD displaying blue vertical lines
i just got the same tv today and the same thing happend to me but it happend with the satellite input and i did not have the blue vertical lines i just had a black screen and sound. i unplugged the hdmi cable that carried the signal to the tv and plugged it back in and i had a picture. hope this helps
Dec 17, 2006 | Mitsubishi WD62527 62 in. LCD HDTV
Philips 32PT6441/37 32" TV Logo
46 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
