Question about Whirlpool ACQ158XP Wall/Window Air Conditioner
Thru wall/ Window ac units
Hey there was wondering if you knew where I could get my hands on a good Ac troubleshooting book or sumthing I work on apts and they have old ac units and newer ones the old ones date back to when they still used the brush coils instead of the fins so I would need a decent general book. We Have service techs comeout on ones that we cant figure out ourselves but would be nice to try and save on the budget. thanks in advance
  • 139 Answers
Try this ttech http://www.amazon.com/Using-MultiSIM-Troubleshooting-DC-AC/dp/1401852548
Posted on Aug 01, 2007
Clean window ac unit
What do you need to know about cleaning your wall unit? If you need any other assistance check us out online at Boca AC Service we are always happy to lend a helping hand.
May 28, 2016 | Frigidaire Heating & Cooling
All lights on but fan or nothing works also can't find reset button
Do you have an owner's manual that came with it? If so you should contact the manufacturer and find out what services are available. It is not something the amateur can fix since it is high voltage and solid state on a circuit board or two. Maybe there are error codes you can write down like the "19" may be,
Jan 01, 2013 | Heating & Cooling
I just bought a new frigidaireAC,and i'm wondering why it doesn't have a drainhole to drain water under neath the ac
If the unit is tilted ot theout side it will drain properly with out the hole . often units get set level andor to one side and the problems start. So just make certian that it is tilted to theoutside
Jul 23, 2011 | Frigidaire FRA052XT7 Thru-Wall/Window Air...
I have a window model and lost my user guide. I was wondering where the water empties?
There's a drain pan under the unit. I has a drain hole on the outside (outside the wall) part of the AC. If the unit is installed properly and has a 1/4" to 1/2" downward tilt on the outside, the water runs to the rear of the drain pan and drains out thru the drain hole. That's assuming the drain hole is not clogged.
Jul 19, 2011 | Haier Heating & Cooling
Water coming out of front of unit, thru vents leaking on floor
Darlene, if this is a window or thru the wall unit, the leaking is usually caused by two things:
1. The drain pan under the unit has a drain hole (in the rear outside part of the unit) that is clogged.
2. The AC unit is not tilted down at the rear 1/4" to 1/2", so that water will drain to the outside drain hole.
Be prudent when you look for the drain hole in the drain pan. As the clog can blend in with the drain hole, making it difficult to see.
Hope this helped you troubleshoot and solve the problem.
Jul 18, 2011 | Haier Heating & Cooling
Can a 12000 BTU thru the wall AC be installed as a
Yes... no problem... just need to use cardbord of something to seal off the open spaces around it...
heatman101
Jul 21, 2010 | Frigidaire FAH106N1 Wall/Window Air...
AF-S80MX Thru-Wall/Window Air Conditioner: What kind of refrigerant does this unit uses? ...
Most new window units are using R-22 or it's most common alternative R-410A - but you will need to check the 'data tag' on the AC to be sure. All AC units have a data tag (either metal or paper label) - somewhere on the AC - which gives you model number, size, voltage, and type of Refrigerant, as well as other info.
good luck!
May 08, 2010 | Sharp AF-S80MX Thru-Wall/Window Air...
Can I mount a Samsung AC unit thru wall rather then window?
as long as the vents are completlyeyt covered. and cove rit in winter
Mar 15, 2009 | Frigidaire FAC107P1A Wall/Window Air...
Thru the wall AC units(small)
If the Ac unit can not fit your window, you can put a wall unit, you don’t have to open the wall and mount a stable unit, you just need to buy a portable AC unit put on.
This way cost you not too much.
Jul 09, 2008 | Haier hwr10xc6 Air Conditioner
Troubleshooting
they are a simple ac unit to repair but if you have a model number I would try a appliance parts store or call GE and see if they have one
Jul 26, 2007 | GE AJCH10DCB Thru-Wall/Window Air...
Whirlpool ACQ158XP Wall/Window Air Conditioner Logo
136 people viewed this question
Top Whirlpool Heating & Cooling Experts
Bill Long
Norman Al-Anbar
Dennis Boxerman
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
