Question about Ranger VR-9000 Base CB Radio
Freq counter starts rolling backwards to 24mhz and locksup entire
Functions on radio....turn off for a20mins or so and turn back on to normal operation
  • 55 Answers
SOUNDS LIKE A COLD SOLDER JOINT OR A BAD COMPONNET WHEN IT WARMS UP THATS WHEN IT STARTS ..TAKE OFF THE COVER SO THAT YOU CAN SEE THE SOLDER SIDE OF THE BOARD PUT POWER TO THE RADIO AND WHEN IT WARMS UP AND SHUTS DOWN TAKE A LITTLE PIECE OF WOOD OR PLASTIC AND PROBE ALL THE SOLDER CONNECTIONS TO CHECK FOR A COLD SOLDER JOINT IT MAY BE GRAY IN COLOR MAY NOT.. SEE IF IT GOES ON AND OFF.. IF SO RESOLDER THAT SOLDER JOINT.......IF THIS DOES NOT WORK ....PICK UP SOME FREEZE SPRAY AND SPRAY IT ON THE COMPONNETS ON THE OUTHER SIDE OF THE BOARD THIS IS WHAT A SERVICE PLACE WILL DO IF THAT DOES NOT WORK NOW BRING IT TO A SERVICE AND LET THEM SCRATCH THERE HEAD GOOD LUCK
Posted on Feb 21, 2009
Galaxy 959 Testing TP3 for AM, LSB, USB with FC-347 or what other freq. counter can be used for this?
An external freq counter will always do a better test then the one on the unit . Do you have an oscilloscope? A function generator will also have a freq counter . Now the ultimate is a spectrum analyzer. you don't need all these but the function generator will work fine.
Jun 23, 2012 | Galaxy Radios DX-959 40-Channels Base CB...
Dx-959 freq counter an channel selector don"t
Hello, please tell me what you were doing before and at the time of change. Were the digit lights recently switched? Please give me a little more information so I can be more specific in my answer. Thank you.
Mar 01, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
The freq counter stays lit at 10.625mnz the claifier knob or the channel selecter will not change the freq counter
This problem, really need to be on a bench to test.. FREE at any good cb shop, to tell you what is wrong.... But most times when a freq counter is not working. Either the crystal is bad, poorly soldered, or its not receiving an input signal. Best way to test is to have a second freq counter external inline using coax.. and check the output of the radio and see if it shows correct or wrong. If it is showing correct they you internal freq counter is messed up. and needs to be check for a bad crystal or solder joints. sometimes even the voltage regulators go bad.. If it is showing a wrong freq on external counter then check the radio's crystal and oscillator circuit. this too can be as simple as a cold solder joint. on the solder side check the small surface mount diode near the PLL, next to the PLL shielded covers. It is normally black these come loose often times too. If you need more help feel free to call or text for more help.
Jan 28, 2011 | Galaxy Radios DX-66V Base CB Radio
Hi my deltaforce is slightly off on ssb you have to be on 27554 and clarifier at 12 30 to be spot on 27555 thanks vince
Use a known good external freq counter, and do the tx alignment. that will put your meter back on showing the right freq when you are..
Jan 27, 2011 | Magnum DeltaForce CB Radio
Band selection an freq. doesnt align galaxy 33hml
sounds to me someone was tampering with it ,your best bet is to get a frequency counter and realine the radio .start from 27.185 centre band you can do this by tuning the ossolator be very careful not to damage this should realine the radio for you goodluck
Oct 16, 2009 | Galaxy Radios DX-33HML 40-Channels Base CB...
Rolling Frequency Counter
I'm giving this info from the Master Edition of C.B. Tune-up manual Volume 1 year -1995. The original price of this info was $39.95 But I have had people help me with radio info. so here it is---- on page 60 it says [ Model ] : Galaxy Saturn ( and export models using the same Freq. counter module ) The most common problem with the { Galaxy Saturn } is after it has been on for awhile the read-out becomes unstable. And sometimes it will quit all together. This problem has been traced to a Zener Diode inside the freq, counter module. The square silver box located right behind the speaker. The Zener Diode inside marked D-603. This is a 2.4 volt , 1/4 watt diode next to IC-609 the ( LM-7808 ) regulator. REMEDY: change D-603 to a ( 2.4 volt , 1/2 watt diode) This should restore normal operation. {{{{ 357 - MAVERICK }}}
Mar 13, 2009 | Galaxy Radios DX-2517 CB Radio
Not a Galaxy DX-2517
its a mexican kraco clone,lol
Aug 09, 2008 | Galaxy Radios DX-2517 CB Radio
Connex 3300 hp
U mean on sideband? Frequency counter only useful on other than sideband operation. This does not mean the carrier insertion osc. is on frequency. If it needs adjustment, your voice will sound high/ low on transmit. Incoming signals will sound right after adjusting the osc.
May 14, 2008 | Connex 3300 240-Channels Base CB Radio
Ranger VR-9000 Base CB Radio Logo
71 people viewed this question
Top Ranger Radio Communications Experts
AnyMHz.com
AnyMHz.com
Jon Piercy
Mike Charette
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
