Question about Microsoft Xbox 360 Console
My control not working right
My wireless control keeps saying my control is disconnected i have put new batteries in it ok 4 about 5 mins than it goes off again
    Sniper:
  • 57 Answers
1 thing to try is unplug every thing and start fresh then resync the controller to the xbox with the button on the top of the controller on the left with the 3 little ((( on it then press the round button on the front of the xbox to sync them both up this should work
thanks
Posted on Feb 03, 2009
2000 JGC starts and goes dead in 3-4 seconds worked fine until wife came out for lunch tried the remote and it wouldn't work so she used her key got in started it and the horn blowed once so she pushed one...
ok i know this might sound wiered but i just had the samething happen what i did was i cleaned the key with soap and water dryed off , locked the door with key and unlocked with key then got in jeep tryed starting it ,it started right up gauges all work now and windows work and running fine doesnt shut anymore.
Feb 20, 2010 | 2000 Jeep Grand Cherokee
My wi-fi keeps randomly disconnecting but is not bc a weak signal
Your card is ok. There is interference between the router and your computer.
1. The router or the PC may be "hidden" behind a metal cabinet, refrigerator, etc.
2. Move router higher
3. Microwave ovens and some cordless phones (not cellphones) that use 2.4GHz will interfere with the 2.4GHz WiFi signal.
4. Point the router antennas in-line with the direction of the PC.
5. Move the router closer to the PC.
Oct 06, 2009 | HP (319468-002) (319468002) 802.11b...
My netgear isent working even though it says it has a signal
Follow the steps below to configure wireless connection:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply.
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab.
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight thee SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
Sep 03, 2009 | NetGear WG111 802.11g/b Wireless Adapter
Netgear wg111 usb 2.0 won't connect even after clicking repair
Hi, Follow the steps below to configure settings:
Sep 02, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Keys not registering on Cherry wireless keyboard
try with new batteries. rechargeable batteries lose their performance in time
Aug 20, 2009 | ASUS Computers & Internet
I have a wireless connectivity issue from my laptop. When the power cable is connected, the internet works. When I disconnect the power cord, I am disconnected from the internet. This problem has only...
I would say you need a new battery, if when you disconnect the charger your losing your wireless connection, you need more power to hold the wireless connection or that make sure when you remove your charger press your wireless button near your volume control on laptop to make sure its on, blue, not off red ok
Jun 29, 2009 | Acer Aspire 3680 Laptop
Tried connecting controller with xbox on and buttons doesnt work
If you power up a new controller and the Ring of Light lights just keep cycling around in a circle without settling on a position, this means that the game console does not recognize that controller.
This can happen with a new controller or when replacing batteries.
To sync it up with the XBox 360, you need to first turn on your game machine,
then turn on the wireless controller (push the Xbox button and hold it until it lights up),
then press the little connect button on the game console (round button to the right of the two memory slots on the front of the machine),
then press the connect button on the rear of the wireless controller in between the left and right buttons that you normally push with your index fingers (above and to the right of the battery release button).
The Ring of Light will cycle on the controller and then it will be assigned a position by the Xbox and stay lit. To turn a controller off or disconnect it, press and hold the Xbox button in the middle for a second or two until the light goes off - if you are in the middle of a game it will ask you if you want to turn off just the controller or the console as well. When the console powers down, all wireless controllers are automatically turned off.
If this does not work, attempt to connect with a different controller to make sure that the controller you are trying to use is not defective.
Hope this helps!
Apr 06, 2009 | Microsoft Xbox 360 Wireless Controller
Controller connects but after a few moments it disconnects keeps flashing green, sometimes it connects again and sometimes it just keeps flashing green.........any solutions??
you have to use a rechargeable battery pack,for some reason those blue controllers and the legendary need the packs or they wont work right regular batterys dont do it even new lithiums wont work.
Mar 01, 2009 | Microsoft Wireless Controller for Xbox 360...
Acer travelmate 2420 wireless internet connectivity problem
try downloading a new set of drivers and install. http://www.acersupportus.com/2016/07/acer-travelmate-2420-driver-for-xp.html
Feb 03, 2008 | Acer TravelMate 270XV Notebook
Belkin ADSL2+ Modem with Wireless G Plus MIMO Router
Me Two, I just reboot my cable box and router box, i do wireless online gaming and every bout 10 mins, i get disconnected even though i have full signal, on he routers web interface settings I have everything up-and-running and thr top right hand corners says connected, but when it drops I just realised that the internet light stops blinking aswell..???
What is this, this routers is way too annoying keep getting disconnected from every god damn game.
Keep me up-to-date if you what the preoblem is.
And oh, the person who can't get on the internet even though his ''WAN'' Says Stable i have 2 possible reasons.
In the address bat type in the following..
192.168.2.1.
look on the left of the screen you can see DNS, if not already ticked, tick the the little box which states.
'' Automatically assign DNS by IP'' then Apply Changes.
Or, Go Straigt down to the bottom and go to system settings, also go down to the very bottom. At this poin you can see A option or '' Advanced Featue! '' Menu saying, UnPn or something lol, click the box which says enable or something.
Hope this has helped
Thomas Miezavs
Jan 04, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Microsoft Xbox 360 Console Logo
22 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
