Question about eMachines T6524 PC Desktop
System will not power on.
I have a emachines T6524 when the side panel is on the computer will not power on. If I remove the side panel the machine will start as normal . Any suggestions why this is happening.
Thanks in advance
Robert
  • 6 more comments
  • Robert Castillo Feb 01, 2009
    It has been happening for a few weeks. I just never bothered with it I had another computer to work with, I have cleaned out all the dust. The heatsink is really dirty. I will try cleaning the heatsink. I have not turned the system on in while and I have misplaced the power cord. Once I find the power cord i will check the fans and install speed fan to ensure they are running correctly. I will update as soon as I find the power cord.
    Thanks for the fast reply.
    Robert
    Thanks for the info, and I will keep you posted.
  • Robert Castillo Feb 12, 2009
    Well, I found my cord and when I try to power it on the screen stays blank. The CPU fan starts the rear fan starts I believe the hard drive is powered on. The hard drive light is on in the front. None of the ethernet lights are on when an ethernet cable is plugged in. Nothing appears on screen. And when I try to shutdown I have to pull the plug out. If I hold the power button down to shutdown it does not respond. thanks in advance.
    Robert
  • Robert Castillo Feb 13, 2009
    I tried everything you asked I am also using the same monitor and cord I currently use with my working PC still no response. My first thought was the motherboard, but I wanted to make sure. How can one identify the mother board model to replace it.
  • Axekick May 11, 2010
    Emachine's website did not specify the motherboard for this model as they typically do.
    The following link claims it is an MS-7184. MS is the same as MicroStar. http://www.impactcomputers.com/104571.ht...
    That seems too expensive for that motherboard. I would suggest you check NewEgg, www.newegg.com for a compatible ATX motherboard that has all the slots you would need. I would think you should be able to find one for around $50. HOWEVER if you change motherboards it is unlikley that the copy of Windows you received on that computer will work any longer. You would have to contact Emachine/Gateway and inquire about that. Also, if it was damaged by a power surge it could have also damaged your hard disk, memory or any other peripherals.
    Not knowing your situation it is difficult for me to suggest a course of action. But if it were me prior to replacing the motherboard I would want to test the memory and the hard disk in another computer to insure they still function. I would also want some reassurance from Emachine and/or Microsoft that the OEM version fo Windows that came on the machine will work with a new motherboard. They are suppose to be good for the life of the motherboard so if it fails after warranty you would also need a new copy of Windows.
    If the hard disk, hard disk and memory or the Operating System would not work upon replacing the motherboard I would then suggest you simply purchase a new system.
    That MS-7184 Motheboard is the same one I have in my Emachine and know 3 friends with the same computer. They have all worked for about 4-5 years but at the time they were purchased I remember reading that the motherboards and power supplies were often faulty.
    Sorry I could not be any more help or that it appears the situation is not more promising. If I can help you in any other way message again and I will try and answer any questions you have.
    John
    I would unplug the computer, then reseat the memory, and all pci, agp and pci express cards. Disconnect all cables and reconnect them. If the monitor doesn't come on then I would try an alternate monitor AND alternate monitor cable to eliminate the possibility of multiple problems.
    I assume you don't have a boot disk? Without getting some response from the monitor it would be difficult to troubleshoot and I suspect it may be a bad motherboard but would exhaust all other options before writing it off.
    Sure thing Robert. Post me a reply and I will try and assist further if necessary. If the heatsink is really dirty it may need to be replaced.
    I have a comparable Emachine (T6412) here and it began running hot a couple month ago. I picked up some generic Heatsink-CPU Cooler at Best Buy for $39.00 and installed it. Afterwards it ran 12-15 degrees(Fareinheit) cooler than with the 4 year old heatsink-fan.
    Good luck and let me post back if you still have issues.
    John
    How long has this been happening, more than one day, days, weeks, etc..?
    Is the inside of the computer clean and free of dust and dirt.(have you blown out the inside with compressed air including any vents on the side panel or exterior casing)?
    Verify all the interior fans are working, Motherboard, Power Supply, and the exhaust fan at the rear of the case. Also verify they are all clean and turning at a reasonable speed.
    The only other thing I could think of is if there is a short but it would still seem odd that installing the side panel would somehow create the short provided no loose wires are within its path.
    Check the BIOS or install Speed Fan and check the temperatures of the computer when it starts.
    Problem Solver:
  • 7 Answers
Hi Robert,
Have you checked to see that there is no cabling of any sort in your machine that may be brushing with the side panel when it is closed? I'm thinking maybe a GRND pin from either the front panel connectors or a USB connector but this is only a guess. I am unsure why a panel could stop it turning on! Let me know if its resolved! :o)
Posted on Feb 09, 2009
  • kolrar Feb 13, 2009
    Great advice from everyone else here on this thread :)
    Model numbers are usually always found directly on the motherboard (printed directly onto the PCB)
    This should also include the revision number. Sometimes model numbers are on small stickers, on the i/o ports on the inside of the case.
    If possible, try a known working peice of ram and CPU of the same socket type. Dont bother with hard drive or any other device. This should still display the initial screen when you turn the system on. Given everyone elses advice, i think it might be the motherboard that has died.
    Someone else has given the best advice, consider a new motherboard and in turn a new system as ram speeds/types and hard drive types have changed since 4/5 years ago.
    Happy system building :o)
T6524 wont power
If it doesn't power on, make sure all the cables within the computer are attached, if it doesn't turn on still after that, the reset/power cables could be in the wrong slot, but if it powered on before this probably isn't the case.
I'd say the power supply could be blown, you may have to replace the power supply, as well as the motherboard possibly. When one goes, the other usually goes as well, but that's not always the case.
Feb 25, 2013 | eMachines T6524 PC Desktop
Emachines T6524 will not reboot, get no signal message on monitor
shut down your computer and remove the side cover and remove the memory from the slot and switch on the computer if you hear beeps switch down the computer and insert the memory if you still hear beeps means the tre is an memory failure you need to change the memory while removing memory you didnt hear any beep it means there is problem with your motherboard remove the processor heat sink and the processor clean the surface then insert the processor to the slot apply a thin level of heatsink compound and fix the heat sink then switch on the computer
Dec 29, 2011 | E-Machines eMachines Desktop PC
Want to restore os and start over. Emachine t6524
Have you tried System Restore? Restart your computer and watch for the screen to give you instructions at the bottom. It will say something like: F1 = Boot Menu F10=System Restore
It should walk you through a factory restore, which means it will take it back to factory settings the same as when it was perchased.
Feb 04, 2011 | E-Machines T6524 PC Desktop
I have an Emachine ET1331g. How do I open the casing to reveal its inner contents?
The eMachines ET1331G desktop computer uses the eMachines NexGen 3 computer case.
Looking at the computer from the Front, the Left Side Panel removes.
Looking at the back you will be viewing the Right side.
There are two screws to remove, then the side panel is slid Back. (Towards the rear of the computer)
There is a raised protrusion in the middle of the Side Cover on the back. This is where your fingers go to pull back on the Side Panel.
There is one screw coming down from the top, on the edge of the Side Panel, and one screw coming up from the bottom.
(Philips head screws)
Remove them.
Slide the Side Panel back. It will only slide back so far, as there are tabs coming from the Side panel, into slots of the computer case.
Once it stops sliding back, take it straight out to the side. Lay the Side Panel aside.
Here is a photo detailing the back of the ET1331G from eMachines Support,
http://support.gateway.com/emachines/desktop/2009/emachines/et/ET1831/ET1831rv.shtml
The two screws on the Right side, as you are viewing the computer from the Rear, as shown here.
NOTE*
1) Computer UNPLUGGED from power
2) Observe Anti-Static Precautions BEFORE reaching inside the computer, and BEFORE handling hardware parts.
Anti-Static Precautions:
Your body carries Static electricity.
Static WILL fry out (Short Circuit) the hardware components in a computer.
Computer on a table, computer unplugged from power, computer case open.
TOUCH the metal frame of the open computer case to relieve your body of Static.
Should you leave your computer in the middle of working on it, be SURE to touch the metal frame again upon your return.
For additional questions please state in a Comment.
Regards,
joecoolvette
Nov 19, 2010 | E-Machines eMachines Desktop PC
How do i restore my emachines desktop?
Go to start menu
Click on all programs
click on Emachine folder
click on Emachine Recovery Management
Click on restore on the bar across the top
click on restore to system factory default
Complete restoration takes about 20 minutes to complete
May 31, 2010 | E-Machines T6524 PC Desktop
BSOD after power failure during check disk-now I cannot reboot from recovery console or disk. How can I uninstall the OS then reinstall OS from eMachines T6524?
You need to enter the BIOS. immediately upon starting the computer start tapping either the F2 or the tab button. Once in the bios, go to boot order and set the cd/dvd drive as the first boot priority, hard drive second. It is ok to leave this permanently, save and close settings which will reboot the system and considering everything goes as planned you should be able to start up from a disk and then repair or replace XP. When replacing XP remember to delete partition and write a new copy. THIS WILL ERASE ALL INFO ALREADY ON THE HARD DRIVE!!!
Feb 23, 2010 | E-Machines T6524 PC Desktop
T6524 bios update needed
This isnt necessarily a bios problem mate , its just windows got corrupted during the power surge. Use the link below to do a repair install. Note , repair installs do not erase your personal files or setings or software !
http://michaelstevenstech.com/XPrepairinstall.htm#RI
Hope this helps you
If you found this solution helpful , please rate below
Kind Regards
1234s282
Jul 02, 2009 | E-Machines T6524 PC Desktop
Need a SM Bus Controller Driver
Try this link it's the company's website. Download all drivers and install. I hope this helps.
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T Series&model=T6524
Apr 17, 2009 | AMD Athlon 64 3500+, 2.2GHz...
Updating my T6524
If the device is working, why update? What R U trying to fix?
Jun 09, 2008 | Computers & Internet
eMachines T6524  PC Desktop Logo
219 people viewed this question
Top eMachines Computers & Internet Experts
Michael Vincent Cruz
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
