Question about Microwave Ovens
Microwave runs but does not heat up food
I read it could be a problem with the thermal cutoff, capacitor or transformer. Is this something I can fix myself??? This is an over the range microwave. Thanks
It is not safe to take apart your microwave as there are very high voltages and radiation
Posted on Feb 01, 2009
Not heating food up
please make this test and fix it. Use the multimeter.
Merry Christmas.
  1. Check the power diode This electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitor Responsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetron Responsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal Cutoffs Examine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
Dec 16, 2013 | Daewoo Microwave Ovens
Microwave does not heat
please follow this steps and fix it. God bless you
Dec 09, 2013 | Panasonic NN-S561 Microwave Oven
Unit does not heat
follow this steps.and fix it. God bless you
Dec 09, 2013 | Microwave Ovens
Microwave runs but doe not heat
follow this test and fix it. God bless you
Nov 26, 2013 | GE JVM1190 Microwave Oven
It runs but won't heat, what do I do?
please follow this test and fix it. God bless you
Nov 22, 2013 | Hamilton Beach Microwave Ovens
Will not heat food
please test the steps and fix it. God bless you
  1. Check the power diodeThis electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitorResponsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetronResponsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal CutoffsExamine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
Oct 26, 2013 | Whirlpool Microwave Ovens
Will not heat food liquids at all
Oct 25, 2013 | LG MB3949G Microwave Oven
Re Microwave: we turned it own and then there was a loud bang like something had blown (transformer-board?)... thereafter there is no heat from the unit, the light comes on and it does rotate. Could you...
test this components and fix it. God bless you
Oct 24, 2013 | Whirlpool MH6140XK Microwave Oven
Panosonic Microwave working but not heating
see this instruction and fix it. God bless you
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#2#ixzz2ZYTePT1u
Jul 19, 2013 | Microwave Ovens
Cm302b
see the following steps , use the VOM and fix it. God bless you
Jun 17, 2013 | Thermador MBBS Microwave Oven
Microwave Ovens Logo
135 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
