Question about Systemax Dual-Core AMD Athlon 64 X2 4400+ / Microsoft Windows XP Professional / 1GB DDR / (2) 300G... (989126) PC Desktop
Big problems....... systemax venture running windows xp pro. I was doing a video lesson online when lightning struck and knocked the power out in the middle of this lesson. Now the computer does not allow me to do anything except to get online as long as I don't open more than 1 window. It will not shut down at all, it does not allow me to do a restore, before the shutdown I had removed a trial version of a spyware program in the recycle bin, so when I try to empty it the computer locks up. It does not start in the safe mode, it gets to a certain point and stops. It does not install any updates without locking up so it never does install anything. Many programs lock it up and if I am able to "end now" from the task manager nothing else will open up. I tried getting systemax to send me a boot cd but no one has responded to my emails. The warranty just expired.
    Brigadier General:
  • 6,966 Answers
Hi, When lightning strikes in my area, normally what gets zapped is either or a combination of: DSL modem, AP/Router, NIC which are all hardware but in your case, I get the impression that it's software related. Although I'm tempted to say that you check your hardware, I would suggest that you fresh install windows XP Pro. If you have files that you want to retain, of course back them up and burn them to a CD or DVD. If in the current state of your PC you can't burn, then you either get another hard disk where you can install XP and run everything from there. Your old HD may then be used as a backup or file holder. Or get hold of another PC where you can temporarily install your HD as a secondary master and proceed to copy. From all indications, I get the impression that if you just repair your windows, sooner or later other problems will come up so a fresh start/install would be logical. Hope this works out for you and pls post again how things turn up or if you need further information. Good luck and kind regards.
Posted on Aug 01, 2007
  • 41 Answers
Since there is a lightning strike involved, there could be any number of problems. The first thing I would do is open the case and visually look for anything that looks burnt or any capacitors, etc., that may have "exploded." I would rule out a power supply problem since you do have the machine on. My thinking would be more along the lines of the motherboard, hard drive, RAM, or a combination so check these first for the above mentioned problems. The downside of this is that even if there is no visual damage, there could still be lightning damage that isn't visible. This makes lightning related issues hard to diagnose. I hope this will at least head you in the right direction.
SOURCE:
Problem setting up windows XP
D to Delete all the partitions on the drive to get all the space into one big contiguous space. Then try installing.
Apr 06, 2012 | Systemax Venture S519J (988868) PC Desktop
I have a 58'' HP Pavillion Projection screen TV. It was struck by lightning. the power cord is good. It will not turn on at all, no fans running, etc. What do you think I will have to fix?
As u have just said that it was struck by lightning the only way to get the TV back working is to replace burnt items on the moterboard .becouse lightning must have demaged some components on the power supply, if possible i would preffer a new power supply board
Aug 31, 2009 | Televison & Video
System properties, xp pro
1. Click Start
2. Click Run
3. Type this in the run box: c:\Windows\System32\oeminfo.ini
Something like this should open in notebook:
[Version]
Microsoft Windows Whistler Edition
WinVer=5.01
[General]
Manufacturer=vpr Matrix ™
Model=Personal Computer
SupportURL=http://matrixsupport.net
LocalFile=c:\matrixsupport\file.html
[Support Information]
Line1=”Visit us online or call our toll-free Customer Support number 24/7!”
Line2=”http://www.vprmatrix.com”
Line3=”cb_transparent_l.gifus.gifspace.gifspace.gifarrow.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gif(800)332-4800cb_transparent_r.gif in the USA and Canada.”
Line4=”"
Although I wouldn’t play with anything under the version section, you can edit the information in the other sections. You can edit anything to the right of the = sign.
Save it before you exit notepad and you’ll be set.
You can also edit the bitmap that will be displayed on this screen by changing this file:
It must be 172 X 172 pixels in size.
Feb 01, 2009 | Systemax Venture H356 Desktop Computer -...
Video drivers crash my Systemax out of XP
your video card is most likely overheating, either you are overclocking the video card or the video card's fan is stuck, jammed, broken ect...
Dec 24, 2008 | Microsoft Windows XP Home Edition
I need a sound driver for systemax venture
Hi
Firstly, try getting the motherboard model and checking the manufacturer's site.
You could try drivergrabber off majorgeeks.com (easily found on google). Alternatively, try googling the device ID's - found by clicking start > run "msinfo32" OK. In that screen, click the [+] next to components and then go to Problem Devices. In that screen, on the right hand side, you will have things written such as PCI\VEN_8086&DEV_3A3A - go to google and type in exactly as follows "8086 3A3A" (or whatever shows up after VEN_ & DEV_ in your case) and see what you can find.
Alternatively, if you're running a legitimate copy of Windows, Windows update (if on XP you must install Microsoft Update), can often pull these straight down off the Microsoft servers.
Dec 15, 2008 | Systemax Venture PC Desktop
No Audio
I have a friend with a systemax, same thing happened to him.
Go into the control panel, select sounds and audio devices, go over three tabs to the audio tab, make sure the sound default device is the onboard audio card. Should be all set.
Let me know how it works out.
Nov 23, 2008 | Systemax Venture S519J (988868) PC Desktop
Open Questions:
AOL DESKTOP GOLD isntallation error #@ {1844641-OO35} pHoNe nUmBeR SAKTE USA AOL DESKTOP GOLD can't open linkAOL DESKTOP GOLD not working pHoNe nUmBeR {+184464I-OO35} to resolve all AOL DESKTOP GOLD email products. JCG is an American multinational company which was founded by Michael AOL DESKTOP GOLD email using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, AOL DESKTOP GOLD email support number, and selling of computer-related services and products. AOL DESKTOP GOLD email Tech Support Phone Number Recently, AOL DESKTOP GOLD email has been named the number AOL DESKTOP GOLD email technical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, AOL DESKTOP GOLD email customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a AOL DESKTOP GOLD email Service Tag or a AOL DESKTOP GOLD email Get AOL DESKTOP GOLD email Technical Support Phone Number and Customer Services. AOL DESKTOP GOLD email is a US-based multinational tech organization having its headquarters located in Round Rock, Texas. This tech organization supports, repairs, sells, and develops technology products. Basically, the company offers computer related products and services
Aug 17, 2019 | AOL Computers & Internet
AOL DESKTOP GOLD configuration #@ {1844641-OO35} pHoNe nUmBeR SAKTE USA AOL DESKTOP GOLD mail can't open linkAOL DESKTOP GOLD not working pHoNe nUmBeR {+184464I-OO35} to resolve all AOL DESKTOP GOLD email products. JCG is an American multinational company which was founded by Michael AOL DESKTOP GOLD email using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, AOL DESKTOP GOLD email support number, and selling of computer-related services and products. AOL DESKTOP GOLD email Tech Support Phone Number Recently, AOL DESKTOP GOLD email has been named the number AOL DESKTOP GOLD email technical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, AOL DESKTOP GOLD email customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a AOL DESKTOP GOLD email Service Tag or a AOL DESKTOP GOLD email Get AOL DESKTOP GOLD email Technical Support Phone Number and Customer Services. AOL DESKTOP GOLD email is a US-based multinational tech organization having its headquarters located in Round Rock, Texas. This tech organization supports, repairs, sells, and develops technology products. Basically, the company offers computer related products and services
See all Systemax Dual-Core AMD Athlon 64 X2 4400+ / Questions
Systemax  Dual-Core AMD Athlon 64 X2 4400+ / Microsoft Windows XP Professional / 1GB DDR / (2) 300G... (989126) PC Desktop Logo
Top Systemax Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Mike
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
