Question about Brother CS-8060 Computerized Sewing Machine
Singer Concerto 9217 - problem threading bobbin
Hello - I haven't used my machine in a long time and I am unable to find the manual - I have forgotten how to thread the machine to fill the bobbin. I would really appreciate anyones help. Thank you
  • 3 Answers
Thread the same way as for sewing. put empty bobbin case in bottom. close slide plate only to red button, not all the way. wrap thread from needle around bolt that holds on the presser foot (or just hold it tight). press pedal to sew. bobbin should wind. when done, shut slide plate all the way and sew.
if this doesn't work, try using a pin to push down the center of the bobbin when the slide plate is in winding position - the little catch on the bottom of the plate breaks easily and then the bobbin won't wind without a little help.
Posted on Mar 03, 2009
  • 3 Answers
Https://www.youtube.com/watch?v=BbiYhHmfZFA
Posted on Nov 08, 2015
Singer 9217 thread winds under bobbin instead of on bobbin
Make sure the bobbin is seated all the way on the winding pin. There may be an adjustment for it--a technician can probably fix it for you. However, you can also try lifting the thread with a pencil tip just before it winds onto the bobbin. Some of my machines wind the thread unevenly (more on the bottom than the top of the bobbin) and I balance it out by lifting it when winding.
Oct 07, 2016 | Singer Sewing Machine 9217
Threading problem
Hai, you check the bobbin tension.
Mar 21, 2014 | Singer Sewing Machine 9217
Singer model 9217 too much bobbin tension
First recheck your upper threading. Then go to Pinterest.com and do a search-there is a read good explanation on adjusting the bobbin case.
Jan 28, 2013 | Kenmore 15516 Mechanical Sewing Machine
Instruction Manual for Singer Concerto 3 sewing machine
i have this machine and would be glad to answer any questions for you
susan
Jan 06, 2009 | Yamata FY920
Raising the bobbin
Use a SA 156 metal bobbin (ebay, 20 of them for $8.99 free shipping) and make sure the bobbin thread is turning the right direction, read you manual or call singer at 1-800-4singer
Aug 23, 2008 | Singer 3116 Simple
Singer Concerto sewing machine model 9217
i was having the same problem. try putting in a new slide plate - the pressure from it holds the bobbin down, but it wears thin after a while. fixed mine.
Feb 12, 2008 | Sewing Machines
Singer Concerto sewing machine model 9217 - bobbin thread problem
This problem is common in sewing machines with plastic bobbin cases. The new case you've ordered will most likely solve your problems. I might suggest checking the point of the rotating hook, to be sure it is burr free.
Jan 31, 2008 | Sewing Machines
Bobbin is not winding correctly
slide plate may be worn - i had the same problem. try holding down the center of the bobbin with a pin while slide plate is in the winding position.
Dec 31, 2007 | Singer Featherweight 132Q Mechanical...
Threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Nov 07, 2007 | Janome Mini Compact
Brother CS-8060 Computerized Sewing Machine Logo
3,280 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
