Question about GPX D1816 DVD Player
Disk region incorrect message pops up
This (disc region incorrect )message pops up when i try to play discs i've viewed in the past. some work some don't
  • bendiy Feb 24, 2009
    i just bought a dvd through amazon and when I press play on my DVD player, "wrong region" pops up. What gives? Other DVDs work.
It's not the dvd; it's your player. I'm answering my own question. I did a search and found a code that needs to be set into my dvd player. So do a google search asking "wrong region" and the name of your dvd player. Someone is sure to have hacked through the problem and is more than willing to tell you how to fix it. Worked for me! Why does this even happen?
Posted on Feb 24, 2009
Incorrect disc region code
Look at the region code of the DVD that plays on the vehicle DVD if it is the same of the others that do play it's not a region code issue. If the others are a different region to the DVD that plays or the disc says it is region free. Then you might have a problem with the region code settings on the machine. You can look up the model number of that player to see if you can change the region code.
Otherwise check out the player to see if it needs cleaning or is faulty.
Aug 14, 2016 | Televison & Video
Selective playing of DVD's on Sharp DVD Recorder
Given that the machine will read disks it has written itself but not play regular discs, I suspect the lens assembly is slightly out of alignment and needs adjusting. This is not normally something you can do at home unless you have the correct test gear. It will need to go to a repair shop. One thing you can try before that is to clean the lens. Buy a quality (Scotch 3M, Philips ) cleaning disc and try it. Could be it's only a speck of dust on the lens.....
Aug 01, 2007 | NAD C541 CD Player
I amin india and i bought a xbox 360. my xbox i can play pirated disc. However for some games i am getting the message disc code is incorrect for this region. what should i do to make those disc...
Your Xbox region code has to match the region code on the video games. Figure out your xbox's country of origin and then only buy games that come from that region. If you are trying to play pirated discs and getting that error message, than they obviously were not pirated correctly.
Apr 28, 2011 | Microsoft Xbox 360 Console
The disc's region is incorrect. what is mean by this????
Region codes is a built-in feature of the DVD system designed to control where discs are viewed and distributed. All DVD hardware and software is coded using one of six numbers ( DVDs Regions 0 , 7 and 8 are special cases - see below ). The U.S. and Canada use Region 1. Region 2 discs are used in the U.K. , Europe and Japan . While Australia and the Caribbean use Region 4. These codes determine where the discs can be played.
Your console must match the discs region code.
This is not the case so you wont be able to play with this game.
Hope it helped.
Nov 20, 2009 | Microsoft Xbox 360 Console
Solutions to incorrect disk error c105 & c104
Hello gjbrokke,
First make sure the disc is compatible with the dvd player (CD-R+ , or CD-R - )
Second make sure the region code of the dvd you burned is compatible with the dvd region settings on your dvd player.
One of those two are preventing the disc from playing in your sansui player.
May 19, 2009 | Sansui VRDVD4005 DVD Player/VCR
Unknown disk type
Press 'Disc Menu' and wait for 'no disc' to appear on the screen. Eject the tray by pressing the 'open / close' button on front of the recorder. Enter the following numbers very slowly on the remote control ' 0086000 ' Press ' OK ' button on your remote control. Close the tray by pressing ' open / close ' button on the front of the recorder. You can check this has worked by pressing ' 0009 OK ' on your remote after the tray has closed. A display will pop up on screen showing the Region as 0. This means you should be able to play discs from all Regions. If this doesn't work the first time! try again! Hope this helps!!
Jan 24, 2009 | Philips DVDR3380/05 DVD Recorder
Region code accidentally changed and no idea how to set it back
power on your dvd and press setting as you can view on your tv monitor then check the displayed carefully look for dvd regional settings and change it where you live.
Oct 18, 2008 | Samsung DVD-R155
DVD doesn't play any disk anymore. Displays a message: this can't of disc can't be played ... I tried several different types of disks.
Same here! It would say something along the lines of "this type of disc cannot be played. please insert a different disc." it's the appropriate dvd region, i've tried all types of dvds, and it still won't work. the vhs and cd still works, it's just the dvd player that won't.
Mar 30, 2008 | Panasonic PV-DF2703 Triple Play 27 in....
DVD player problem
You may have had a brief power outage you did not know about. Then the DVD player needs to be unplugged from the wall and started up again or your lens may need to be cleaned Because your dvd player is only made to play region 1 discs and vcd's are region 2. You need to buy a dvd player which will play all region discs or is rated region 0 which is the same. www.dvdenergy.com/index.htm
Aug 06, 2007 | Sylvania SRCD227 27 in. TV/DVD Combo
GPX D1816 DVD Player Logo
731 people viewed this question
Top GPX Televison & Video Experts
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
