Question about SAMTRON 55V 15" CRT Monitor
My monitor Model: SAMSUNG SyncMaster 551s Problem: Whend switch on my pc, monitor does not on properly. But when it on, shown different color, like as green, red, blue, black etc. It on for the sometime and again color black and off and again on and shown the different color. Again after sometime it work proper and again after 2/3 minutes it shown problem. What can I do now. Please write details how can I solve this problem. Note: This proble just begin at 2 days ago. Thanks Sankar Bhowmick Project Engr.
  • 58 Answers
First try with the reinstallation of the drivers.
If it won't works there may be a problem in hardware.
mostly with the picture tube.
Hope this helps.
Posted on Feb 01, 2009
Syncmaster 216bw monitor..stuck in power saver mode..power light blinking
Did you try this monitor with another PC yet? VGA cable connectors are properly seated?
This model (same chassis as the 223w) is known for haing bad caps in the power supply/inverter board as shown here:
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors pictures:
Learn about bad caps:
Capacitors kit: he can make you a set of caps for you.
Or just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Oct 26, 2011 | Samsung SyncMaster 216BW Monitor
Hi, I am using Samsung SyncMaster 551s monitor. Suddenly i found vertical stripes in my display when i opened my pc. Pls suggest me solution. Rgds/Himel
if the stripes take 45 dgree and acolor of white then its aproblem in the line then you can decrease the brightness (the 3rd pot) and see
Mar 18, 2011 | Samsung SyncMaster 551 15" CRT Monitor
My screen is shaking a lot and some times get black but my screen is samsung syncmaster 551s
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Sep 24, 2010 | Samsung SyncMaster 750S Monitor
I have samsung syncMaster 551s CRT monitor. i want to open its back cover. i found only two scrow and i have remove them. but now problem is i cant remove it. plz help me.
You have to find 2 holes at the top of the plastic cover (at the front edge of the back cover) of this monitor and place a flat blade screwdriver in them and gently press to unlock the cover.
Sep 22, 2010 | SAMTRON 55V 15" CRT Monitor
My samsung syncmaster 932b is blurry. There is a shadow slightly to the right of each object on the screen. How do I fix this?
cmwag, Try some isolation testing. Will 932b do same thing when connected to a different KNOWN GOOD pc? Will your pc display a sharp, bright, crisp, colorful screen when connected to a KNOWN GOOD monitor? Is the VIDEO card seated properly into its connector on the motherboard? Is VGA connector clean and tight into the port on back of pc? Hope this was of some use. 12fixlouie
Jan 29, 2010 | Samsung Computers & Internet
About text sharpness
The monitor shouldn't be changing the settings itself unless you changed it. Try changing the brightness and contrast. Otherwise, it might be a video card issue.
Nov 30, 2009 | Samsung SyncMaster 551 15" CRT Monitor
Samsung SyncMaster 730B monitor green color problem
video controller card has gone bad need new video controller card.
Mar 16, 2009 | Samsung Syncmaster 730B 17" Flat Panel LCD...
The power on switch is blinking only in a samsung color monitor
When you switch on the computer can you hear it beep?
If yes then it could be a monitor problem.
This could be monitor or computer ,the only way to test is to try the monitor on another computer or vice versa.
Jan 09, 2009 | Samsung SyncMaster 753 DFX 17" CRT Monitor
No display in monitor
This may be the problem with the WYSE driver. Ensure that correct driver is intalled and colour profile is compitable. Syncmaster is auto detected by window based OS.the message "Sync out of range" comes due to improper out put video signal.
Jul 24, 2007 | WYSE Winterm 3235LE Network Terminal
SAMTRON 55V 15" CRT Monitor Logo
93 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
Richard Lilja
Richard Lilja
William Miller
William Miller
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
