Question about Honeywell HZ-510MP Ceramic Heater
Diagnosing a short cycling honeywell HZ-510 heater
I bought a used HZ-510. It seemed to work fine pre-purchase.
After getting it home, it cycles off and on.
On about 1 to 3 min and off 3 to 5 min.
I removed the cover to diagnose the problem. I cleaned the temperature sensor located right over the ceramic coils, it had a small amount of dust. The thermostat seems to operating properly as it calls for heat and stops calling when it is turned down or is satisfied.
The fan is operating, the blades are clean, the coils are clean. I see nothing that would indicate improper air flow.
The only thing that is throwing me is what apears to be a temperature sensing device on the thermostat knob itself.
With the pendulum type wighted cylinder that opens the contact.
It is getting hot to the touch, is there a desighned temperature it is supposed to reach and not exeed?
I understand that being purchased used and not being the original owner it may not be under warranty.
Any ideas as to what is the problem and where to get parts if needed?
By the way, I am a heating and air conditioning contractor in NC if that makes a difference. MY HONEYWELL HZ-510 PROBLEM DESCRIBED BY meBNme IS THE
SAME PROBLEM I HAVE. ANY SOLUTION YET? PLEASE LET ME
KNOW. THANKS. BOB
BCNAV@YUKONWALTZ.COM
  • cyclesearch May 02, 2009
    short heating cycle or it never turns on.
There is no "official" way to fix this problem, but I did find a solution. You have to open the case by removing the 6 security screws on the bottom, and pull the height and thermostat knob off (they just pull off easily). You will see on the underside of the thermostat switch, a dangling weight (the tilt sensor). It is attached to 3 sandwiched metal arms. The very bottom arm is designed to bend upward when it gets hot, and it lifts the contacts apart. If you bend that bottom arm downward just a little (don't go too far, or you'll lose the thermostat feature altogether) it will allow the arm to heat up to a more reasonable temperature before shutting the heat off. Just reassemble, and it should work!
Posted on Apr 26, 2013
  • 4,654 Answers
Here is a link to manual and trouble shooting guide. Also service numbers and e-mail contacts. Hope this helps, Thanks and let me know,
Sea Breeze
http://homeappliance.manualsonline.com/manuals/mfg/honeywell/hz510.html
Posted on Feb 01, 2009
The settings for welding aluminium using a Tig200P AC/DC inverter
If you are using a remote then you would set the machine in standard for controlling output and also to AC output, HF tig, contactor and control in remote position. I don't know if this helps or not but I pulled it from an owners manual.
1/16" (.062) - pre-flow .1 sec., hot start 20, amperage 70, Hz 100, balance 20%, post-flow 6.0 sec.
For pulse settings - set pulse width 60%, peak current 100, background current 30, Hz 1.0
1/8" (.125) - pre-flow .1 sec., hot start 20, amperage 150, Hz 80, balance 20%, post-flow 6.0 sec.
For pulse settings - set pulse width 60%, peak current 150, background current 50, Hz 1.0
3/16"-1/4" - pre-flow .1 sec., hot start 20, amperage 185, Hz 60, balance 20%, post-flow 8.0 sec.
For pulse settings - set pulse width 60%, peak current 185, Background current 125, Hz 1.0
Mar 14, 2014 | ARC Thermadyne Inverter Stick/TIG Welder...
Hotpoint DC28 not washing
1.press cancel button
2.check if the door closes securely.
3.since there is water in d/w try running a short cycle.If it works, clean the inside thoroughly to ensure no clogs.
Jan 12, 2014 | Hotpoint 18 in. DC28 Slim-Line Built-in...
How do I program the H5CX ASN timer to turn on 5 mins and off 25 mins in an endless cycle. I don't understand the term Output Mode so from that point the instructions become meaningless.
Omron:
https://www.ia.omron.com/support/
http://waterheatertimer.org/pdf/h5cx_sell-sheet-wiring.pdf
I believe you have 230Volt 50 Hz electric power.
Omron is rated 50-60 hz
US timers are rated 60 Hz.
Maximum load on Omron timer is 5amp at 230 volt
Timer should be connected to 2-pole contactor (relay) instead of directly connected to pump.
http://waterheatertimer.org/images/contactor-drawing.gif
Does Amazon sell percentage cycle timer in your country?
A cycle timer makes one full revolution each hour, or 4-hours, or 12 hours. Then percentage is set for 8% for 1 hour cycle.
Contact Intermatic and ask if they have 50 cycle percentage cycle timer, or ordinary cycle timer in 50 Hz.
Nov 22, 2012 | Omron H5CX A AC100-240 Multifunction...
HOW TO OPENLINE HITACHI CDMA W42H???
All type of phones (old modeles):
NAM programming: 47*869#08#9
Test mode: *759#813580 or 5809540*45680
exit test mode - 02
A-Key: menu + 0, code 25##
Samsung A500
1. Enter ## and the 6 digit OTKSL
2. SERVICE MENU will appear and 1.Basic will be highlighted
3. Press OK
4. Device will display NAM CDMA/ Phone Number
5. Enter 10 digit MIN
6. Press OK (3 times)
7. Display will return to Service Menu. Press END.
8. Programming is complete
Samsung N240 and N400
1. Enter ## and type in the 6 digit OTKSL
2. The display will show SVC MENU and 1. Phone Number
3. Press OK
4. Enter the 10 digit MIN and press OK
5. The display will show NAM with Home SID on the second line (Note: SID is no longer used)
6. Press OK
7. The display will return to the SVC MENU
8. Press END to complete the programming
Samsung Uproar
1. Press MENU key
2. Enter 9 2 0
3. Enter the OTKSL
4. At SVC Menu screen press OK
5. Enter MIN and press OK 4 times
6. Enter SID (4654) and press OK
7. Press END key
Samsung N300
1. Press ## followed by the OTKSL
2. SVC menu will be displayed
3. Press 1 for Phone #
5. MIN that was entered will be displayed press OK
6. SVC Menu will display press 3 for NAM
7. Enter the 4 digit Home SID press OK
8. Press END and handset will power cycle
Samsung i300
1. Tap on the Phone Icon with stylus
2. Press #907*9#0 ENTER LOCK should appear on screen
3. ENTER OTKSL
4. SVC MENU will appear press 1
5. Enter 10 digit MIN and then press SAVE
6. Press SAVE again
7. Press 3 and then press SAVE 6 times
8. Enter the HOME SID and press SAVE once
9. Press END key twice
Samsung A400 and A460
1. Enter ## and OTKSL
2. Press 1 for Basic at MENU (1 of Phone # when using the MSL)
3. Enter 10 digit MIN and press OK
4. At 1.Basic Menu press the END key
5. Handset will power cycle
Samsung 3500 8500 6100 N200
1. Press MENU
2. Press 6 0 (3500) 8 2 0 (8500/6100/N200)
3. Enter OTKSL
4. Press 1 at SVC MENU Screen
6. Press OK 4 times
7. Enter SID (4654) and press OK
8. Press END key
9. Programming is complete
Qualcomm:
QCP-800 programming: menu + 3 + 0.
SPC: "000000" or may be other SPC typed by user.
QCP-820/1920/2035: type "111111" and press Jog Dial.
Choose "Programming" and enter SPC: "000000" or may be other SPC typed by user.
QCP 1960 and 2760
1. Press softkey under the work MENU
2. Press 8 0
3. Enter the OTKSL
4. Press softkey for OK
5. Enter MIN and press softkey for OK
6. No SID is require for this handset
7. Press softkey for EXIT
LG:
LGC-300 programming: menu + 9 and enter SPC: "000000" or may be other SPC typed by user
A-Key: press STO for some time while you can see special code enter zone. Type 2539** and enter A-key
LGC-330W programming: menu + 4 + 0 and enter SPC: "000000" or may be other SPC typed by user.
A-Key: type 2539** and enter A-key
LGC-800W /500 programming: menu + 0 and enter SPC: "000000" or may be other SPC typed by user.
LGC-510 programming: menu + 3 + 0 and enter SPC: "000000" or may be other SPC typed by user.
LG1010 LG4NE1 TP2200 TP2100 Touchpoint SB/DB TP 1100 TP5200
1. Press ##
2. Enter the OTKSL
3. Scroll to SAVE and press OK
4. Scroll to MIN and press OK
5. Enter 10 digit MIN scroll to SAVE and press OK
6. Scroll to SID and press OK (Skip on 4NE1 go to RESET PHONE and press OK to complete)
7. Enter SID (4654) and scroll to SAVE and press OK
LG5350
1. Enter ## and enter the OTKSL and press the left soft key under the word clear.gif
Mar 01, 2012 | Cell Phones
Hey i had purchased a Samsung galaxy 3, 2 months ago.Its battery is frustrating It doesn't give even 4 hrs of talktime .My wifi,gps,internet nothing is on but still it looses 20% in 4-5 min of talk on gsm...
According to online specs, this is your phones battery:
Stand-by Up to 620 h (2G) / Up to 510 h (3G) Talk time Up to 15 h 30 min (2G) / Up to 7 h 15 min (3G)
4 hours is way too low. You might need to get it to a service center and it should be fine seeing you're still within your warranty period.
Mar 16, 2011 | Samsung Cell Phones
I need an owners manual for my Honeywelll-kaz HZ-705
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can't find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Sep 23, 2010 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
The main on/off switch is defective... Where can I purchase another one? Honeywell portable heater HZ-515
dear sir /madam
please find out heater unit company,s dealer at your area you can purchase that switch or you contact to your maintenance personnel for further action .i mean replace your defective switch.
hope answer the question
please vote
thank you!
Sep 05, 2010 | Honeywell HZ-515 Baseboard Heater
We purchased the Honeywell HZ-709 heater and the instruction manual is missing. How do we operate it?
http://www.honeywellcentral.com/ssi/pdf/honeywell-commercial/oil-filled-heaters.pdf
That is the manual that you need. Hope this helps. If you need anything else, let me know.
Nov 19, 2009 | Honeywell HZ-709 Oil Filled Radiator...
I lost the dock that connects to the computer
Your only option is to purchase another Home dock for your TomTom GO 510. The 510, 710, and 910 all use the same dock. The cheapest place to purchase a home dock is ebay. The answer to the second part of your question is no, you cannot purchase a usb cable to connect your TomTom GO 710 to your pc. The TomTom GO series uses a proprietary dock.
Jul 16, 2009 | Tomtom GO 510 Car GPS Receiver
Need to use the smartpool Orion pool cleaner on 240 volt 50 hz power. A friend bought one in the USA (100v, 50Hz) but is using it in Cyprus where the home voltage and current are different. He has a 240 to...
It will not work on 50 Hz. You could try a variable frequency drive to up the cycles or check with an electronics shop to see if they have a lower cost way of stepping up 50 to 60 cycles, otherwise it won't work.
Jun 27, 2009 | Smartpool Dolphin 3001 Commercial...
Honeywell HZ-510MP Ceramic Heater Logo
817 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
