Question about Sharp AF-S80DX Air Conditioner
AF-S680MX When I turn it on Cool, there is a loud buzzing sound every 8-10 seconds which lowers the lights in the room, drains the power. The machine is new - we've only used it about 6 times.
  • 147 Answers
Hello,My friend your having a Problem with the Compressor Start up,Take it Back and Exchange it ttech
Posted on Aug 01, 2007
SOURCE:
I have a Hotpoint Aqualtis wash/dryer which stopped working with a 'F12' fault. Now when I turn the socket on I get an immediate really loud whir/buzz.
possibly the main drive belt has either snapped or jumped off the pulley and this allows you to turn easily by hand the whir/buzz sounds like system in coming into play but with no belt to drive nothing more happens, the front lower portion of the machine could be the water pump working overtime unable to drain ???
May 09, 2016 | Hotpoint Washing Machines
I have a samsung side by side fridge and it is an RS285LA. For awhile now it has been making this buzzing sound from what sounds like to be coming from the back. This buzz sound is kinda loud cause I...
its the relay for the ice maker.. they are loud if the don't have water going threw them, you may want to shut off your ice maker. lift the arm to the up position. that turns off the ice maker.. if'n i was of hel vote YES .. jay the pool pump repair guy in longwood fl
Jul 05, 2011 | Refrigerators
Loud buzzing sound when turned on. Water will not drain
Sounds like a drain pump problem. Best off to call a certified repair company such as Sears.
Oct 16, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Loud rumbling/buzzing for 10-15 seconds and then power goes off
Your Color Wheel needs to be replaced!
Call Mats Electronics for Parts and supplies
1-800-628-1118
Mar 17, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Amana side by side, buzzing, no fan in fridge.
that sound is the relay/overload. it is trying to start the compressor. the problem is either that relay or the compressor itself
Feb 05, 2010 | Refrigerators
Buzzing - will not spin or drain water
This noise is probably the pump trying to start but will most likely be obstructed.Drain the machine manually by lowering the drain hose into a bucket or bowl and then remove blockage.
Nov 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Nd error essage
nd= no drain. loud buzzing noise sounds like something stuck in pump assy.remove the door(2screws) adn other 2 screws oppisite side, and hte front panel comes off giving you acess to the drain pump, pull the hoses and look for the obstruction
Mar 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Does not drain & makes a loud buzzing sound(KENMORE 44042)
this sounds like something has gone into the pump, coins or whatever, the objects need to be removed, also check the hoses, remove the plug to work on any appliance the buzzing is the pump trying to work but unable to go round, start there and see how you go if i have helped rate me please
Sep 12, 2007 | Kenmore 44042 Front Load Washer
Sharp AF-S80DX Air Conditioner Logo
66 people viewed this question
Top Sharp Heating & Cooling Experts
Ekse
AJMAL KHAN
Pete Norton
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
