Question about Sony KP-46WT510 46" Rear Projection HDTV
My sony 46 kp46wt510 panel tv has red outline on images
There are red shadow on the images could it be the bulbs that need to be replaced
  • Sony Master
  • 8,617 Answers
Its more likely needing the convergence ICs replaced. You can get the convergence repair kit for your model at the following link which contains both IC the six pico fuses and four of the feed resistors, The kit comes with instructions. Heres the link.
http://servicemanuals.vstore.ca/product_info.php/pName/sony-kp46wt510-convergence-repair-kit/cName/convergence-repair-kits
Posted on Feb 01, 2009
Our tv has red and green shadows on the picture when words come on at the bottom of screen they look like a shadow double Peoples faces will be outlined with red and green lines
your color engine is failing its also known as the optic block and they are very expensive to replace good luck google the optic block failure in these sets to better educate yourself with what your dealing with ok it most often blue that shows the failure but green and blue to and red
Dec 21, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
All the lettering on my screen as well as images have a red shadow
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.These parts on the tv convergence board,must have to be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 21, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
I have a Mitsubishi HD1080 46 inch TV. The projection shows a concave picture and there are red and green outlines like a 3D image but without the glasses. This problem has come and gone in the past now...
I have the same problem. At first I thought the TV just needed some warming up because after a while it would resolve itself. Now, even after hours of being "resolved" it will occassionally revert back to the concave image! Have you gotten any feedback or resolution?
Oct 19, 2010 | Mitsubishi Televison & Video
Have Sony KP-57ws500 rear projection i had the bulbs replaced 3 years ago now itseams as if everyting is out of focus.images outlined in green and red.
It sounds TV got convergence out ICs failure problem and causing 3D image or outlined picture.
There are 2 convergence out ICs mounted on D board in TV that need to be replaced.
Let me know if you need part number of ICs if you want to replace by yourself or call local Tv tech to fix it.
Thanks.
Dec 04, 2009 | Sony KP-57WS500 57" Rear Projection...
KP-46WT510 Red lines and double vision
yes the convergence problem leaves a shadow of red or blue like an outline around the picture, sometimes part of the screen some times the entire screen.
Jun 26, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
My sony kp46wt510 has a red shadow behind the pictures
Check for open pico fuses,open/burned resistors in conv.circuit(STK392-560
conv.IC).
Jun 06, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Ghost shadows on the Sony KP-46WT500TV
you can get the KP46WT510 convergence repair kit at the following link under convergence repair kits category which will also work for your model.
Apr 12, 2009 | Sony KP-46WT500 46" Rear Projection...
Red ghost in the screen
you can get the KP46WT510 convergence repair kit which will usually repair that issue at the following link the repair kit contains both ICs six pico fuses and 4 of the feed resistors also includes instructions with pictures on how to do the repair.
Feb 09, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Image on tv casts a red shadow.
TRY THE MAGIC FOCUS BUTTON. IF THIS DOES NOT CORRECT THE PROBLEM YOU WILL NEED A SERVICER TO GO IN AND REPAIR CONNECTIONS OR REPLACE THE CONVERGENCE IC'S AND OR RESISTORS. AND READJUST CONVERGENCE IN THE SERVICE MODE.
Jan 07, 2009 | Sony KP-57WS500 57" Rear Projection...
Convergence problem with my KP46wt510...!
They go on the largest heatsinks in your set---the " back" side,
if you look over & down......that PC board must come out to
replace IC's.......
Nov 05, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-46WT510 46" Rear Projection HDTV Logo
878 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
