Question about HP Compaq Presario V2000 Notebook
A claim some component of ventilation has been damaged due to no pro per ventilation
  • Roberta Smith
    Roberta Smith May 11, 2010
    if you are making a warrenty claim ... may i suggest you try www.hp.com
  • Kevin Shafer
    Kevin Shafer May 11, 2010
    So what is your problem that we may help?
    Problem Solver:
  • 4 Answers
I had the same problem on my v2000. apparently the fan shroud for the cpu cooling fan is made of plastic and can deform. In my case the deformation allowed the fans blades to strike the heatsink stalling the fan. This would lead to system overheat and shutdown. I disassembled the unit removed the fan shroud and installed .5mm O-rings onto the mounting screws moving the fan away from the heat sink and allowing normal operation. This repair is not for the faint of heart as these are tiny screws.
Posted on Feb 10, 2009
Have a guarantee on the car from autoprotect. refusing to accept claim - say its due to wear and tear. True?
Depends on the component and level of protection that you purchased. Read /read your contract and see what components are covered and for how long. You never said what component is was.
Aug 05, 2015 | Cars & Trucks
Frigidaire CPEF3081MFC - Clock and timer run fast [gaining approx. 10 mins per hour]. Everything else, including temperature, functions normally.
If the power outage was as a result of a power surge it is likely that
the components were affected in some way, they may need diagnosing and repair or replacement.
There are many reports of electronic devices going wrong after
a power cut...the outages are , seemingly responsible for a lot of damage. If this is the case I would look at whether there is a mechanism for claiming reparatory compensation from the power company you are signed to
Jul 03, 2015 | Kitchen Ranges
My computer is automatic shutdown
Have you cleaned the fan, vents, heatsink? If a laptop overheats, due to dust, poor ventilation, blocked vents, it will shut down to prevent damage to vital components. Clean, improve air flow through the bottom and out the vents. Never use on soft surfaces that can block air flow. Contrary to the name, Laptop, it's not good to use on your lap. Go figure? If the Laptop is Clean and air flow isn't a problem, open Power Settings in Control Panel,and change Advanced Power settings to Sleep/Hibernate to Never, set to High Performance, unplug and remove battery when not in use. If you use mostly on AC remove battery.
Sep 24, 2013 | Computers & Internet
Hello why does my 04 mitsu endeavor not shift past second gear and neutral light flashes when in drive and takes a sec to engage
Your Mitsubishi transmission is a sophisticated piece of machinery, with multiple electronic components and advanced diagnostic capabilities. This means, your transmission is capable of telling you what the problem is, via the diagnostics process.
When the "N" light flashes, this is an indication that a fault has ocurred within your transmission, and to prevent further damage, the transmission is then placed into "Limp" mode , allowing the vehicle to be driven at low speed - just enough to get you to your home or service agent.
What the "N" light flashing means:
i) One flash per second (1Hz) - the computer has detected an internal malfunction. Further diagnostics is required to identify the suspected circuit or component.
ii) Two flashes per second (2Hz) - the trans fluid temperature is too high. Stop the vehicle, place gear into Neutral and leave engine idling for 2-5mins to allow fluid to cool. Chances are your fluid may not be of the incorrect type (must use Mitsubishi fluid only), incorrect level or the fluid is due for replacement.
Further diagnostics should be carried out by extracting trouble codes (DTC) from your vehicle's Powertrain Control Module (PCM). This process takes only a few minutes with the aid of the correct hand held scanner - I recommend this process be done only by a Mitsubishi franchise, as many garages claim they know what they're doing, when in reality, you end up spending unnecessary $'s, due to their lack of knowledge.
If problems in the transmission have been detected, one or more fault codes (DTC) between P0700 to P0999, should be stored in your PCM's memory.
NB: the correct diagnostics procedure will identify the problem very quickly. Do not waste your time taking to your local mechanic, who may not have the required diagnostic scanner.
Hope this helps........and Good Luck !
Nov 01, 2011 | 2004 Mitsubishi Endeavor
04 mitsubishi endeavor transmission slips goes in to gear but takes a sec to engage and then nuetral light flashes in drive and it wont shift past second gear
Hi Frank,
Why would a monitor start to smoke?
Hi!
The cause could be a blown capacitor/regulator and/or overheating to due blocking of ventilation area, which resulted in self-"frying"... It's time to replace the monitor!
Regards,
Pelu
Jun 04, 2011 | Dell Studio XPS 435 PC Desktop
Consumer Priority Service - How Many Years Of Coverage Should I Buy For My Apple Macbook Pro 17''?
In Use Service Time on a Mac is typically longer due to the quality of the hardware...plus the additional expense and expertise it takes to repair them may want you to consider a longer contract with a replacement option. I'd say 3-5 especially if you travel. If it sits at home and there is not much movement.. 2-3. Quality of the Mac is high... this would be just like Insurance.
Jan 04, 2010 | Apple MacBook Pro PC Notebook
Titanium ventilate issues
Remove the milk frother,checked to see if it is blocked.
This can cause the machine not to ventilate correctly.
They tend to block with old hard milk.
Aug 26, 2008 | Gaggia Titanium Espresso Machine
Frigidare electric dryer not heating properly
Longer dry times and improper heating can be attributed to poor dryer vent ducting. The first thing you need to check is the ventilation ducting to ensure that it is not kinked or clogged. Poor air flow is the number one cause of dryer failures. Not to mention it can cause fires due to lint backing up inside the dryer. This can cause an "electrical" smell a lot of people complain about. If lint accumulates on the heating element it will smolder and burn. It is often reported that you should clean your ducting twice per year. I recommend the ducting be checked (this means inspected to see if it needs cleaning) thoroughly about once per season. That's 4 times per year. If you've never cleaned the ducting, or your dryer is pushed all the way up against the wall causing the ducting to become kinked, you will have air flow problems. One way in determining air flow is to remove the vent hose from the back of the dryer and start the dryer with a load to see if it heats better. The air flow coming out of the back of the dryer should be forceful and gradually warm up to about 140 degrees. If the air flow is weak, you may have a clog inside the air baffle of the dryer (this is where the lint screen slides into). If the air flow is good, reattach the dryer hose and check at the output of the dryer vent as it exits your home. If the air flow is weak or non-existent then you know you have a clog in the vent line somewhere. Periodic cleaning will go a long way towards preventing future clogs. Dryer vent rule of thumb: The SHORTER and STRAIGHTER the vent line, the BETTER. Everywhere you have a bend or kink is an area where you will create potential collection points for lint. Poor dryer maintenance is also one of the frequent causes of house fires. In addition, if the dryer vent runs into an attic, or under a crawl space, this can cause heating problems due to frequent clogs (remember the shorter and straighter rule). I would recommend a little routine inspection and maintenance before assuming you have a part failing. Leaving a dryer in a poorly ventilated condition will eventually lead to failure of the heating circuits. If you have checked the dyrer thoroughly and have no ventilation problems, we can take it from there to see if you have a component starting to fail on you. Please post back and let me know. I hope this is helpful to you.
Jun 17, 2008 | Frigidaire FGR341AC Electric Dryer
HP Compaq Presario V2000 Notebook Logo
74 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
