Question about Acer TravelMate 4320 Notebook
Removing the Memory Card Drive
I inserted a wrong memory card( Digital Camera Card) in the slot and since this card is a small one, the whole card went inside and I am unable to remove it. How can I get this thing out. Can I remove the whole drive?
Any help would be highly appreciated.
Thanks
  • 79 Answers
If you can see the card, try using a hair tweezer to pull out the card.
Posted on Feb 01, 2009
How to remove memory card from camera
Confirm the power-on lamp and the monitor are off and open the battery-chamber/ memory card slot cover. Be sure to turn off the camera before opening the battery-chamber/memory card slot cover.
Removing Memory Cards 1 Before removing memory cards, turn the camera off and confirm that the power-on lamp and monitor are off. 2 Open the battery-chamber/memory card slot cover and press the card in to partially eject the card. 3 The card can then be removed by hand. Do not attempt to remove the card at an angle.
Insert the memory card.
4 Slide the memory card in correctly until it clicks into place. 5 Close the battery-chamber/memory card slot cover.
Oct 08, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
I was changing the memory card and the second memory card will not go fully into the slot. i have tried to insert other memory cards but none will fully slot in.
Two different memory card slots is a feature normally found on professional cameras. Anyway I'm including a picture and the only thing I can think of is that the card is the wrong way around. There are very small guides along the side that will forbid it from loading backwards. Problem is if you force it you could damage the guides OR the pins at the bottom, take a look at the picture. Robert in Canada
Dec 14, 2010 | Fuji Finepix S9600 Digital Camera
The memory card slot feels tighter than usual. after i put in the memory card and turn on the camera, i get the message of "no memory card."
Make sure you are inserting the card in exact manner as illustrated in the camera manual or near card insertion slot.
Try to check into the memory card slot if any of the contact pins are not damaged.
Oct 05, 2010 | Canon PowerShot SD850 IS Digital Camera
Where is memory card inserted in E317 camera?
Open the battery door. There's a small slot behind the battery that is for the memory card. The notch end of the memory card should go in first when inserting it. See the image below
Please do rate this answer.
Thank you for using Fixya.
Sep 04, 2010 | HP Photosmart E317 Digital Camera
My camera will not put pictures onto the memory card, it just put them into the internal. how do i fix this problem
The problem may be that the memory card is defective - or more likely that the card is "locked" or "protected" You can check for this by removing the memory card from the camera if it isn't already, and look along the left edge of the card. Find a small tab and slide it forward (to the unlock position) and carefully slip the card back into the camera and try again. If it still won't store images on the card, carefully remove the card to see if the tab has moved back to the locked position. It is possible that if the tab is moved when inserting the card, it could just as easily be moved back when removing, too.
Either way, if the tab is moving (or suspected to be be moving) to the locked position during the insertion and / or withdrawal process, you could place a small amount of tape along the card edge - over the tab - and carefully insert the card again. You might have to remove some tape to allow the card to fit into to slot, depending how much room there is. If you never lock the card (I never do); you could put a very small drop of super glue on the tab to hold it in place. Wait for the glue to set completely before inserting into the camera and try again.
If all else fails, you might try again with a different card.
I hope this helps!
Nov 10, 2009 | Fuji FinePix A820 Digital Camera
Memory card works in PC but not in my Nikon camera.
you have to set the setting on the camera to write to card and not to camera internal memory, look at the manual about that, if not post again
Aug 08, 2009 | Nikon Coolpix S210 Digital Camera
Memory card will not push in and stay engaged in memory card slot
This happens most of the time with digital camera and mobile phones, if you try to insert the memory card in a wrong direction. Before inserting your memory card, look into the slot hole and see the position of contact terminals and insert your card in such way that the card comes with contact with the terminals inside the slot. If your card already got struck into the slot, try removing it by pulling out using a small nose plier. Also try with another memory card of similar type to detect any problem due to your memory card. I hope this will help you out.
Aug 04, 2009 | Canon PowerShot A720 IS Digital Camera
Wrong memory card size insterted
Opening of your camera would not be good because memory slot has very very little space in it and you can't do any thing, use tweazer to pull out that memory card.
Jun 20, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Memory card error
Check the slot and see if the pins inside are fine, no breakages, free from dust etc. Try turning the camera on and off (completely remove batteries etc).
Mar 03, 2008 | Canon PowerShot A530 Digital Camera
Camera doesnt recognize a Secure Digitalor MultiMediamemory card?
The cause and solution may include one of the following: The card may not be certified SD or MMC. Purchase a certified SD or MMC memory card. The card may be corrupt. Reformat the memory card. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card. The card is not fully inserted in the camera. Turn off the camera, insert a card into the slot, then push to seat it.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Acer TravelMate 4320 Notebook Logo
29 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
