Bearing noise on Indesit WDG1295
Is changing the drum bearings on an Indesit 1295 a DIY job? Have done wheel bearings on motor bikes and Minis in the past. Thanks
    Sniper:
  • 100 Answers
You will have to open the machine lid to see if its a plastic drum or metal.
the metal drum is easier as it has a 'spider asssembly'. remove this after taking off the pulley by taking out the bolts that hold it and bang it off being carefull of the heater element. remove the bearings and seal and refit in reverse order you took it off.
i would not advise replacing plastic drum bearings as they are a pain, removal of the rear of a plastic drum easy but not putting it back !
Posted on Feb 01, 2009
Kenmore 86582800 drum has a high pitched squeak after been on for 5minutes. 1983 model
see this steps and fix it. God bless you
Drive Belt
If the dryer makes noise, the belt may be frayed or damaged. If the belt is damaged, it will make noise every time it travels around the pulleys. The drive belt is a long, narrow band that wraps around the entire drum, then around a tension pulley and the motor pulley.
er
Drum Roller
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers. If one is worn out replace all of them at the same time as a preventative measure.
Drum Roller Axle
Over time the drum roller axles can wear out, causing the rollers to wobble. If this happens the dryer makes noise. If the dryer is making a rumbling noise, check the rollers and axles. If any are worn out, replace them all at the same time.
Blower Wheel
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
Drum Bearing
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
Drum Support Roller & Axle
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers or axles may be worn out. After removing the drum from the dryer, inspect the rollers and axles. If one is worn out replace all of them at the same time as a preventative measure.
Drum Support Bearing
The drum support bearing is at the rear of the drum. If the dryer makes noise check this bearing. If it is worn out, replace the entire bearing.
Drum Slide, Glide, or Pad
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
Drive Motor
Although not very common, if the dryer makes noise the drive motor may be worn out and the motor bearings can become noisy. If this happens the drive motor must be replaced. The bearings are permanently sealed and cannot be lubricated.
Jul 13, 2013 | Dryers
I have a Zanussi ZWX1506W washing machine and have a problem used it yesterday and after about 10mins i could smell a burning smell so turned it off and unloaded it/ drained it etc left it go an hour or so...
There is a tiny possibility that the motor has seized. To test this possibility, remove the top of the machine and take the drive belt off. If the drum now spins easily but you can't turn the motor spindle by hand then the motor has siezed, if the drum is still stiff but you can turn the spindle of the motor by hand then the drum is siezed. A replacenemt motor will probably set you back around £100 ($170) this may make the machine a write off. Worst still, and I'm sorry to say, far more likely is that the main bearings in the drum have broken down and siezed. The smell is from the motor buring out as it tries, and fails to turn the siezed drum (or siezed motor bearings).
Under normal circumstances, to test your bearings, open the door of the machine and by putting a little lifting pressure on the top of the inner drum, attempt to rock the stainless steel inner drum up and down.
The outer drum is mounted on springs and shock absorbers, so it will rock about (and it should do this) but the inner drum should not move up and down in relation to the outer drum. There should be ABSOLUTELY NO PLAY between the 2 drums, even the tiniest amount will mean the bearings have failed. Having said this, if your bearings have siezed, there may be no play in the drum because they are jammed solid.
If the bearings have siezed, then other symptoms that have been leading up to the failure will typically include:
A clonking noise as you lift and release the inner drum (this is the inner drum rattling on its bearings and/or hitting the outer drum), but as I say, with siezed bearings, this may not be the case.
You will have become aware of the spin cycle becoming far noisier recently and possibly even a grinding crunching noise when the machine spins.
When you turn the stiff drum by hand, it may not only be stiff, but you may be aware of a grinding crunching noise that you can also feel transmitting through the drum as you turn it at the same time (the broken bearing catching up on smashed bits as you turn the drum)
A leak from under the machine, which you will probably be able to trace to the back of the machine, coming from the centre of the drum. This is a result of the failing bearing allowing water to escape through the seal at the rear.
If it is the main bearing (and I can't imagine any other cause other than the motor its self seizing) then this is NOT a job for the uninitiated DIY enthusiast as it will mean stripping the machine and removing the drum from the chassis, splitting it, removing pressed in bearings and then sourcing and re-fitting new bearings.
To be frank, the cost of a bearing set (if they are replaceable, and most are) will be about £20 ($30) or so. But it's a long and horrible job if you haven't done it before. I know professionals who claim they can do a bearing change in under an hour, I've done a few and it takes me about 2 hours by the time I
Aug 30, 2011 | Zanussi Washing Machines
How difficult is it to change drum bearing on my indesit wg1130tg washing matchine
Personally, my view is that this is NOT a job for the uninitiated DIY enthusiast as it will mean stripping the machine and removing the drum from the chassis, splitting it, removing pressed in bearings and then sourcing and re-fitting new bearings.
To be frank, the cost of a bearing set (if they are replaceable, and most are) will be about £20 ($30) or so. But it's a long and horrible job if you haven't done it before. I know professionals who claim they can do a bearing change in under an hour, I've done a quite a few and it takes me about 2 hours by the time I've ripped the machine apart and reassembled it after the bearing swap. A local repairer will probably attend and swap out your defective drum for a refurbished one and then take yours away so he can refurbish it and put it back in his stock. Sadly, this will take the price up to the point where you need to question if the expense is worth it or do you get a new machine instead.
I'm not saying that you couldn't do it if you had the will and the practical temprement, but I would certainly approach the idea of starting the job with a degree of scepticism.
Jul 19, 2011 | Indesit Washing Machines
Kenmore elite heavy duty king-size capacity model 110.2302: tub spins, but makes a loud banging noise as if the load is off-balance, even when there is no load
I'm sorry to say, this almost certainly means that the main bearings on the drum have failed. This is NOT a job for the uninitiated DIY enthusiast as it will mean stripping the machine and removing the drum from the chassis, splitting it, removing pressed in bearings and then sourcing and re-fitting new bearings.
To be frank, the cost of a bearing set (if they are replaceable , and most are) will be about £20 (($30) or so. But its a long and horrible job if you haven't done it before. I know professionals who claim they can do a bearing change in under an hour, I've done a few and it takes me about 2 hours by the time I
Jul 05, 2011 | Washing Machines
Hotpoint wma46 drum bearing failed
The drum sits on a shaft, just like the front wheel on a car. There are 2 bearings, one each side of the drum housing. Usually the inner bearing water seal fails and the bearings begin to rust, causing it to become noisy. Once the water is that far, its not long until the outer bearing goes. At some time in the process, you will begin to get a water leak from the rear of the drum that will get progressively worse.
You can change the bearings and I work with professionals who claim that they can have a drum out, bearings swapped and back in within 45 minutes. I've never got it down below an hour and a half on a machine I know well and you will need, if not SPECIAL tools, then a tool of some description to knock out the old bearings that are pressed into the drum. This is a job for the hardened DIY enthusiast and a pig of a job if you've never done it before.
Bearing sets cost (depending on the machine, the supplier and how many you buy) around £25 in the UK (About $40). Calling out a guy to do the job will easily quadruple that cost (He will probably come with a refurbished drum, swap it out and then take yours away to refurbish).
With this information, you now have to ask yourself if it's worth the effort on a machine that may be reaching end of life anyway.
Typically, the noise will get SCARY and the water leak annoying long before the machine actually fails to work. My advice would be take this as notice that your machine is about to go to the scrap yard in the sky and start looking for a replacement before it croaks on you at an inappropriate moment.
Jun 21, 2011 | Hotpoint WMA46 Front Load Washer
Washer all works fine, but machine is over 5 years old. the spin cycle getting louder. no screaching, no hi-pitch, just a louder than normal spin. goes thru cycles properly, but too loud. is there any...
I'm afraid so. This is classic main bearing wear. The drum sits on a shaft, just like the front wheel on a car. There are 2 bearings, one each side of the drum housing. Usually the inner bearing water seal fails and the bearings begin to rust, causing it to become noisy. Once the water is that far, its not long until the outer bearing goes. At some time in the process, you will begin to get a water leak from the rear of the drum tht will get progressively worse.
May 27, 2011 | Washing Machines
The rear wheel bearings on my 1998 Honda Civic Aerodeck are rumbling and I need to know how to replace them or regrease and is it a DIY or garage job
Your vehicle is equipped with sealed bearings that are pressed into the hub assembly. If your rear wheel bearings are making noise, you must replace the entire bearing and hub assembly (they cannot be greased).
To replace it, raise and support the vehicle and remove the tire and wheel assembly. Remove the brake drum. Remove the bearing cap, the spring nut and the axle washer. Remove the hub assembly and hub seal. The new hub assembly should come with a new hub seal installed. (See first picture below)
TIP: The brake drum has threaded holes in its face where an 8mm bolt can be inserted to help "push" the drum off of the hub assembly - they can get really stuck. (See second picture below)
May 22, 2011 | Honda Civic Cars & Trucks
Passenger rear wheel bearng needs to be replaced.does this require special tools? I've just had a complete brake job ,new pads new rotors new drums and I have a recurring grinding noise coming from the...
You can do this job your self with common tools. Auto zone carries the wheel bearing you need and can give you the step by step instructions to replacing the bearing. Here is a tip, to try to break the old wheel bearing from the axle. Just loosen the 4 bolts 3 mm that hold the bearing to the axle and put the wheel back on and drive the car back and forth a few times, hard on the brakes to break it free from the axle. Once the bearing breaks free from the axle, it should take you under 45 min to get the job done. Good luck and be safe.
Nov 17, 2009 | 2001 Toyota Corolla
Whirlpool dryer drum making noise
window.google_render_ad();There are many places & parts that could be causing your Whirlpool dryer to be noisy. To find out what is causing the noises, you need to find out where are the noises coming from.
Start the dryer and let it run for a while and listen to try to pinpoint where in the dryer the noises is coming from. Once you have an idea of the area, you will need to disconnect the dryer from the wall outlet and take the dryer apart.
Below you will find the parts that you need to check when your dryer is noisy.
The drum baffles:
The drum baffles are use to tumble the clothes inside of the drum, in other words, the baffles job is to separate the pieces of laundry as the drum turns.
When the dryer is getting older and if you use the dryer a lot, the drum baffles holding screws will become loose. Loose drum baffles will cause noises. All you need to do, is to open the top panel and tighten the drum baffles holding screws.
The drum support rollers:
These dryers uses four drum support rollers, tow on the front and two on the rear. The job of the drum support rollers is to keep the drum tumbling smooth.
When the grease on one of the rollers dry out, the roller start to make squeaking noises and the roller bearing will start to wear out until the bearing on the roller is gone. When the bearing on the roller is gone, the noise will change from squeaking to a clanking noise.
The blower wheel:
The blower wheel is use to circulate the air inside of the dryer drum. The most common Whirlpool blower noises are cause by something falling inside of the blower housing and hitting the blower when the motor runs.
The Idler pulley:
The Idler pulley is use to apply the necessary tension on the belt. There are two types of idler pulleys, the pulley with the wheel and the pulley with the teflon slide. A bad idler pulley could cause a Whirlpool dryer to be noisy.
The drive motor:
Worn out bearings on the motor will cause the motor to run kind of noisy. When the motor starts making noises, the solution to this problem is to replace the motor.
The belt:
The belt on most dryers is only about1/4 inch wide. These belts work very hard making the drum tumble. When the belt stretch just 1/2 inch more that it supposed to, the belt will start slipping and that could cause your Whirlpool dryer to be noisy.
As you could see, there are a lot of parts that could become noisy in your dryer. When your dryer starts making noises, make sure to check it out before it gets worse.
Feb 09, 2009 | Whirlpool LER4634J Electric Dryer
Indesit wash machine drum bearing
depends on the model that you have some indesit machines you only have to undo the spider and others can be a bit of a pain because you have got too split the drum would recomend an engineer regards jason
Jun 13, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
238 people viewed this question
Top Washing Machines Experts
