Question about Sony KP-46WT510 46" Rear Projection HDTV
Color convergence chip
I have a convergence problem it is dipping at the top of the screen. All colors are visible was told it needs the color convergence chip replaced..do you know the part # and where I can order one..Also need a service manuel and sony remote to reset after repair..Can't pay a mint in labor cost. Would appreciate any info you can provide...
  • 5 more comments
  • Tanya LeVasseur Aug 01, 2007
    techman your awesome thanks a bunch
  • Tanya LeVasseur Aug 02, 2007
    does sanyo and sony interchange because the part numbers and site is for sanyo my tv is a sony KP-46WT510
  • Tanya LeVasseur Aug 16, 2007
    I got my ic's they said nothing but the stk #392-560 even though I ordered them as sanyo..Do you by chance know the original part # for sony ic's for the color convergence.
    Shortness
  • Tanya LeVasseur Aug 17, 2007
    Thanks again techman I did go back into the sight and went off. It would have been worse if I had to end up paying to have them replaced in a few months..We will see if they live up to any of it ....I really don't see it happening but hopefully noone else will end up a victim to this nonsense...
    just one last note. Something good did come out of my search for everything. If anyone one needs an original remote there is mr.remote on ebay you can buy from store instead of bidding they are the most reasonable I found mine for around 23.99 with free shipping real good service. NEW remotes everyone else wanted from 50 to 71 dollars with shipping. Good luck all
  • Tanya LeVasseur Aug 18, 2007
    Sorry all. The remote store is awesome remotes not mr.remote. It has been a draining day. Sorry again
  • nnicole Aug 06, 2008
    Same as "shortness". Need new chip and what cost is for same? Thanks.
    President:
  • 3,130 Answers
The system will not let me post to a link, I wrote: OK first off, as you stated, you will for sure need an original replacement remote for this TV set to make any types of alignments. You may also have a friend relative or maybe a neighbor who may have a remote you could borrow. If not, there is one available here http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=KP46WT510&brand_pn=SONY_KP46WT510&mode=large&uid=11859736726080 Now the convergence IC's, there are two of them that will need to be replaced, the number is STK392-560 You can get the original Sanyo IC's from HERE http://www.mcminone.com/search.asp?keyword=STK392-560&btnSubmit.x=10&btnSubmit.y=8 You will also need to get some heat sink compound and apply to the backs of the new IC's before you install them. Now after all is said and done, before you plug in the set, take a multimeter and check resistors R 8122,and resistor R8127. These two resistors supply the voltage to the IC's. They are 7.5 ohm resistors. The R8122 carries the negative 22 volts and the R8127 brings the positive voltage to the IC's. Next, check the circuit protectors around the IC's also. They are PS8001,8002,8003,8004,8005 and PS8006 and make sure these are not open. These circuit protectors are nothing more then 3.2 amp fuses. I do not have the KP46WT510 service manual, so you will have to go to servicemanuals.net Good Luck
Posted on Aug 01, 2007
  • 3 more comments
  • Larry  Dillon
    Larry Dillon Aug 02, 2007
    The convergence IC parts used in the Sony is made by Sanyo. There are replacement type STK iC's but like I said these are aftermarket IC's You need the IC's that have Sanyo on them. You will be on the same river without a paddle several months down the road.
  • Larry  Dillon
    Larry Dillon Aug 16, 2007
    If you purchased them from MCM, they are getting as bad as the other parts houses and ripping off the public. Their web site says they are the original Sanyo IC's. But without Sanyo on them, they are cheap after market types of IC's. Go back and tell them they are using false advertising.
  • Larry  Dillon
    i guess if that is all you can get, use them, but just be sure to use a lot of heat sink compound on the backs of the new IC's before installing them.
  • Larry  Dillon
    Larry Dillon Aug 17, 2007
    Not a problem my friend, Good Luck
  • Larry  Dillon
    WoW! Thanks for the tip!
Hitachi 46F500 and there is a blue curved bar
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
May 15, 2009 | Hitachi 46F500 46" Rear Projection...
Sreen pulled in on top and bottom
  • Screen looks 3D
2c07611.pngSolution
May 15, 2009 | Sony KP-61HS10 61" Rear Projection...
Green color seperation multiple images convergence will not fix
Your TV most likely a convergence failure. ( common problem )
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
May 14, 2009 | JVC AV-48WP74 48" Rear Projection...
Off colors in picture
  • Screen looks 3D
My Philips 51PW9363 looks like someone is pinching the screen in the middle from the top and bottom. No color, sound or other problems that I've noticed.
  • Screen looks 3D
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Apr 22, 2009 | Philips 51PW9363 51" Rear Projection...
SPEED BUMP OR BOWING
Your convergence chips and convergence resistors are going bad. When they fail the screen colors will look distorted/3d looking. Another symptom is one or more colors can't be converged using the convergence menu. You can purchase the parts over the internet. Just make sure you get Sanyo brand convergence chips and the correct flame proof resistors. You can also check the site www.TvRepairKits.com for a kits.  Just make sure you replace both of the convergence chips and all of the convergence resistors.
Aug 25, 2008 | Philips 60PP9202 60" Rear Projection...
Hitachi 50ux26b/27k with AP63 chassie convergence problem
It looks like the STK chips need to be replace for fix the distorted colors.
You can download the service manual from here: http://www.eserviceinfo.com/downloadsm/11792/Hitachi_60SX12B.html
Feb 05, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Arch on top and bottom of screen
I read that these sets have a problem with the yokes on tubes sliding down some- there for causing this problem make sure yokes are all the way up on neck of picture tubes,this may fix your problem!
Dec 27, 2007 | Philips 55PW9363 55" Rear Projection...
PT-53WX52
  • Screen looks 3D
Dec 02, 2007 | Panasonic PT-53WX52 53" Rear Projection...
Warped Picture, Separated colors
Each color (red,green & blue) has an amplifier IC (STK-).
When there is a convergence issue,the first step is change both
IC's for reliability. Then check for open fuses devices,usually
pico fuses.Then re-check convergence alignment.......T.
Feb 07, 2007 | Philips 60PP9352 60" Rear Projection...
Sony KP-46WT510 46" Rear Projection HDTV Logo
828 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
