Question about BenQ Scan to Web 5000U Flatbed Scanner
Trying to install driver for Scanner Model Benq 5000 color flatbed scanner. several attempts failed. seeking asistance.
I want to install BenQ scanner 5000 flatbed but I have no CD
Posted on Feb 26, 2009
I need a scanner driver modle benq 5000 color scanner
Posted on Feb 01, 2009
HOW DO I un-lock the scanner on a Brother MFC 7420?
Unfortunately, the MFC-7420 doesn't have a physical lock switch. You need to turn off the all-in-one and wait for the unit to clear its memory. If the error recurs after you press the power button again, wait 30 minutes and try again. (Note: you will lose any faxes that are in memory. See the User Guide page 11-5 to save this information.) You can find the manual on the Brother support page for the MFC-7420: https://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=MFC7420 . Click on the Manuals & Documents tab. Then click on the Manuals on our Online Solution Center for the English version of the manual. The direct link to the User Guide is currently: http://download.brother.com/welcome/doc000387/ALLFB_UsaEngUsr_B.pdf .
You can also try unplugging the all-in-one for several minutes to reset the error codes. If the error persists, contact Brother if the MFC-7420 is still under warranty (1 year). If it isn't under warranty, consider replacing the unit. The repair costs may be unreasonable.
I hope this helps.
Jan 09, 2017 | Brother MFC-7420 Printer
B&w/gray Scanning Is Okay But Color Scanning Problem
Run ink head cleaner routine. If you cannot the list make and model of printer. Thanks.
Dec 25, 2014 | Office Equipment & Supplies
Hp laserjet m1522f error 5 turn off and on
Hi, Error 5 is a Scanner error. When turning the printer on, have the lid up so you can watch the scanner movement. Does it move smoothly? It should go through a warm up and you should be able to watch the scanner movement. If there is a problem with the scanner, there isn't a lot you could do except. The service manual says the scanner assembly should be replaced. If it was my printer, I would try to take a closer look at the scanner assembly and check to see if the scanner unit is bound up somewhere, or maybe a drop of 3 in 1 oil on the scanner rails. Let us know what happens.
thanks
Oct 02, 2013 | Office Equipment & Supplies
Canon pixma mx 922 will not scan
This happen due to poor version of drivers.Make sure that you install latest drivers. If you don't have then download it from PIXMA MX922 Canon Software Driver
For more help or guidance check Canon MX922 Manual English
Jul 28, 2013 | Office Equipment & Supplies
HP Laserjet 3330. Scanner bulb warming up doesn't go away. I have done the "solution 1" as discribte but nothing is happening. It goes like: - i put the power on, hewlett packard is flashing, the...
How does the bulb look? Is it bright or kind of dim. The bulb warming error is designed to halt use of the machine until the scanner bulb reaches the correct output level. As these are basically a flourescent tube, they will dim over time and at a certain point they will not generate enough light to enable proper scanning. If the bulb is dim, it will require replacement.
Mar 14, 2011 | Office Equipment & Supplies
LSU error SAMSUNG SCX 4725FN
Laser Scanner Unit or LSU is what writes to the surface of the drum. The glass above the cartridge in the machine may be dirty. The mirror motor in the LSU could be bad or needs to be cleaned to spin better. The Laser diode may be faulty.
This is not a user-serviceable issue. You will need to contact Samsung for a service. You can do it online via Samsung website or contact the vendor to see who will they appoint to service the printer to, especially if it is still under warranty.
Jan 27, 2011 | Samsung SCX-4725 Laser Printer
Why does canon MP258 printer with scanner can't scan japanese yen paper bill amount 10,000. I tried it over 10 times but it stops,. And when i tried US paper bill, it works well. I need some explanation...
When you scan with any scanner it utilised the software with "Optical Character Recognition functions, usually abbreviated to OCR -> OCR is a field of research in pattern recognition, artificial intelligence and computer vision." to scan and record the scanned object, sometimes it does not or cannot recognise certain symbols or characters because of man made software & hardware have its limitations too.
Hope it helps.
Nov 12, 2010 | Office Equipment & Supplies
HP printer psc 2210 all in one
Chances are that you didn't lock down the scanner when you moved the unit. You can attempt to open the unit and move the scanner bar manually to reset it. HPs are very difficult beasts when it comes to their power up check out. It must be fully functional...including all cartridges...to work in most cases. Good luck.
Dec 20, 2007 | Office Equipment & Supplies
BenQ Scan to Web 5000U Flatbed Scanner Logo
141 people viewed this question
Top BenQ Office Equipment & Supplies Experts
Tom Chichester
Electro Med Services...
Tony
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
