Question about Sharp AR 201 Copier
Sharp ar 201copier not working
Whenever i switch on my machine the display shows L 6. All the operation and keypade does not work,i am not an expert but i think there is problem in the laser. kindly advisc me and suggest what to do, also the rate(amount) of the items which i have to replace if any.
  • 328 Answers
L6 means that the polygon mirror is locked up. I have repairedthis many times in HP laser printers and is is relatively easy. The top cover needs to be removed and laser scanner opened. Then remove and clean the mirror asm. May have to replace the scanner asm. This will be expensive.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Aug 01, 2007
Sharp R-9H84B-display black, cleared display shows "Conv Mix, 88:88 Auto". Short time all dark again. Hit clear happen 2 times then, all dark, no power, can't clear won't start, nothing works.
R-9H84B - May 29, 2017
I would suggest pulling the control board out and looking on the foil side (opposite the component side) for "ring cracks," most likely on the low voltage transformer's connections.
The board may have the screen-printed reference designator "T1" near the low voltage transformer.
Also be sure the fuse is not easy to turn with your fingertips when it is in the holder. If it is, the fuse holder is too loose and must be replaced (not just squeezed with pliers).
You can order a fuse holder, part number WB06X10034 for $6.49 (subject to change) from the Pros here.
If you have any keypad issues, please note that the membrane keypads for this model have long been discontinued.
FixYa does not directly notify us experts of responses, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 28, 2017 | Sharp Microwave Ovens
SHARP AR 5520 keep displaying TONER INDICATOR ALARM MESSAGE whenever I switch on the copier. And even if there is toner, the message keep displaying. So what is the problem?
Dear
The ink cart. is dual component one is drum unit and other is toner unit. You may go to system information there consumable information which indicate the status of the both and according to that replace the chip of the respective cart.
Thanks.
Jan 12, 2015 | Sharp Office Equipment & Supplies
My sharp MX-M450 turns on but there is no display, why?
sometimes if there is a fax board on the back and the power switch is off on that it wont light up the display. either that or something is wrong with the display itself. sometimes those ribbon cables have to be replaced that power it.
Copier Collin Houston TX Copier and Imaging Expert
Jun 29, 2014 | Sharp AR-M450N Copier
HI, my copier AR-122EN is not working it shows 4 and H when I press he start button.
From the keypad area press # * C * The machine will enter a diagnostic mode.
Then enter the number 14 as if to make 14 copies. Press start and follow the directions to clear the code.
Mar 11, 2011 | Sharp AR-5316 Advanced Digital Imager...
My copier sharp AR-161 is not working it's write
please change toner cartridge chip your toner cartridg is fail due to toner empty
May 12, 2010 | Sharp AR-160 Copier
Sharp Ar-M205 displays "d", no control panel operation.
I think "D" means it has been put into firmware download mode. (When a techo wants to upload the firmware).
Just try turning the machine on and off from the main large switch on the left of the machine
Aug 18, 2009 | Sharp AR-M205 Copier
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
Mar 03, 2009 | Sharp AR-M237 Copier
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR 5316
there might be some dirt on thermistor above the heater upper roller pls check and clean the fuser unit then use simulation 14 to reset the machine enter simulation by presssing #,interrupt,c,interrupt in sequence display is then off, then no. 14 then start key h2 disappears ok
Sep 04, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR 201 Copier Logo
Top Sharp Office Equipment & Supplies Experts
k24674
George Mclaughlin
polytek
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
