Question about O2 Xda IIi Smartphone
Align screen not responding
I have hard reset my O2 but I'stuck at align screen because it does not responding well. after i touch all the cross..it is still at the allign screen page....
  • 1 more comment
  • mat emy
    mat emy Nov 09, 2007
    dopod 810 pro
  • Dhayashiv Mar 13, 2008
  • Anonymous May 02, 2009
    Touch scren does not repsond. I think it has something to do with digitizer.
Tap the screen to set up your windows mobile- based device
Posted on Nov 09, 2007
  • 139 Answers
Go to the Website and see if the is a new software update available,let me know ttech
Posted on Aug 01, 2007
I THINK YOUR BATTERY Has gone weakerr. chaange the battery , AND KEEP CHARGING WHILE ALIGNING.'
Posted on Jan 05, 2008
SOURCE:
Garmin iQue M3. Gradually not responding to touch
First make sure the screen is clean of any dirt or oils that may deposit on your screen from your fingers. Use a stylist (a mini pencil like item that came with your GPS) or and other non metal semi pointed item and go through the screen alignment process. Hit the "X's" as you see them (it will move 4 or 5 times to ensure the screen is aligned.) After it is aligned it should give you other options. I have seen GPS's recycle trough the alignment process two or three times before cycling out. If you do this and you are still you are having issues, and you have tried resetting it, you may have a hardware issue.
Mar 07, 2011 | Garmin iQue M3 Pocket PC GPS Receiver
The calibration on my samsung impression was way off so i used the unlck code *2767*3855# the phone shut down and restarted and at the calibration screen tapped the center of cross many many times cross...
OK..your touch screen was jammed or not working and you did reset via code *2767*3855# then the phone restarted with the calibration cross....you tapped the cross but nothing is happening.......what to do? first shutdown the phone remove the battery for 30 sec also remove the simcard put the battery again start the phone when the calibration screen pops up tap on the cross here you must feel the tapping is working by feeling a light vibration of the phone.....then tap on the lower bar of the screen which has color (light gray) different than the calibration screen the cross will move to another corner......repeat this for all four corners then you should see and OK on the bar to save and exit to the normal screen........done
Jan 03, 2011 | Samsung SGH-A877 Impression Cell Phone
Hx2415 stuck on align screen
i think you have a problem with you touch screen digitizer. you can send your device to a repair center to replace the TP only, without the need od replacing the entire LCM display panel.
A touch panel withou the lCD should cost much less than an LCD.
Jul 30, 2009 | HP iPAQ HX2490 Pocket PC
The touch screen does not appear to be working
needs to be replaced , if it does not respond to ur taps have u tried aligning the screen does it work at all or no area is responsive on screen then u can try hard resetting it first but after that it will be guaranteed that ur touch panel is faulty which seems like to me
but one thing u shud now do all data will be lost in factory reset process and if ur touch panel is faulty u will stuck up in initial aligning process so pls backup first b4 going ahead sync contacts and sms calender an stuff then try this
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if u are stuck at align process then it is now pretty sure that ur TOUCH PANEL / also called DIGITIZER is faulty u can get it replaced around 60 $ or so
pls rate me fixya for my diagnosis if u like
Mar 05, 2009 | HTC Touch P3450 Smartphone
Hi, I am using HTC P3450, My phone is hang on After giving hard reset on Aligh Screen
try aligning the screen with a pointed object and on the cross hairs of plus sign firmly dont damage the lcd by hard impact
if can get past to it its ok and if not
ur Digitizer is faulty the upper cover beneath which lcd is assembled is faulty, it is separate from LCD screen and costs around 60 to 70 $ if u are covered in warranty
3 option u can google for a software to bypass the screen alignment process u can use ur pda but the alignment will be wrong and it will not respond where u touch the screen if u can live with that but its free !!!
Jan 26, 2009 | HTC Touch P3450 Smartphone
Screen problam
Have you aligned the screen?Go to settings,click screen folder and tap align screen.
Sep 03, 2008 | i-mate JAM Pocket PC
Touch screen not responding.
Is there anything on the screen?
try to perform a cold reset by plugging the battery out
Jul 22, 2008 | HTC Touch P3450 Smartphone
Touch screen & key board with stick does not respond
try aligning the screen...
settings > screen > general > Align Screen
If that doesn't work try hard reset... i.e.
press the two soft keys and the reset button using stylus...
If its still not working do soft reset:
settings > system > Clear storage
but remember to take back up of phone before doing this..as it will erase all your data...
and do tell me if it worked or not...
Jun 25, 2008 | HTC P3300 Smartphone
Any chance you are using screen protectors and that the edge may have shifted under the case? If yes you have what I call a wedgie and it's causing a phantom tap in a non-accessible area. Remove screen protector.
Any chance there is some dirt/detritus wedged just under the edge of the case pressing on the digitizer? Fold the corner of a piece of copier paper to form a scoop and go around the perimeter of the screen no more than 2.5mm under the case to dislodge (not push in) anything stuck there. This method solved this same problem on my HTC phone
Nov 04, 2007 | Computers & Internet
O2 Xda IIi Smartphone Logo
420 people viewed this question
Top O2 Computers & Internet Experts
xxxxxx xxx
Sheldon Dedek
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
