Question about Bulova Watch
I dont know how to set time
I have got a 70's Bulova Electric watch the crown does not pull out to alter the time how can i do this please serial number is 7018-23839.
    Problem Solver:
  • 11 Answers
Some 70s quartz watches used quite a different system where you push the crown in, hold for a while (perhaps 5-10 sec) then release it and push and hold it back in again immediately. At this point, the ends should set off advancing at many time their normal rate so you can alter the time.
Complex, I know.
Posted on Feb 16, 2009
How to set up second hand and chrono minutes for bulova 98B105 back to zero setting?
If you haven't got the user instructions you can get them via the following link:-http://www.bulova.com/watches/bulova/marine-star/98b105/
You should see "download user manual" at the bottom of the page.
Mar 31, 2011 | Bulova Marine Star Calendar #98B105 Watch...
SETTING DATE&TIME
i cant get a manual for this but watches have standard mechanical function so maybe this will do.
the center crown of the watch right side of the picture, loosen the crown. Be careful, some crown have a screw function so if your bulova has this don't force to pull it to prevent damage. if you have loosen the crown, check if can be turn it, if yes pull gently the crown, first pull date adjust,second pull time adjust.
This is the proper way to adjust you day and time.
say you want to adjust your watch to (date)10th (time)10:15am
adjust your date to 9th, then move your watch hands clockwise until the date change at 12oclock this is the evening time (PM) continue moving your watch hands until you reach 10:15am.
if your crown is a screw time remember to turn it close tightly for waterproofing.
Dec 13, 2010 | Accutron BULOVA men's 26B62
I'm tryng to set the date without changing the day and time. I've tried to just pull the pin out half way but its not working. How do I do this? My watch has three dials on the face - 1)date, 2) day and 3)...
mcdevito75 here, It takes practice, the crown does have 2 positions, slip a fingernail just under the crown and lift to it"s first position this will allow you to change the DATE (number) once you get the correct Date, push tje crown back in, NOW! pull the crown out to set the DAY itself and the time. On some watches the crowns first position allows both the day and date to be changed by turning the crown in it"s first position clock wise and counter clock wise.
Jul 04, 2010 | Bulova Watch
GB743 CHANGE DATE
mcdevito75 here, Your Bulova watch should have a 2 position crown (winder), carefully lift the crown to it"s first position, this should allow you to change the DAY, once done pull crown out to set the time, keep turning the hans till you get the right DATE (number) now set the correct time and your done.
Jul 01, 2010 | Bulova Watch
Vextra men's watch
pull crown out once this allows you to set one of the functions by turning crown in one particular direction ..then pull out further to set next function by turning crown in one particular direction then push cronw all the way back to case side..if crown is of the screw down type you will have to unscrew it anti clockwise first then pull it out one click remember to screw it back when you finish
Mar 26, 2010 | Bulova Watch
How do i set time back and have watch work again
This model has a pull out crown (the middle "button") on the side of your watch. Simply pull the crown out and turn to set the time. If your watch is not working after this then it likely needs a battery change.
Nov 03, 2009 | Bulova 96R19 Wrist Watch
How to set time, date, and alarm
there should be a manuel online that is downloadable from Bulova. This is the best way to find out how to set it short of taking it to a jeweler.
Generally, with the crown pulled out in different positions the push buttons will change the position of your subdial hands.
Oct 17, 2009 | Bulova Watch
I cant adjust the minite hand backwards if the watch is gaining
Unfortunately your watch do not have reverse action, so, you have to go all the way forwards till you reach designated time again.
One more way how to set the right time is to disconnect the battery and wait till the real time reaches the hands of your watch, then put battery back and set again. If watch has a STOP function (crown pulled out), then you don't have to disconnect the battery- just pull out crown and wait.
By the way: pushing the button in accelerates minute hand constantly, but if you'll push the button rapidly, it will move mimnute hand bit by bit. Use this feature to set desired time more precisely.
Do not forget to rate, please.
Jan 14, 2009 | Bulova Watch
Rolex oyster perpetual datejust time/date setting instructions
Unscrew the crown pull out the crown to the first position, One click and rotate the crown clockwise. This is for Quick Set models
For non quickset
Dec 30, 2008 | Bulova Watch
Remove stem on accutron 76 to replace face number
The video i want to see you,is using older kind of watch,screwing before he can pull the crown ,the new model watches now is pushing, while pushing you pull the crown .That's why ill tell in advance so you aware.I know because i'm a watch technician working in rolex before...
remove the crown
if i helped,please,click FOR RATING .It is the only way i get paid for my works also,please consider leaving feedback..
Jul 26, 2008 | Bulova Watches
Bulova Watch Logo
114 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
