Question about Cobra Digital DC4330 Digital Camera
I pressed format one to many times, now my camera wont turn on, a red light will be on when i hold the on/off but then goes off when i let go. is my camera done for? or isit fixable
    Brigadier General:
  • 5,158 Answers
Perhaps go here http://cobradigital.com/download.php you can get the manual and software for that camera. perhaps reinstalling the software will fix it.
Robert
Please rate this solution... thanks
Posted on Feb 01, 2009
  • Roberta Smith
    Roberta Smith Feb 01, 2009
    please consider bumping this up to a fixya... thanks
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Kodak camera C653. Camera will not come come on after green light blinks.then the red light blinks and the camera goes off Batteries is not the problem
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 17, 2011 | Kodak EasyShare C330 Digital Camera
My sony walkman suddenly stopped working while out on a run, On returning home I checked that it was fully charged & now it seems to do its own thing, if I can get it to work
Try resetting the Walkman by pressing the RESET button located near the Jog Dial.
Press the reset button using a sharp pointed object like a ball pen. Be sure that the Walkman is playing when resetting.
Try connecting the Walkman Player to the Computer by using the stand to charge the battery and check if it works normally.
If the issue persists after resetting, try Formatting the Player back to factory defaults. Formatting the Player will erase all the files and all the settings will be back to factory default. Please be sure that a backup is there with you before formatting the player.
To Format the Player, unite the left and right parts to turn off the Player.
Separate the left and right parts.
Press and hold the jog dial for about 15 seconds until the status lamp blinks quickly.
Release the jog lamp when the OPR Lamp lights Red.
Rotate the jog dial within 30 seconds after the OPR lamp lights Red.
The status lamp turns off and the OPR Lamp lights alternately Green and Red each time you rotate the jog dial.
Press the jog dial while the OPR Lamp lights Green.
The OPR Lamp blinks Green quickly and Formatting is executed.
When the OPR Lamp turns off, formatting is complete.
If you press the jog dial while the OPR Lamp lights Red, or if 30 seconds have passed, formatting will be canceled.
This will resolve the issue.
Thanks for using FixYa.
Dec 08, 2010 | Sony Walkman NWZ-W202 MP3 Player
I have M1033 - when the shutter button is pressed half way down it wont focus and shows a red AF on screen. The pics are blurred. Batteries have been changed and lens cleaned.Help please
The red AF is autofocus. If it is red it isn't focused. You will have to hold the button until the red light turns green, then release the button.
Jul 08, 2009 | Kodak EasyShare M1033 - black Digital...
Bell express vu remote codes for soyo tv
1 - Hold the clear tv buttom until all 4 light flash red
2- Press the red tv buttom
3- Press the amount of time needed on the up cursor ( around select buttom) until your tv shut down
4-When the tv goes off press the search buttom ( at the end on the right side )
5-Press record
Then u can use the red tv buttom to control ur tv and u can control the volume on satelitte mode without going back to tv mode , if u press too much time while searching the code and the tv wont light back , do the same thing but instead pressing the up cursor press the down one to go back on the code it will be faster .
Jan 02, 2009 | Soyo Crystal DYLT032B 32 in. LCD...
When using flash, my sony cyber-shot dsc-t10 takes forever to take pictures!
Have you tried Hi-Speed memory cards, as writing speed of the card affects the response time of camera, I am using Sony MSX-M2GN 2GB and it's gives me quite good response.
Other thing you might try is format the memory card using camera, camera has card format functionality and it does also improve the performance of the camera.
Jul 16, 2008 | Sony Cyber-shot DSC-T10 Digital Camera
Doesn't turn on, red light & flash pops up
most probably your charger inside the camera has gone bad. Get an expernal samsung charger.
Mar 28, 2008 | Samsung NV10 Digital Camera
Cobra Digital DC4330 Digital Camera Logo
29 people viewed this question
Top Cobra Digital Cameras Experts
Daniel Dollive
Daniel Dollive
Greg Cann
Greg Cann
Are you a Cobra Digital Camera Expert? Answer questions, earn points and help others
