Question about HTC Touch Cruise Smartphone
Touch Screen does not Working. The case is ok
I Try to reste default configuratio, but the screen freenzing in windows mobile set up
    President:
  • 1,223 Answers
Touch panel is faulty if u are stuck in the first alignment screen try getting it replaced under warranty
Posted on Feb 20, 2009
I have a china mobile suny ericssom C6.Its touch is not working after using the touch screen setting.please resolve this problem.
Oct 29, 2012 | Cell Phones
Only my touch screen isnt working, all the other buttons work, is ther ea rest that can do to fix this?
try resetting everything to factory default n restart ur 4n. M sure it was not dropped. Most touch screens end up this way because of shock.
Apr 09, 2011 | Samsung Cell Phones
My LG GS290 Touch Screen Not Working. Widgets Are Visible But Not Functioning.
In this case, the touch screen may have gone faulty. first, have your set cleaned (serviced) but if problem persists, then have the digitizer replaced. check it here.
thanks for using fixya.
Feb 24, 2011 | Cell Phones
The vibrate setting has stopped working. Vibrate doesn't work at all. Is there a way I can fix it?
Please try resetting the phone but this will reset all the settings to factory default.
Steps to Reset Settings
This resets the phone to factory default settings.
  1. Unlock the screen by touching Lock or pressing the Unlock Key on the left side of phone, then touch Menu to access the menu .
  2. Touch the Settings & Tools icon.
  3. Touch Phone Settings.
  4. Touch Security.
  5. Enter lock code. The default lock code is the last 4 digits of your phone number.
  6. Touch Reset Default.
  7. Touch OK after reading the warning message.
  8. Touch Revert. A confirmation message is displayed briefly before the phone resets itself.
source: http://www.resetcellphone.com/solution/LG/vx9700-dare
Feb 22, 2011 | LG Dare VX9700 Cell Phone
Touch screen not working
there must be display screen problem.contact your device dealer and ask them to change the display screen of your mobile.this will fix your problem.
Dec 27, 2010 | HTC Touch P3450 Smartphone
Hi i have taken the phone to defaults settings and now the touch pad is not working.
This can be fixed by resetting your phone.default setting is used for making services on your mobile. while your mobiles touch screen is in compliant
Aug 14, 2010 | HTC Touch Cell Phone (Unlocked) - Soft...
HTC Touch was stucked up after an error while upgrading to WM 6.1
i think u have tried to upgrade thru custom rom bcoz this pda came with WM 6 only so u tried to upgrade to 6.1 thru custom rom procedure and it seems like something went wrong and u get a boot loader screen tri color with code written SPL 1.XXX on it dont worry i can help u in this go step by step as soon as ur problem is resolved leave other step
first try this
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if ur pda boot normally after reset procedure it will take some time to boot dont panic if it is ok then good luck
if it doesnt help then try this
download Hard SPL 3.1 from here
http://forum.xda-developers.com/showthread.php?t=445666
install it as described in the instructions inside the zip file
and then Rom Lite version for ELF from here
http://forum.xda-developers.com/showthread.php?t=451100
first install hard spl 3.1 as directed on ur pda and then update to custom rom from the the file downloaded
pls rate me FIXYA if it helps
Mar 14, 2009 | HTC Touch P3450 Smartphone
Touch pro screen blank
first try this
if it doesnt help then then go to www.htc.com and upgrade ur ROM
Pls rate me FIXYA if it helps
Stuck on windows boot up screen
Regarding with your HTC Viva / Elf
Try hard reset with phone in "OFF" state following this instructions if it will do;
1. Press and hold the TALK and END buttons, and at the same time, use the stylus to press the RESET button under the battery cover at the top
of the device.
2. Release the stylus, but continue pressing the TALK and END buttons until you see this message on the screen:
Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have
been backed up before a hard reset is performed.
3. Release the TALK and END buttons, and then press ENTER on your device.
Mar 03, 2009 | HTC Touch P3450 Smartphone
Touch pad on/off utility
Disabling or enabling the TouchPad The TouchPad is enabled by default. To change the enable/ disable the TouchPad setting: 1 Click Start, Control Panel. The Control Panel window appears. 2 Click Printers and Other Hardware. 3 Click Mouse Properties. The Mouse Properties window appears . 4 Click the TouchPAD ON/OFF tab. The TouchPad ON/OFF tab appears. 5 Select Disable or Enable, whichever is appropriate. 6 Click Apply.
7 Click OK. The Mouse Properties window closes. 8 Close the Printers and Other Hardware window . 9 Close the Control Panel window.
Nov 11, 2007 | Toshiba Qosmio G25-AV513 Notebook
HTC Touch Cruise Smartphone Logo
303 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
