Question about Compaq FS7600 17" Flat Glass Monitor
Monitor keeps stating "monitor going to sleep" now awhile after booting up. The monitor works fine with other computers and the computer in questioning when in safe mode - yet if tried to boot normally, the monitor says going to sleep. Recently, I used that monitor to work on another PC but didn't touch the now affected one - but after plugging it back into the old one.. this is the issue
  • EricDaniels
    EricDaniels May 11, 2010
    What kind of video card do you have. You probably need to install the drivers for it whilst on safe mode.
    President:
  • 2,992 Answers
This is probably a video setting issue. In Safe Mode, Windows starts with low resolution and color settings, so the monitor can display them. But when it tries to start normally, Windows is using a video setting the monitor can't handle.
Start the computer and press the F8 key three or four times when the manufacturer's logo screen appears. This should get you to the Windows startup menu screen, and you can pick the option of starting in VGA mode. This will start Windows with video settings any monitor can handle.
Once you have Windows up and running, make sure the video card and monitor types are properly set up. It would also be a good idea to download and install the latest drivers for your video card. You can usually find them at the manufacturer's website.
Posted on Feb 05, 2009
Looking for drivers to use this monitor with Fedora 20 Linux OS
You don't need drivers. You need to adjust the resolution and refresh rate. If you plug in an old CRT monitor then Linux will probably boot and you can edit the conf file to change the settings. Most LCD monitors require 50-60Hz refresh rate.
May 05, 2014 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
The monitor will go into sleep mode, and when first booted up will not register anything and goes to sleep. Have tried re-booting, checking the chords, plugging and unplugging them in. To no avail it...
No pc stated just monitor. (not even desktop or laptop) stated.
no OS stated, ether.
so ill answer in wide generic ways....
all computer are a problem, since days of Mr. Allen Turning to now.
ive done 43years of them just puters.(and other big systems MIL)
no person on earth can answer that common question
gee no pc stated,! nor can we lay blame until its fixed can we. ever.
3+billions of transistors. mine here typing now.
4,800,000,000, and friends, lots of other things to fail even LCD
its not a toaster or 4 banger calculator, at all.
its COMPLEX but 1 of those 2 boxs or cable are bad. sure.
(viewed in the MACRO)
sleep? how do you know it is sleep.
the screen showed that. text said SPEEP?
is the screen totally dead. (that is not sleep if true)
is the screens OSD button dead?,
the only clue i have here is one word, REGISTER (good word just too few)
so the screen never ever shows any text or HP logo ever
booting with monitor on for 5min. power on PC, see words?
no text ever...so.
then push the monitors.
Select menu buttons on front of monitors. and the OSD pops does it , it must....!!! see image below (mine is Viewsonic, near new)
there are many simple tests here.
  • try you monitor on any other PC
  • or try you pc on any other monitor
easy no.?, just 1 or 2 tests and bam, who's bad.
called the process of elimination..
but OSD is first. no matter what,.
if the screen tests ok,, (display tests and its buttons)
then the PC is problematic, (1/2 the battle won)
the first thing to do (tell me what pC) but turn off all sleep
modes in the CONTROL PANEL + POWER SETTINGS>
do that first. if you can even get the screen to work.
A pc never boots to sleep so.....
the PC can have 2 VGA jacks on the rear.
the PC can have DVI jacks, using those are you
try them all yet?
if you test the PC and it works and the screen works the cable is bad.
omg that screen is new, its even sold now at walmart.
not cheap either, too much, kinda
this is a modern 22" screen, LED>
and do not just go bad, is the power pack there and correct?
if the OSD screen is dead, check power first.
this is the Monitors brain, it works even with the PC dead.
the button is marked menu or select. this is test1.
osd-1z31dkbg41o2owghj0fas5br-1-0.jpg on my monitor ,heck all 2004 up
it tells you SLeep mode when the PC goes to sleep mode
or shows Power saver mode. live on the screen.
screen power on first sure.
all ways to go black done here.
http://pcdied.com/black-screen.html
Jul 20, 2017 | HP w2207 Monitor
Using a HP L1506 Monitor on a HP Pavilions a 867c computer and has worked, but now receiving "VGA input: no input signal" with window on monitor, followed by "Monitor going to Sleep" and it does. Worked...
First of all, boot your system without the monitor connected to it and when you feel that it's booted upto logon screen (or if you haven't assign password it'll directly logon to the desktop, power on the speaker to make sure you can know it's done) connect the monitor. If this isn't successful, please turn off the system and remove the cmos battery, leave it outside for few minutes and again reinstall it. Boot again normally. Still having the same problem? then let's try another method. Did you see the bios loading (black screen with white text during startup) when you power on the system? If so, press F8 several times while it is booting and select "Safe Mode" and restore your system to previous state. Do let me know if this isn't possible. Good luck Thanks for using FixYa.
Jun 10, 2010 | HP Pavilion F1703 17" LCD Monitor
I have a HP monitor for 2yrs now. It was working fine until recently I noticed that whenever I boot up the monitor goes into sleep mode and the PC is not coming on. How can I resolve this problem and can...
The problem you are encountering is not your monitor but your computer. There is a problem with your CPU unit. To know this info in true then try this.,remove the connections of the monitor from your own computer then use the monitor to the other computer and see. Hope this could help you determine the real problem.
Oct 26, 2009 | HP Pavilion F1703 17" LCD Monitor
Monitor going right to sleep mode on start up
Sounds like a bad graphics card. Try using monitor wit another computer and see if the problem still exists. This rules out the display.
Jul 25, 2009 | HP w1907 LCD Monitor
Monitor keep going into "sleep" mode
Check the power setting in control panel of windows. If you have a monitor from another computer swap them and see if the problem stays with the computer or monitor.
May 12, 2009 | Dell Dimension 3100 PC Desktop
Hp L1706 Monitor Keeps Going Into Sleep Mode
I have an hp media center that runs windows xp with service pack 3 and my monitor is an hpL1706 monitor and was running fine now it says no input and goes into sleep mode how do I fix it?
Apr 10, 2009 | HP Pavilion F1523 15" LCD Monitor
My W2207 monitor keeps going to sleep
Hi,First there is no signal from the PC . check if the display card has come out while moving the monitor, or just reinsert the display card in the PC , then boot the pc .
Jan 14, 2009 | HP w2207 Monitor
Monitor keeps going i to sleep mode
Check the cable it's not connected correctly or check you CPU is it working fine.
Dec 08, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Monitor going to sleep at startup
try changing the video card of your computer..
Aug 27, 2008 | HP vs19 (Silver) 19" LCD Monitor
Compaq FS7600 17" Flat Glass Monitor Logo
355 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
