Question about Canon PIXMA MP150 All-In-One InkJet Printer
I am gettting the "error 6000" message every time I try to print a document. I was told by a technician to download a registry fix program, but I don't know which sites to trust and which not to. Also, is there a free site (no cost at all) for this, as I am uncertain that it will fix the problem.
I had a error 3 that I cannot delete. What will I do? my printer is Canon 145.tnx
Posted on Feb 02, 2009
Error 6000
If you're gettting the message "Canon printer error 6000," it may be related to a LCD error, so to fix it reset the printer by pressing the ON/OFF button.
It can also be related to a paper jam, so check for that and if you have had one and cleared it, make sure there is no paper left inside. Once this is done, again reset the printer
Jun 05, 2014 | Canon PIXMA MP600 all-In-One InkJet...
Everytime I go to print a document, printers, alarm comes on and it says error 6000. Im not sure what to do. Do I need a technician?
Yes you will need a technician. basically it sounds as if the timing **** disk has fallen off the end of the platen so the machine is not able to feed the paper or print.
Jul 04, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Error 1402.Setup cannot open the registry kaey. HKEY_LOCAL_MACHINE\Software\Classes\CLSID\{7EA9A8FA-F5D2-49E1-99E8-C26EE07FCEEB}\LocalServer32.
The first thing you should do to fix this error is - if you're using Windows 98 or 2000 - to use the 'registry checker' facility. This is done by loading up the "Run Console" with CTRL + R and then typing "registry checker". If the registry is intact then this will not be a problem. On later versions of Windows, you should use a 'registry cleaner' program to perform this task.
If you have XP, Vista or Windows 7, you should first download a registry cleaner from the Internet and let that scan your system. It will look for any registry errors on your PC and then fix them, which should fix the 1402 error in the process. To use one of these, you need to download a registry scanner program and then let it scan your PC. It will identify all the damaged parts of Windows and should fix them. And if one of these registry errors is causing the 1402 error then a quick restart after the registry scan should enable you to install Office or the program you wanted.
If that method did not work, you should try using a different user account, or creating a new user account, to install the program onto. It's often the case that user accounts will become corrupted for whatever reason, blocking access to the registry. This causes the 1402 error because it means that the program cannot access the files and settings it needs to create when it's being installed. You should try creating a new administrator account and then installing the program on that.
Jun 08, 2011 | Microsoft Windows XP Professional With...
Down loaded Yahoo Messenger. Keep getting ERROR Msg..file:///C:/Program%20Files%20(x86)/Yahoo!/Messenger/pcRC9jQlClDtY7lIaoW_LQ. HOW do I FIND and Fix??
Hi, Katie. Please uninstall the Yahoo Messenger from the Computer using the software called Ccleaner.
You can download the Ccleaner from the below link:
http://www.filehippo.com/download_ccleaner/
After uninstalling the Yahoo Messenger using Ccleaner, select Registry Menu in the CCleaner and click on Scan for Issues. Now click on fix selected issues button, it will prompt to backup the registry so click yes and save it in My Documents are any place you like to store.
Now click on Fix All Selected Issues to clean the Registry!
Please download the latest version of the Yahoo Messenger from the below link:
http://www.filehippo.com/download_yahoo_messenger/
That's it! Yahoo Messenger will now work without any errors.
Apr 29, 2011 | Yahoo Messenger
Printer error has occurred 6000
Error 6000 gets displayed when there is a paper jam or other general malfunction. When the message "6000 Printer error has occurred. Turn off the printer then back on again. If the problem persists, see the manual." Is displayed, something may block the paper feed tray from opening.
If the printer is surrounded with documents or when you copy large documents such as books, make sure that you secure the clear space in front of the tray before printing / copying. When the error message above is displayed and if you find something is in front of the tray, remove it. Then, turn OFF the printer and back ON again and the printer will be ready for printing.
If you still have the trouble, contact the repair service.
Check the printer for any paper jam or try to reset the printer to release memory code errors.
1. Press and hold the Resume button for 1 - 2 minutes.
2. Open the cover.
3. Remove the cartridge and then reinstall it.
4. Close the cover.
5. Turn Off the printer.
6. Turn On the printer.
Feb 14, 2011 | Computers & Internet
Printer Error message : Printer Error has occurred. 6000
2. Open the cover.
4. Close the cover.
Dec 21, 2010 | Canon Office Equipment & Supplies
I ran pcdecrapifier and now i am getting the mywinlocker error message. I think the decrapifier didn't remove it completely. How do I make this error message stop popping up every time my system boots...
I use program called Ccleaner and it has utility to fix registry problems which this looks like. Try downloading and scanning your registry see if you get anything. Good Luck.
Apr 26, 2010 | Computers & Internet
Canon PIXMA MP150 All-In-One InkJet Printer Logo
48 people viewed this question
old marine
old marine
Corne Viljoen
