Question about Boss Riot 2500D Car Audio Amplifier
Boss 2500d gets hot and trips off and on every 5 mins...
I recently bought a boss 2500d. It performs well during the first half an hour then it trips off, and after five minutes it would come back on or I could I take off the power and put it back on, then it would play for a min and trip off back. During this time the protection light comes on then switches off accordingly. The speaker is new and not faulty and within the stipulated ohms specs the amp is designed for. All connections and wires are new and insulated and well connected including power and ground. Sufficient power is supplied to feed the amp. The amp gets extremely hot when playing at 2, 4 or even 8 ohms at only quarter the gain level and half the head unit, then it trips off. Does it nead a fan or something? What's up with that? It seems as though when the amp is cool it plays continuously. Could it be failing output transistors or a lack of proper contact thereof?
  • peter_brown_ Aug 28, 2008
    Hi I have a 5 channel boss amp. After playing it loud for 1 or 2 hours it starts tripping off--then comes back on in like 3-4 minutes. Or I can turn off the unit --then turn it back on & it will work for 2-3 minutes then it trips off again. And it will do this until I turn it off for a while & let it cool down. Then it will play for 1 or 2 hours then start quiting all over again. Can I do anything with that safety switch? Thanks,
The amp is monoblock so there is no bridging of a single channel to itself.
Posted on Feb 12, 2008
    Novelist:
    Champion:
  • 218 Answers
If you are bridging the amp then you must DOUBLE the "ohms load" that is specified. I.E. If you need 4ohms per channel, then when bridged you would need 8ohms per bridged channel. If your load is indeed correct then you have a fried output probably. Try to run it without any speakers on it. If it still gets hot then you for sure have a fried amp. All the symptoms you decribe sound just like you have too much of an "ohms load" though.
Posted on Aug 01, 2007
How long is complete drive cycle for a 98 chevy blazer s-10 4.3
what do you mean by complete drive cycle as it is unknown terminology
Nov 18, 2017 | Cars & Trucks
Asus s200e stuck on high performance mode
Go into the settings menu and set it to "Balanced". The thing you have to remember is that they say "Up To 5 hours" not will run for at least 5 hours. It probably will last for 5 hours on idle but not if you are watching movies on it. They take a lot of processor time, therefore use a lot of power.
Apr 03, 2013 | Computers & Internet
White knight 77aw trips out after about 5 mins, smells quite hot
I have never seen one of these dryers but I would imagine the control thermostat is probably not working and the safety limit is tripping OR the vent is blocked causing excessive heat and tripping the safety. The filter might be blocked with lint. It supposed to be cleaned after every load.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 05, 2012 | Dryers
Dryer runs for about 5 minutes then shuts off. It gets hot and drum rotates but it keeps shutting off. Then it takes about a half hour before it will start again.
It sounds like you're not getting good airflow and thus tripping the thermistor. Make sure all the vents are clear and the lint trap is clean.
Mar 07, 2011 | Roper REX5635E Dryer
FSX = ****!
It sounds like a RAM issue. FSX needs a minimum of a dual core processor, a good quality graphics card (512Mb min) and 4Mb ram. The "not responding" is caused by the PC having to try to get a large amount of data into a small amount of ram, or the processor is struggling to cope.
Feb 25, 2010 | Microsoft Flight Simulator X for Windows
Hi, i would like to know if Boss is a good brand amp for my truck
it is ok. These amps are cheaper and are meant for use with lower quality speakers. So they do work but I would expect alot from it.
Oct 10, 2009 | Boss Riot 2500D Car Audio Amplifier
Amplifier
First problem is that if you ever have a problem with anything electronic you dont ignore it going on and off or you dont hit it to get it to start working. Thats a true indicator that something is wrong and/or somethings about to break and take everything with it. When it first started to go on and off You could have made sure that the speaker lines were not loose or touching one another or another big problem like this is the speaker wires and how they are ran thru the vehicle sometimes the vibration will rub off the insulation and /or pinch the wire and short it out agains the chassis of the vehicle. The best way for you to trouble shoot this is to first have someone check the speakers and lines. Make sure the inputs are good and disconnect the output lines(speakers wires) from the amp and put a dc meter on one of the outputsw. And have someone turn o0n the power. If theres any dc there for even a spit sec then the amp has blow output devices and probably also bad drivers and predrivers. At this point find out how much your local repair person would charge you for an estamate. or contact Boss at 323.890.3700 ext. 2770 Good Luck
Apr 17, 2006 | Boss Riot 2500D Car Audio Amplifier
Boss Riot 2500D Car Audio Amplifier Logo
227 people viewed this question
Top Boss Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
