Question about Onkyo TX-SR803 Receiver
Video problems Hi, I have a onkyo 803 receiver I have the hdmi hooked up with a sat & a dvd player.when I switch video inputs between the 2, the picture becomes jittery or breaks up or goes green.than it goes way just curious on what would make this happen. thanks Don
  • donald sumner Aug 03, 2007
    Hi tryed the immediate display feature,I turned it off and it has'nt done that again so far thanks for the help
    Novelist:
    Scholar:
  • 84 Answers
Hi summerof58....could you please update your post to include the complete Model Number in it's entirety of your Receiver. Electronics is such a huge arena that specificity is the absolute key to obtaining correct and precise answers...thank you
Posted on Aug 03, 2007
  • 1 more comment
  • V. Chris Suehiro
    V. Chris Suehiro Aug 03, 2007
    Hi summerof58....please disregard my initial post...evidently one eye was looking at one thing while the other was on vacation. I will update my post if I arrive at an intelligible and correct answer to your query....thank you.
  • V. Chris Suehiro
    Hi Don...I've been doing some minimal research when time permits, and rather than accumulate my discoveries and present you with an encyclopedia of possible causes/remedies in one sitting, I will update my posts as I glean possible causes, and will continue to do so until I see a white flag from your general direction.
    The first and most obvious thing that I learned is that I now too would like to own an TX-SR803. As for your issue, because your video screen exhibits symptoms of temporary signal loss upon switching Video In selections, the immediate likely culprits that come to mind is flawed or less than optimum settings in source detection/acquisition, or unneccessary/null tasks that are holding RAM, which would account for the "delay".
    Let's start with your DVD turned off, and your Recv'r Selection on the approriate IN for SAT. While viewing your tv, toggle your IN between DVD/SAT. Does your tv immediately go black, or cleanly display any appropriate default messages from your receiver as soon as DVD is IN? If yes, than we have definately removed your tv from this equation and can confidently focus solely on your receiver settings.
    The first alteration I propose is that you turn off the Immediate Display feature, which is ON by default, and can be found on page 79 of your owners manual. This feature has essentially been rendered null due to your all-HDMI setup. Although petty, it does require resources which, given your setup, is needed by you. Now, with a DVD on play, toggle your IN. Has that produced any change in your display response time?
    Finally....for now anyway, let's try changing your tv Format Setup, which can be found on page 47 of your owners manual. If your current setting is on Auto, let's try NTSC instead. After completion, try the IN toggle test again. Please post your results/observations which will help us determine if we're on the correct train of thought or not.....good luck my friend.
  • V. Chris Suehiro
    Thank you so very much for your courtesy update. If you come across this post, please close this thread by clicking on solved. Thank you and enjoy your awesome setup!
Unable to connect a blu ray dvd player to onkyo tx-sr605 via hdmi
Not sure what unable to connect means..but I will assume you have the correct cable.
First make sure you have plugged the from the HDMI cable from the DVD play into the IN 1 HDMI port on the back of your Onkyo
On the Receiver
Enter the Setup mode
Select INPUT OUTPUT ASSIGN
Next make sure the HDMI monitor out is set to YES on the Receiver
Monitor out
HDMI Monitor - YES
Next you need to assign the HDMI INPUT to DVD
HDMI INPUT
DVD - IN1
CBL/SAT - IN2
This may be your issue.
Next step would be to verify your television input settings.
Nice receiver!
Best of luck!
Apr 13, 2011 | Onkyo TX-SR605 Home Theater Receiver 7.1...
Dear Sir/Madam : Re: ONKYO HT-SR800 7.1 ch HOME THEATER SYSTEM The system will not deliver video output in television mode . Audio is fine . Initially , I press the...
Check the input selector on the TV, if you have audio only then it is a cable problem,
that means that cables are not connected in the right way.
Oct 10, 2008 | Onkyo Televison & Video
I have a Onkyo HT-S6100 sound system which has the HT-R667 receiver. I have a DirecTV dvr hooked up with hdmi, a PS4 hooked up with hdmi, and a Wii hooked up through component cables. The receiver is...
My HT-S6100 had a similar problem with my DVD player and some times with my Cable/DVR box. The signal wasn't getting received at the TV. So, first I changed the input jacks my DVD and Cable box are plugged into on the receiver (e.g. from HDMI 1 & HDMI 3 to HDMI 2 & HDMI 4). Second, I reprogrammed the Input Assignments to match (e.g. HDMI in 2&4). Third, I deleted any Input Assignments that weren't applicable. For instance, I'm only using HDMI connections, but there were Digital and Component Input Assignments programmed in. When I say I deleted them, I actually set them to "----" (just scroll through the options and you'll find this.) Finally, I turn on my video/audio sources (PS3 in your case) and let them load/warm up before I turn on my Onkyo receiver. It seems to be working. Good luck.
Sep 26, 2009 | Audio Players & Recorders
Onkyo TX-SR604 provides audio thru receiver but no video on Bravia LCD when satellite receiver signal is sent thru any of the Onkyo HDMI connections to tv, however if I connect up my Samsung DVD recorder...
easiest fix is to take all hdmi straight to tv. then come out of tv with optical cable to your receiver. that way what ever your watching will automatically be sent to the receiver thru optical. you even will get dolby dig. also you can have audio from your tv when you dont want to use your surround. keeps receiver on one input also.
Jul 02, 2009 | Onkyo TX-SR605 Receiver
Zone 2 speakers only work with the tuner - no sound comes out when switched to DVD, Cable/SAT, ect. All of my other devices (DVD player, Satellite Receiver, ect.) run through the receiver. How do I get...
hi,
zone 2 will only work with analog sources so if your dvd, cable and other devices are connected via HDMI, that alone won't work. What you need to do is hook up RCA (red and white) cables from the dvd player to dvd in of the receiver and same thing for your satellite box (and other sources.) no need to change any setting on the receiver. This way, the HDMI will take care of your main room speakers and the RCA will feed your zone 2 speakers.
Hope this helps.
Jun 10, 2009 | Onkyo TX-SR605 Receiver
Optical inputs
In short yes!
If you have two optical inputs and two equipment (PS3 and HDVD) then you shouldnt have a problem at all. Just make sure you change the mode of the receiver to TV/SAT when you want to use the HDDVD. Your problem may be the video out put.
If i was you i would do the following:
1. Get rid of all your optical cables as you won't need it.
2. If your receiver support HDMI then by default HDMI will send both video and digital sound.
3. Plug the HDMI of the PS3 to the HDMI input of the receiver, plug the HDMI of the HDDVD player into the HDMI 2 of the receiver and plug 1 HDMI cable from the receiver to the tv/monitor you have.
That is the best set up so when you play PS3 you select dvd/ld and when you watch hddvd you select tv/sat.
However having said all that the fact that you have dvd/ld suggests you actually don't have HDMI at all on the receiver(...i just checked the specs of the receiver). Which means you will need to have 2 hdmi inputs for your tv and you will need to have the 2 optical connections.
But in short yes to your question.
hope this is not too confusing.
good luck
smeags.
Feb 05, 2008 | Sony STR-DE595 Receiver
Video on game and dvd seem to work
DO you have hdmi monitor turned on?
Jan 05, 2008 | Onkyo TX-SR605 Receiver
Receiver won't put out sound to LCD Sharp aquos
I have the same problem with my Sharp Lcd and Onkyo 804. I believe one problem is that the TV can not accept dolby digital or dts digital audio signals through HDMI. It will play sound if it receives a PCM signal through HDMI. You can try switching the type of signal on the cable box settings and on the dvd player. I switched to PCM and got sound through the TV and the receiver. The problem is that PCM is usually only a 2 channel signal and Dolby 5.1 will sound better through the surround sound theater system. I have not found an absolute solution to this yet, but I am willing to not get sound through the lousy TV speakers in order to get top notch sound through the Onkyo.
Nov 12, 2007 | Onkyo TX-SR803 Receiver
HDMI switching?
I was having a simalar problem, what you have to do is go into a options menu that will come up on your tv screen and tell the reciever that you want it to put out and video through your hdmi cable.
Nov 08, 2007 | Onkyo TX-SR803 Receiver
New home theater setup- no signal at tv using onkyo tx=sr605
Could well be the quality of your cables. if you have high end cables the consult a service agent. if you have the cables that came with the products, go and get some better ones.
Nov 04, 2007 | Onkyo TX-SR605 Receiver
Onkyo TX-SR803 Receiver Logo
57 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
