Question about Dell Dimension 8400 PC Desktop
Disc Drive issue.
Whenever I use one of my disc drives it seems to slow everything down. Sound and video get choppy. When trying to burn a disc it burns really slow eventually messing up the burn. Is this a power supply issue. Maybe the power supply is being drained when a disc drive is being used.
thank you in advance
Robert
  • Robert Castillo Feb 20, 2009
    I bought some more memory as well as reinstalled the driver the disc drive seems to be working as normal now. Thanks for all the help, Now I have another problem I also bought a EVGA 9400 GT 1 GB video card. I have installed the updated drivers as well as the Control Panel software. When I start my computer I receive an alert "PCi Express card is in 1x mode. Press F2 to go to set up or F1 to continue". I go to set up But I donot know what I'm supposed to do. The 9400 GT was resommended by Dell saying it's compatible with my 8400. I get video to work but some of the videos the sound is off by a scond or two. Any suggestions would be greatly appreciated.
  • 27 Answers
Try to reinstall the driver for the dvd drive, all you have to do, is, GOTO CONTROL PANEL
click SYSTEM
on the top you will see HARDWARE TAB
click on it and then click on device manager, under device manager you would see disk drive, click on the plus sign next to it and in the list below, right click on it, click uninstall and then restart the computer, check if it helps,
Posted on Feb 07, 2009
    Brigadier General:
  • 5,158 Answers
Very likely it is a memory issue... try to close down as many programs as you can while you are burning a disk... if possible you may want to upgrade the amount of memory you have
Robert
Please take a moment to rate this solution thanks
Posted on Feb 01, 2009
I get "Disc problem -
the hard drive may be damaged or not have FAT32 format on the drive. this can be because the hard drive is not readable any more and needs replacing or it have lost it's format. check the hard drive on a PC. if not recognised on a pc you will need a new one and format it to FAT32 split drive as sound like you have the type with a cd rom. then down load the firmware and burn to a disc. put new hard drive in and cd into drive and hold down camera 2 for 5-10seconds should put the new software on from the disc and restart. takes up to an hour depending on disc size you put in.
Sep 08, 2011 | Dedicated Micros Digital Sprite 2 RS Video...
The drive will not burn cd's. It rejects the disc to be recorded and say no disc in drive. you can read from it or load a music cd. It does everything but burn cd's. Disc drive atarts to spin but speeds...
This situation will sometimes occur if the laser device is dirty. You can purchase a CD drive cleaner at most discount retailers inexpensively, and give that a try.
If that does not solve the problem, then it's probably time for a new disc drive.
Hope that's helpful.
Jan 18, 2011 | Computers & Internet
I have a problem with my LG Super Multi DVD Rewriter GH22. When I try to burn a disc, the writing process will start (mostly), but at some point the drive will get stuck so that the writing process never...
The issue seems not related to the LG Burners, possible the disc in which you are trying to burn may be issue.
Can you try with the different brand disk.
Oct 12, 2010 | LG Computers & Internet
Dvd burner not working
It sounds like the DVD burner does not have a "write strategy" for the type of disc you are using. This results in the burner and the software having an endless argument about how to go about the burn!
You can either use another brand of disc more compatible with your burner or go to the DVD burner's manufacturer's website and check for "Firmware" updates.
The firmware is the software within the drive that establishes the write strategy for each type of disc and these are often updated.
If you do update the firmware then be sure to read the instructions on the manufacturers website carefully and follow them EXACTLY.
Jan 27, 2009 | Toshiba SD C2512 (SD-C2512) Internal DVD...
Samsung SH203N
well you could try to set it to the right speed and then maybe you never no it could actually work and you would get more custmers.
Apr 07, 2008 | Computers & Internet
LG HL-DT-ST DVDRAM T10N ATA DRIVE
Various issues can cause drives to occasionally balk at writing optical discs. These run the gamut of physical, hardware, and software troubles.
Inappropriate or dirty media may be to blame. Make sure to match the type of recordable disc to the drive, and check each disc for fingerprints or other contaminants. If a disc is dirty, wipe it with a clean, soft cloth in a straight line from the center hole outward. Try a quality optical drive cleaning disc if you suspect dust contamination on the drive’s laser lens.
Some discs don’t perform well with certain drives, even within their rated speeds. Try recording at a slower speed and then with a different brand of disc. Also, on PCs, verify that the temporary file storage area on the hard drive used by the burning software has enough free, defragmented space. Allocate at least 5GB for a DVD (9GB for a double-layer [DL] disc) and about 1GB for CD burning.
Feb 28, 2008 | HP Pavilion dv6000z Notebook
Cd burner quit working properly
Just a thought! Check your hard drive is not out of space as it may be having buffering problems..
Feb 19, 2008 | Computers & Internet
DVD - Slow burning speeds
Unlikely that there is a problem with the drive itself, most likely cause is software settings - which burning software are you using? if it is nero 6 then once you click burn after arranging the files for burning, the burn info page should pop up. click on the burn tab and make sure that "determine maximum speed" is checked and that write speed is set to maximum. hopefully this should solve it, if not try setting write speed to one of the slower settings listed and see if you get a better result. Sometimes dvd drives can slow right down when you are trying to push them to go at maximum. if you want to check what it should be able to do, try http://www.pcpro.co.uk/reviews/87363/sony-dru820a.html also worth trying is updating the drivers http://drivers.softpedia.com/get/FIRMWARE/Sony/Sony-DRU-820A-10b.shtml to make sure you have the most recent version. Another thing worth trying if you haven't already is try a different brand or type of disc - just occasionally there can be clashes with certain types and burners - if this seems to solve it, don't throw your pack of discs away, give them to someone with a different burner. The final possibility is a power supply problem. If your PC's power supply unit has spare connectors for a drive then try a different one - possibly your supply doesn't have enough guts to run a more modern drive - take the drive out and try it in another pc with a higher power supply wattage rating. Hope this helps :)
Feb 28, 2007 | Sony DRU-820A DVD RW Dual Layer Burner
Dell Dimension 8400 PC Desktop Logo
53 people viewed this question
Alun Cox
