Question about HP OfficeJet 6110 All-In-One InkJet Printer
HP printer I have an Hp 6150 all in one printer/fax/copier/scanner. When I go to print something it starts to feed the paper then jams. the top left corner of the piece of paper is always folded over when I clear the jam. How can I fix this problem
    Scholar:
  • 125 Answers
Most likely worn pads & rollers, I'm afraid. Kits are available though. Not too dear.
Posted on Aug 01, 2007
SOURCE:
X4270 paper feed jam
You may have remnants of torn paper left in the feed rollers or beyond -from a prior jam. Other causes include:
  • Overheating
  • Wrong Paper Type
  • Printing Labels
  • Cracked or Dirty Rollers
  • Use of Wrong Tray
  • Incorrect Loading of Paper
  • Paper Overload
Nov 21, 2013 | Lexmark X4270 All-in-One Multifunction...
HP 1610 printer photo paper jams
Right click on default printer icon select printing prefrences,click on advanced tab,select the size.or
Click on start menu then click on control panel.
Click on classic view on the left pane.
Double click on printers and faxes from the top toolbar.
Click on add a local printer.
Select the USB 001 virtual printer port from the “Use existing port” and click on next.
Select the manufacturer as HP and printer as Deskjet 990c and click on next.
We are using the generic driver for HP printers.
Use the default name for the printer, or you can change to your printer name and click on next.
Select yes to print a test page and click on next.
Select yes to set as default and click on next.
Select no to “do not share” and click on finish.
Jul 28, 2010 | HP PSC 1610 All-In-One InkJet Printer
Problems with hp laserjet 3330
suspect either worn ADF(automatic document feeder) pickup roller or there is a jam in the ADF unit where the paper feeds to the scanner.
Mar 11, 2010 | HP LaserJet 3330 All-In-One Printer
My fax something and now part of it is jammed if i try to fax again the paper won't go though please help
Your owner's manual will walk you through the steps to remove the jam. If you are feeding from the tray on top, make sure you don't have any documents of the scanner glass. This could cause a jam.
Lift the lid as though you were going to scan a document. With the lid up, immediately to the left of the glass, firmly lift the edge of the black cover, exposing the rollers. You should be able to pull the jam out.
Dec 01, 2009 | HP Officejet 6310 All-In-One InkJet...
HP G85 PAPER JAM ERROR ,but still prints from scanner fine
Remove the rear cover...clean the rubber rollers with alcohol
Feb 17, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
Paper feed jams
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 08, 2009 | HP Photosmart C7280 Laser Printer
Printer jam
hve u tried removing the paper jam from a proper place.hp has provided a door behind the printer to clear paper jam.open that door n check out 4 any paper part left out in it.wish u success
May 31, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
HP PSC 1610 All-in-One paper jam
ur printer paper feeder gears r jammed or misaligned. kindly get ur printer serviced from a good technician.dont worry its a normal problem.wish u success
Mar 11, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
HP OfficeJet 7310
showing paper jam and have checked and don't see any paper
Dec 17, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
106 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
