Question about Car Audio & Video
Pinouts on Rear Panel Connector of Matsushita Radio/CD/Cassette
Purchased a Radio/CD/Cassette player unit (2 DIN size) and require the pinouts of the rear connector to apply power and speakers etc. It is from an Early-Mid 90's Toyota and the car was totalled but the unit is right to go. I just need to connect it up. Either a manual or the pinouts is appreciated.
Model is: 86120-2A150 or Ref: CQ-MS2030A
There is also a power amplifier that goes with it: Model=86250-60020; Ref=CY-BT495A
  • driss_ziti Mar 26, 2009
    I CAN'T FIND THE PIN OFF MY CAR AUDIO
    Model is: 86120-05060 or Ref: CQ-MS6070L WITH SERIAL NO 220959
    There is also a power amplifier that goes with it: Model=86110-05011; Ref=CN-TS6070LA
  • Anonymous Apr 05, 2009
    mi problema es parecido tengo una autoradio MATSUSHITA modelo: 08690-00790 REF: CX-LS0750C deseo saber si hay alguien que tenga el diagrama de conexion del pinado de los cables.....
5 Suggested Answers
SaintGene
  • 53 Answers
SOURCE: I need the pinout for the Panel 2 connector Shuttle MV43V v7.3
Hi mrdcoe,
Here's the pinout you needed.
If you need more information about your motherboard, you can always download the manual from this link,
http://eu.shuttle.com/download/Archive/Manuals/en/mv43p_n/mv43pen.zip
Good luck,
Don't forget to rate my solution, thanks!!!
Posted on Jan 17, 2009
dnewcombe1
  • 1564 Answers
SOURCE: Pin out diagram for Matsushita Car Stereo model 39100-s9A-A2000
You've got to get that info from a dealer or audio installation specialist.
Posted on Jul 26, 2009
  • 4748 Answers
SOURCE: I don't know my matsushita radio code;
If this is the Matsushita fitted into a Honda, then try here
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} HONDA codes may be available here
https://radio-navicode.honda.com
You will require the car VIN number and Radio serial Number
If they cannot provide your code then you will have to try your HONDA Main Dealer .....or a Decode Service who will plug in a laptop to read/recode the memory chip (EEPROM)
Posted on May 18, 2010
  • 4 Answers
SOURCE: DUAL XDVD8281 Car DVD Player I
WWW.DUALAV.COM indashes XDVD8181 owners manual
good luck
Posted on Jul 31, 2010
SOURCE: wireing diagram for a matsushita
97 Honda Accord EX leather: I am trying to find some audio parameters on my 6X9 rear speakers. I only find 4Ohm, 16W, USA EASA23DO1B1 on the speaker. I am looking for freq response, power handling, magnet type & wt.
Posted on Jul 19, 2011
CCTV cir-700sd. Where can I get rewiring information?
Leads Direct ' SCART Wiring
www.leadsdirect.co.uk/technical-library/pinouts-wiring.../scart-wiring/
A SCART connector is used to connect two electronic devices such as a television set and a video cassette recorder (VCR) or DVD player. Each device has a ..
Sep 19, 2015 | Home Security
94 Honda Prelude Factory Car Stereo/CD Player
The BUS wires are a serial data link, probably incompatible with other makes of CD player. I'd hesitate to connect it to +12v, this may cause damage. If anything try connecting it to BUS.C through a 1kohm resistor to start with.
Perhaps you need something like this to make it work. http://www.caraudiocentre.co.uk/product_m-alpine-kcm-122b_p-20941.htm
Oct 21, 2007 | Car Audio & Video
Pinout Details for HP C7671B transparency adaptor mini din connector
Cut the mini din wire, you will see four wires inside the sleeves. The red wire is positive terminal, and black wire is negative terminal. Use any 12V DC adapter to connect. The adapter will light up. Good Luck.
May 12, 2012 | HP Office Equipment & Supplies
What is the pin layout for the rs232 connector on the F5U409v1 adapter from belkin.
The pinouts are in numerical order
1 2 3 4 5
6 7 8 9
Pin signals:
1.Data Carrier detect
2.Rx
3.Tx
4.Data Terminal Ready
5.Signal Ground
6.Data Set Ready
7.Request to Send
8.Clear to Send
9.Ring Indicator
Dec 20, 2010 | Computers & Internet
Model D3057F3H Want to use it to power a car radio. What is the on / off connection and what is the 12V out let than can handle 5amp
Check the label on the power supply for the current rating on 12 volts.
The +12 volt is the yellow colored wire and the black is the ground.
To turn on the switch mode power supply connect pin 14 (for a 20pin connector) or pin 18 (for a 24pin connector) to ground.
You can use a switch so you can turn the power supply ON and OFF.
Please click on this link for diagrams of the 20 and 24 connector pinouts :-
http://pinouts.ru/Power/atxpower_pinout.shtml
http://pinouts.ru/Power/atx_v2_pinout.shtml
Sep 12, 2010 | Hi-Pro (HP-P401W) (HPP401W) Power Supply
Need pinouts diagram for Pioneer DEH-1600 CD Player
ok my friend has a 1999 ford f150 and we took the radio out to put in a poineer deh-1600 and we bought the connectors but one of the connectors doesn't fit and there was for wires were free when i got done the wires was a solid black with a white stripe, a solid orange with a white stripe, and a solid blue and a solid orange cable left tell me what do those wires goes to
Jan 16, 2010 | Pioneer DEH-1600 CD Player
Screen wiring pinouts accoustic solutions dvd 263
hai
if you check in www.allpiouts.org and www.stockcable.com tells you which pin is what. i have the same system and i tryed only using 9v input not any video input. it only stays in standby the remote does nothing when i try to use it. if you got any solution please email to me in eddiechellam@yahoo.co.uk
Sep 27, 2009 | Durabrand Portable DVD
Would like to connect i pod into my system, but have no instruction book or wiring diagram. The model is a Sony CDX 5470 RDS
I just did this yesterday with my Kenwood MP8017 and an old Dell Pocket DJ. The deck uses a 15pin DIN connector. I had the connector and just used trial-and-error to determine the left, right channels and ground.
For your setup, you need to first determine what sort of inputs that the Sony unit has. Most have some sort if DIN input. If there is an AUX input, you are good to go as it is simply GND, Left and Right Channels. Then use this to deterime the signal pinouts from the IPOD cable.
You will have to hack up an IPOD docking cable (you can get them cheap here.). and get an 3.5 mm jack to cut up as well.
If your deck uses a DIN connector, you will have to source one of those and determine its pinout. Then, just match it with the IPOD connector and you are good.
Apr 20, 2009 | Sony Car Audio & Video
Durabrand Db1200 installation
As per our chat session I said I would be back while I search out your product...so here is your information; http://dbproducts.net/i/product/manual/DB1200_OM.pdf
Aug 24, 2007 | Durabrand DB1200 CD Player
Car Audio & Video Logo
2,119 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
