Question about HP Pavilion dv7-1130us laptop
Laptop will not power up at all from mains or battery power.
Background........
Hi, I have a HP Pavillion dv7 laptop, 4 months old from new. It has worked perfectly since I purchased it. Lastnight, in tired mode, I went to insert my camera memory card into the laptop card reader port, but before I realised, it was too late and the card was too small and disappeared into the opening. I tried to retrieve it but it would not come out as it wedged itself.
Problem.......
I then removed the bottom access panet, (like a T shape), but could not get to the card still. so I went a little further, removed the hard drive, and around 8 screws hoping to remove the bottom cover completely to allow access. I soon realised the I was not going to work and did not proceed any farther, I replaced the Hard drive, screws and the access panel and lastly put the battery back, now the laptop refuses to power up at all. I have since managed to retrieve the card form the same way it went in.
There is no reason that I can see that has caused to machine to go into total shut down, I was very careful not to touch or disturb any components except as I say the hard drive. hope you can help.
Thank you for listening and your kind assistance on this matter.
  • 3 more comments
  • Anonymous Feb 02, 2009
    Thanks for all the replies, its much appreciated for you taking the time to assist me.
    Update.....
    I plugged in the mains and it powered the laptop, all seemed well, it stayed on for 5 mins then the screen went blank, all the neon lights remained lit. The power button would not shut down the laptop, so I unplugged, and on trying to restart it, it fired up for 5 seconds then turned itself off and kept repeating this each time, it did finally turn on and stay on but the screen remained blank, again just the neon lights on. I know this has now become a far more complex problem and difficult to diagnose blindly.
  • katiedid25 Feb 23, 2009
    i have a gate way, that will now power up, I have tried disconnecting the battery and the main power cord, i held the power button down for 30+ sec then plugged the mail power cord back in nothing no light ect, I did the same thing only i plugged in just the battery and still nothing no power. can some one give me other suggestions
    Kimmer
  • Anonymous Mar 19, 2009
    cannot power up with or without power cord plugged in, all black no lights at all, have checked battery, power light is on around insert point but can't power up at all.
  • Ryan Stiers
    Ryan Stiers May 11, 2010
    Do you have an A/C adapter? If you do, plug that in to guarantee you have power going to the Laptop in case there is something wrong with the battery. If it still doesn't power on, you may need to call HP and have it sent in for service (which would be good to call them now since you are within the 1 year warranty period. Out of warranty service with HP costs around $400)
    If you do call HP, Do Not tell them you opened the case up, no matter how little you did while it was open. They may tell you by opening it up on your own without one of their phone technicians telling you to do so may void the warranty. Follow their troubleshooting steps and if it doesn't work after what they suggest you try, they will send you a Fed Ex Box with postage paid to send the Laptop into one of their service centres to get repaired or replaced.
  • Amardeep46
    Amardeep46 May 11, 2010
    Did you check if the battery is fit in properly ? It might have disconnected when you tried to remove the back cover of the laptop.
    Guru:
  • HP Master
  • 829 Answers
Hi Can u be more specific.
Posted on Feb 01, 2009
Laptop sometimes switches off when moved.
Sounds like a loose connection where the laptop opens and closes hinge there are wires that run from the main screen to the main board. If you know how to take the unit apart it maybe a cheap fix if not then a new laptop maybe the way to go the prices have really dropped from 4 years ago
Jan 12, 2013 | HP Hewlett Packard Compaq 6720s Laptop...
Hp battery saying i may consider changing the battery
Insufficient info is provided here. How old is the battery, and how long does it last now. If it is old and runs down easily, then it needs changing. If it is less than 8 months and still runs down fast, then its having issues with ur main power supply. Purchace a new battery and ALWAYS USE IT WITH A SURGE PROTECTOR. Hope this helps?
Mar 16, 2011 | HEWLETT-PACKARD Hewlett Packard HP...
My battery always stays charged, so why is my laptop telling me that i need to replace my battery?
Hi,the reason why your laptop is telling you to replace Battery is,you have killed your battery without knowing by Charging it always,since you have constant power supply,you should at least after getting a new Battery,discharge it four to five times a week longer life of battery,by these i mean,unplug cord from mains let power drain to 5% or 10% before charging again while working and if fully charged and you are not making use of it disconnect and if you want to make use of it use battery instead do not connect immediately to mains until power drains from battery.Just like your mobile phone,you only charge it when need be(ie. when Battery is Low).
Jan 01, 2011 | HP Pavilion DV7-1020US Laptop
My dv7 1245 dx had a short at the ac110 adaptor plug on the 18.5 volt end. This shut my computer down. Twisted wires. I bought a new HP adaptor. The computer will not power up now. The only sigh of life...
Dear Sir/Madam...
You just follow these steps:
1.Remove the battery and Adaptor
2.Press and Hold the On buttun for 30 seconds (without battery/adaptor,this is for reset the BIOS in your Laptop)
3.Now you just connect the adaptor with your laptop
4.On the adaptor socket main switch in main board
5.Watch the Laptop charging Light is ok or not.Also watch the Light in Adaptor is lighting normally or not.if all are normal then try 6th step otherwise problem in your Laptop.Just go for an authorised service center.
6.Try to ON the Laptop
All the Best....
thank you very much By Ganesh(INDIA)
6.
Dec 04, 2010 | HP Pavilion dv7-1245dx Notebook
Battery specification for HP pavillion dv7 17" pc
Sounds like you are having a battery problem. Go to HP.com and put your model number in. HP is having a battery recall for thousands of their computers. You may be able to have HP send you a new battery for free.
Oct 29, 2010 | HP Pavilion dv7-1130us laptop
My hp pavillion dv7 1130us laptop will not turn on at all was working fine then stopes charging and then when batery went dead that was it I have no power at all now with or without the batery in
press and hold the Power button for 60 secs without the battery and power cable and then reconnect to it back and try to restart and if nb turns on then log on to www.hp.com and download the latest bios and install it as Administrator.
Aug 06, 2010 | HP Pavilion dv7-1130us laptop
Hi, HP pavillion dv7 laptop. Went into hibernate mode but will not wake. Pressing power button does nothing. Hold power button for 5 to 10 sec does nothing. Plugging in power cord is not registered by...
are you running vista? this is an ongoing issue with that operating system. my best advise would be to totally disable hibernate and sleep on your computer by changing the power settings.
  1. right click on your desktop
  2. click personalize
  3. go to screen saver
  4. on the lower part, you should have change power settings there
  5. play around with it and disable hibernate and sleep
hope it helps.
Mar 14, 2010 | Computers & Internet
HP pavillion dv1000 won't charge
Try using your laptop without the battery and just using your power supply (new universal or your old one).
If your laptop works on just mains power it means your battery is causing the problem, which is not unusual.
Aug 07, 2008 | HP Pavilion dv1000 Notebook
Hp Pavillion dv6000
Hi
It is indicating battery low. Power is not passing to laptop check power card or adopter....
Thanks
Jul 10, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv7-1130us laptop Logo
414 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
