Question about Sharp AR-207 Copier
We have sharp AR 206 F502 code is coming what is this code and how solved the metter i change the lens unit,optical unit,expouser lamp,cable but stil the code please help me what i do thanks
  • jpd8 May 11, 2010
    MCU PWB--- would check and replace, if good -- Main PWB
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
F5-02 - Exposure lamp blown
**ALWAYS DISCONNECT POWER BEFOE WORKING ON MACHINE****
Check the exposure lamp, if defective replace.
Check inline exposure lamp fuse, if defective replace.
Also check flat cable from CCD to MCU PWB , if cut or defective replace.
Last -- brds (boards)
Posted on Feb 01, 2009
Arm237 f5-02 light goes out after 1 second but should stay on -- lamp ok, cable ok, broke after cleaning optics
It is possible that while the optics were getting cleaned the cable connected to the lamp unit got pulled out enough that it looks like it is connected but isn't connected enough, or the lamp was accidently touched by the person cleaning the lamp and now its bad. I would check the cable that connects to the lamo unit and the CCD first.
Sep 28, 2011 | Sharp AR-M237 Copier
1I am was using Sharp ARM155 printer/copier. i got the error message on printer that "Error Code [E7-11]. Please refer the user guide". please tell to me how do solve the problem.
E7-11 Shading troble(whife correction)
IMPRPER CONNECTION OF THE CCD UNIT CABLE DIRT ON THE MIRROR,THE LENS,AND THE REFERANCE WHIT PLATE
copy lamp lighting abnormality
ccd unit abnormality
MCU PWB abnormality
(when occurred in the scan position)improper installation of the mirror unit
Jul 29, 2011 | Sharp AR-5316 Advanced Digital Imager...
ERROR F5
error F5 02
Copy lamp lighting abnormality.
Sorry.... or Replace the copy lamp unit or Replace the MCU PWB
Valerio
May 17, 2011 | Sharp AR-5316 Advanced Digital Imager...
Earorr E 7
E7 it is main code sub code 03 problem on LSU Check printing with SIM 64-1check the LSU unit.Check the MCU PWB
Sub code 04CCD white level trouble# Details CCD white reference level which is read during the copy lamp lighting is abnormal.
Aug 28, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp Photo Copier AR 5316
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} E7-11 Shading troble(whife correction)
MCU PWB abnormality
Jul 31, 2010 | Sharp AR-5316 Advanced Digital Imager...
What do i do to solve error code F5:02 on sharp Ar-205?
F5-02 means the copy lamp is not on or not bright enough.
Remove the glass and clean all the optics in the scanner including the lamp, if it is coming on that is. Make sure you clean the bottom of the glass, the white strip on bottom well.
You can also press # * C * and the machine will go into diagnostics,
then enter 14, then 1 and execute. then 15 , 16 , 17 and execute those fault clearing procedures.
If the lamp is bad let me know I can get the part number for you.
Jul 15, 2010 | Sharp AR-M257 Black and White Copier
Problem on sharp copier ar m-236 h4-01
Try reset the error code by pressing [#] [INTERUPT] [C] [INTERUPT] [14] [START]. If error still exists check the thermostat and heater lamp of the fusing unit.
Jun 04, 2009 | Sharp AR-M237 Copier
U2 fault on Sharp AR-206
Error code U2 in Sharp copier AR 206 shows error or failure of toner crimp you can try to solve by replacing toner crimp
Or by reseting the error code by fallowing procedure
press c intrrupt 0 ( zero ) intrrupt contoneously after pressing all the light on control will go off then press 16 then press start switch
your prob will 100% solve.
if any more prob pl inform
May 20, 2009 | Sharp Office Equipment & Supplies
I want a solution for a Sharp AR - 287 Digital Image problem
H4 for an error code on all Sharps indicates that the fusing temperature isn't correct. It needs to have a new thermistor installed or the heating lamps need to be replaced.
Oct 21, 2008 | Sharp AR-235 Copier
Sharp AR-207 Copier Logo
576 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
