Question about Pioneer PRO-710HD 64" Rear Projection Television
Pioneer Elite Pro 710 HD
When you power on it turns off right away and won't come on. It has been trying to get to this point for some time now by warning us after leaving it on for three hours it would just shut off. Now it just won't turn on.
  • Anonymous Nov 27, 2007
    I have the same problem with my 710pro. After a couple of hours, the tv pops and turns off, leaving a blank screen and no sound. After it cools off, I can turn it on and get a picture with sound.
  • AVHD Dec 09, 2008
    THe TV would work fine for a while, then would go to standby mode.  Could turn it off for a while then turn it back on and it would stay on.  Now it will only come to the standby mode (red LED on).
    Scholar:
  • 90 Answers
If your Elite 510/610/710 - and the earlier 520/620/720s - works fine when you turn it on but starts to go hinky on its reliability once it has warmed up, you still have a shot at getting that sit remedied for a very nominal fee - or nothing, if you know what you're doing and are an electronics professional. Those models were improperly soldered at the factory on their PS boards. Those PS boards took years to go bad, but now that the constant barrage of expansion and contraction of the too-thin solder joints has started its inexorable journey towards taking down your set, the clock is ticking. You don't have much time.
One thing is very important, and I can't stress it enough: STOP USING YOUR SET NOW. Things could get much worse if you do. That means NOW, even if you are watching it right now. A deadly spike caused by the bad solder joints currently on that power supply board could be getting ready to be produced by a connection that is getting ready to separate as we speak, and that spike could take out one or more of the boards downline. One guy who called me had kept using his set for months with these intermittents happening, and eventually both the converence and the deflection boards went out, both in an instant. The set would not turn on again, and built-in indicators on the circuitry showed 3 boards now needed attention. With 3 boards to now have to deal with, he decided not to get his set repaired at all, due to the now tripled expense. His set was now totalled. It tears my heart out when one of these fine machines goes down for the count because of misuse - continued use when it's obviously hurt - and is then DNR'd by its owner. That all could have been avoided by taking action promptly rather than continuing to tempt fate, on his part.
Send me an email requesting it, and I'll send you back an emailout on how to remove it, what it costs, how to wrap it and send it, where to send it, etc. I can't divulge certain aspects of all this on the net here, must keep some of it close to the vest. Will be glad to tell you personally, by email or on the phone.
I will tell you this much - I charge $275 for the resoldering op, you pay the shipping both ways. That's less than it costs to get a replacement board from Pio and have a local Pio warranty station install it.
Keeping the same board in your set rather than replacing it is the way to go, IMHO. That way the voltages it was set up with originally, stay the same. If you get a replacement board, those voltages can be very different, affecting the precision of settings downline. Voltage regulation only has to fall within certain parameters, so different PS boards will produce different sets of voltages. The PS board and your set are now a matched pair. The best way to retain your precision in downline sets of settings, is to keep your original board in the set, the one your set was originally set up at the factory with.
To find the PS board, follow the power cord from the wall. It will lead you right to it. Use the big bubble-wrap to send it rather than the small stuff, and box it in an oversized box for the journey.
Mr Bob
www.imageperfection.com
[email protected]
Posted on Sep 01, 2009
    New Friend:
My PRO-710HD also has this problem. The screen will flash with a loud "pop" and it will shut down. I have corrected this temporarily by unplugging the unit for a while. Does anyone know the cause or fix for this? It sounds like a common problem. Thanks!
Posted on Oct 24, 2009
Hi.. I have pioneer can not adjust RED color these keep go wayoff ,
Posted on Nov 17, 2008
MSANGIE, I have had this problem with my elite also, very easy fix if your handy. Replace the two STK392-110 convergence chips and check the power supply for a burned out fuse (125v 5A most likely). If your handy soldiering this should be no problem and save you hundreds of dollars.
Posted on Sep 06, 2007
Hi. We have an Elite Pro 610 hd with the same problem. I was told to completley shut the main power off or unplug the tv for five minutes or longer then power back on. This does temporarily solve the problem but ours has it's moments and does this constantly or goes a couple of weeks without doing it at all. Our only local authorized Pioneer repair service said they hadn't heard of these doing this and wasn't sure what the problem might be either. Hope this can temporarily help out.
Posted on Aug 13, 2007
My elite 610 is real dark and darkness control is almost all the way up. What , why and how?
Posted on Sep 04, 2010
  • 65 Answers
I had this problem also... The TV seems like its not as bright as it used to be and then starts turning off after so long and eventually just won't stay on or won't turn on at all... Means your bulb is going out or is already out...
Posted on Nov 25, 2008
SOURCE:
Hdmi picture sound pioneer elite pro r04u
disconect video cable from the box and if you see color video bars on the screen the problems is the box.if you dont see anything you problem is in the display
Nov 10, 2013 | Pioneer Televison & Video
Pioneer elite turns on then shuts off right away
Shutdown can be caused by many different things in the set. Do you get an blink codes from the power LED on the front of the TV? You can order boards and get help from the technicians from part suppliers I often use.
www.tristatemodule.com
www.rivervalleyelectronics.net
Nov 04, 2013 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Can I use a universal remote to adjust my settings for the elite Pro 710 HD?
I doubt it, we have in our shop about five of their remotes and each only works on one or two models--bite the bullet to get another or if you have the original but it does not work, most shops can fix that for a reasonable price.
Dec 14, 2012 | Pioneer PRO-710HD 64" Rear Projection...
My pioneer Pro-710 hd 64in keeps shutting down when turn on.
The most common problem this group of sets had was bad solder connections all over the power board that develop after some years of use----most of them I have repaired a total resolder of most or all connections on that board fixes the problem.
Dec 07, 2012 | Pioneer PRO-710HD 64" Rear Projection...
The convergence chip is going in my pioneee elite
Yes there are two ICs in your model they are around 20.00 each for quality ICs. Cheaper ICs are available but I wouldnt recommend them as theyre most likely the inferior chineese made ICs and they fail quickly.
Nov 27, 2009 | Pioneer PRO-710HD 64" Rear Projection...
Tv pops then cuts off
The right direction is right to the service center! you have a failing transistor that could catch fire.
please rate our help so we stay on the net
Aug 17, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Connecting my comcast hd cable to my pioneer elite hd 1130
you will need the other cables. Hd tv won't work with the old school hookups. rca jacks' can sort out those frequencies
Jan 28, 2009 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Problem with pioneer elite pro-99
We are having the same problem of the Pioneer Elite Pro-99 turning itself off all of a sudden. The red 'non' power button comes on as if we had turned it off remotely.
We would love to resolve this. If you can help let us know.
Jun 30, 2008 | Pioneer PRO-99 TV
Popping and Screen Goes Dark
I have the same power pop off on out elite 710 hd. Can you tell me what to check firts, where the board is I need to check, and what it costs to fix? Is there anyone in SC, do I need to send out? Any help would be greatly appreciated!
dorinda
May 30, 2008 | Pioneer PRO-710HD 64" Rear Projection...
Pioneer elite pro 100
My set is doing the same thing again. The last time I fixed this (4 years ago) it was a capacitor gone bad in the power supply for the 24v standby circuit. (C166)
The service manuals can be ordered directly from Pioneer Part Number ARP3014 for Pro-100 model.
Apr 10, 2008 | Pioneer PRO-100 TV
Pioneer PRO-710HD 64" Rear Projection Television Logo
2,206 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
