Question about Kenmore 24902 Top Load Washer
Water valve replacement
I need to replace the water valve on my Kenmore top load washer. What are the steps to opening the back and replacing the valve?
    President:
  • 331 Answers
DON'T OPEN THE BACK!!!! This is done from the front. You must remove the outer cabinet first. UNPLUG YOU WASHER BEFORE CONTINUING! 1.) Remove the 2 phillips screws on either side of the control panel and rotate the panel up and out of the way. 2.) There are 2 brass colored clips under the panel. One on either side. Poke your screwdriver into the slot (the tip of your screwdriver will be facing down) and pry backwards toward the wall to remove these. 3.) Disconnect the white electrical connector that's plugged into the top of the cabinet. 4.) Now tilt the entire cabinet toward you. Bring it to a 45 degree angle... this will release the clips. Then lift and pull it off of there and set it aside. You now have access to the water valve.
Posted on Aug 01, 2007
2 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: Kenmore washer 70 series(top loading) only
The water temperature selection switch would be what I would check next.
Posted on Mar 30, 2011
Washer drips after cycles are completed.
yes the water inlet valve is bad! might be easier to remove the base, when you remove the base the back stays connected to the frame. just unplug the machine,remove the end caps on your control panel and remove the screws holding it on, them pull slightly forward and up to fllip the control panel back it has plastic hinges on top,be careful not to break them. then unplug your lid switch, with a screwdriver remove the 2 gold clips that hold the base to the back panel, then open your lid lift from back towards you and the whole base will come off leaving the back panel and frame, should be a whole lot easier to replace the valve, then replace reversing your steps , when you are lifting off the base look at the bottom of machine through your lid and you can see how to put it back on the frame! not to hard!
Feb 17, 2010 | Kenmore 24902 Top Load Washer
My Kenmore 110 92587210 Washer is slowly letting water in
The solenoid for the cold water valve has failed in the open position and needs to be replaced. The valve unit is for both hot and cold. It is the item that the water hoses are connected to.
Aug 26, 2009 | Kenmore 24032\24036 Top Load Washer
Washer won't fill with cold water
hi..
Replace water inlet valve, it's stuck open. You may try removing hoses to valve and see if something is holding it open..
thank u
rate me..
Aug 15, 2009 | Kenmore Washing Machines
Describe your Kenmore 24032 \ 24036 Top Load
That is a bad water valve. Try my washer PICTORIAL for directions on replacing that water valve. NOTE: this is a pictorial of how to replace your drive coupling but you need to bust this ****** loose to get to that valve.
Jul 06, 2009 | Kenmore 24032\24036 Top Load Washer
Washer water wont stop running and switch to wash. It overflowed
sounds like a bad water valve. Try disconnecting for a few minutes. If problem continues, the solenoid on the water valve is staying open which means the circuit is not opening. Replace valve.
Jun 29, 2009 | Kenmore 22422 Top Load Washer
Kenmore 90 series cold water trickle
Hi, If there is good pressure to the valve and the screens inside the valve are clean, you will need to replace the inlet valve.
Please let me know if I can assist you further with part# or how to replace the valve.
Thanks
Vic
May 24, 2009 | Kenmore 24032\24036 Top Load Washer
No hot water going into wash tub. Hot water else where in house.
on the back inside the washer are two solenoid operated valves that control the hot and cold water flow. your hot valve has ceased to function...and needs replacement.  also make sure your hot water valve is open fully and that the screen inside it isn't clogged.
Apr 03, 2009 | Kenmore 22422 Top Load Washer
Disassemble Washer
Here ya go. Follow the steps provided in this link:
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
The mixing valve is also know as a "fill valve" or "water inlet valve", just for clarification. I hope these steps help you with completing your repairs. If you get confused along the way, or require additional assistance, please let me know.
Dec 22, 2008 | Kenmore 24032\24036 Top Load Washer
When on hot water selection no hot water comes out
This an indication that the hot water solenoid in the water inlet valve has failed. If you replace the valve, I bet your problems go away. The following link provides you with step-by-step instructions on how to replace one:
Please post back with your COMPLETE model number (located along the wash tub opening under the washer lid) if you require parts assistance. I can help you locate them online, or provide you with the a part number. I hope this helps you.
Jul 02, 2008 | Kenmore 22422 Top Load Washer
Lady Kenmore Washer
Possibly a bad fill valve. If you're hearing a noise, it sounds like the valve is getting power, but isn't opening to allow water in, or is clogged. I would check your valve inlets on the back of the washer, first. Turn off the water and disconnect the hoses on the back of the washer. The water inlet screens are located in the valve fittings. Take a cotton swap and clean them out thoroughly. If they are clear, you may want to invest in a new replacement valve. Let me know if you need to pursue this option and I can give you the steps necessary to replace. It's not a very difficult repair job. I hope this helps you.
Aug 09, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore 24902 Top Load Washer Logo
23 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
