Question about Hotpoint FFA90 Bottom Freezer Refrigerator
Hoypoint ffa9op.defrosted i have de frosted it . turned it back on . fridge warm as toast and freezer cold but not freezing .help. was left of 24 hours . been back on 28 hours.it isnt even freezing ice cream
  • michelles946 Feb 01, 2009
    thank you . it has been developing for a few weeks now . do you knw if they are cheap to buy .(fan and compressor).or would i be better buying a new one.
Hotpoint ffa90, I have fridge and freezer problem, non of them are keeping the required temperature though the fridge temperature is showing the right temperature but not cold and the freezer is not freezing as it is contstant between -2 to -5 but it should be
-22, the fast freeze bottom does not fridge either, it does not take instruction.
Posted on Aug 05, 2011
  • Hotpoint Master
  • 4,655 Answers
Has the problem been slowly developing? Is fan inside freezer compartment running? Can you hear fan and compressor running below or behind refrigerator? Is there a collection of dust under and below refrigerator?
Below is a link with more Q&A Click on link and if you need me to assist you are welcome to let me know, Thanks, Sea Breeze
http://www.applianceaid.com/refrigerator.html#freezing
Posted on Feb 01, 2009
  • John Tripp
    John Tripp Feb 01, 2009
    If you are sure that you followed our solutions and really want an honest answer, yes new is the best option in a case like this. Leaks are hard to find , labor is very expensive and parts are almost the cost of a new refrigerator. To do a compressor change correctly involves a days work. Thank you for your rate here at FIXYA, and if you need anything just drop us a line and we will do our best!...............Sea Breeze
SOURCE:
Westinghouse freestyle fridge &freezer work but warm after being turned off fo 90 days
What happens in that 72 hours is the evaporator coil get's so much frost built up on it that the fan in the evap. freezer fan has no where to circulate the cold air (where the cold is produced). Basically you have a restriction between freez/fridg. sections you have defrost problem> It is one of three things d heater,d t stat, or your d timer.I need the model # to tell you what my sugestions would be and where to start.
Nov 15, 2013 | Refrigerators
Why do i have frost on the inside?
frost forms from either the door being left open,a ripped gasket,when warm and cold air meet frost forms,also if the back inside wall of the freezer is frosted up you could have a defrost problem,bad defrost thermostat,heater timer or board depending on the model number.if the warm air got in say overnight you could have a problem with the fridge not getting cold,usually the air ducts freeze up.if it's in the freezer look at the door,you might find ice on the door where the warm air was coming in and also you'll see frozen water droplets on the packages and walls
Sep 02, 2012 | Refrigerators
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
GE 17.2 freezer on top fridge on bottom. Freezer is cold, but fridge is warm. Help!
Is there any frost buildup on the rear panel inside the freezer? If so you have a defrost problem of a bad defrost heater, defrost thermostat, or defrost timer/ control board. If no frost then you probably have a clogged defrost drain. Remove the rear panel to access drain hole.
Nov 09, 2011 | GE 17.2 Cu. Ft. Top-Freezer Refrigerator
Fridge/freezer not working
check the condensor fan if that aint it unit may be low on charge
Apr 24, 2010 | Freezers
I have a Kenmore Cold Spot fridge, freezer on top. Fridge is warm, and freezer keeps freezing up on sides and bottom. I cleaned it all out, defrosted it, and it still freezes up and fridge still won't get...
Is this a self defrost model? Frost inside the freezer could be an air leak around the door gasket. Remove the back panel in the freezer and completely defrost the coils. Is the fan running in the freezer. That will make the frig not be cool. With the door closed peek in the gasket to make sure the light is shutting off, this will warm a frig also.
Eric
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer very cold fridge warm.
does the fan come on if not then the fan delay is bad
May 25, 2009 | Refrigerators
BEKO Frost free freezer not as cold as it should be!
hi i have same problem one of my lodgers left the door open and it froze thick with ice i defrosted it and let it dry for 3 days and was fine for a couple of days then it defrosted so i switched it of for 24 hours it worked fine for a day before it defrosted again could you email me with any help thanks info@mgcsouthern.co.uk matt
Apr 12, 2009 | Freezers
Freezer cold but things not frozen -frosting up. Fridge warm.
most of the time on ge its the defrost heater or defrost sensor in the freezer,that's why its freezing up.you can go to sears .com click on prats put in your modeal number and get yours parts-mike
Nov 30, 2008 | GE GTH18KBR Top Freezer Refrigerator
Hotpoint FFA90 Bottom Freezer Refrigerator Logo
970 people viewed this question
Top Hotpoint Refrigerators Experts
Sal De
Steve Allison
Steve Allison
Carmen Mikulic
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
