Question about Kenmore Dryers
Dryer I dropped a pen in the lint trap on top of the dryer how do i get it out
  • 29 Answers
Your going to have to remove the back panel and then access the filter air chamber. Or get a couple of strong fellows and have them un plug it and then flip it over and bump it a few times and hope it falls out. Dont reast its weight on the control console. Best o Luck
:?) DRRXR
TIP OF THE DAY--To reduce the suction draft and drying time your drier and save some cash, remove the lint catcher and take it to the sink. Run water into it, if there is excessive pooling of the water (water not running straight through) then fabric softener is fouling the lint screen. Use a small brush and dish detergent to clean it and then shake off all the water and dry the screen. Remember this tip on future driers and you will make the dryer blower motor last much longer.
Posted on Feb 08, 2009
How do I retrieve a stick dropped down the lint chute?
if there is no water any where I would first use the wand of a vacuum cleaner that is going ( not the head just the pipe section)
Oct 11, 2015 | Dryers
Carbio Dryer Lint trap won't go back in.
If its that kind that is curved slightly and drops in from the top then most likely there is a lose screw head sicking out blocking it. Most dryers the top comes off after removing four screws or so. Then you can look inside. If you have to get into the back though you will have to remove more but its mechanically very simple. Just a drum with a motor and a pully that has a timer. If it has the lint trap inside the door then your best bet is that something came loose and is obstructing it. Again probably a screw or piece of plastic.
Dec 07, 2014 | Whirlpool Cabrio WED7600XW Electric Dryer
How do I recover pen which dropped thru my filter trap?
This could cause motor fan system to lock up if gets caught in fan also could brake open staining clots should be taken apart and recovered b4 useing front of dryer need to come off
Jul 15, 2014 | LG DLE2532W Electric Dryer
Dropped something down the lint trap
If it's a metal utensil that responds to magnetism, try a magnet on a string, or one of those telescoping magnetic picker-upper tools to get it out.
Jan 22, 2014 | Amana NDE2330AY Electric Dryer
Dropped pen into lint trap. Now Dryer makes a screeching noise.
The pen has fallen into the blower housing and is hitting the fan blades.
Unplug the dryer!! Remove the two screws at the top of the lint trap. Remove the rear panel. Remove the four screws at the bottom that attach the lint filter housing to the blower housing. Then, remove the pen from the blower housing.
Apr 06, 2010 | Kenmore Dryers
A PEN WENT DOWN THE LINT TRAP AND NOW THE DRYER WONT TURN ON. KENMORE GAS DRYER
can you move the drum by hand?if not the pen is jammed in the blower wheel stopping the motor from turning,if the filter is on top you'll need to remove the filter,take out the 2 screws in front of the filter now make sure the dryer is on a flex line so you can pull it forward to remove the lint filter and then remove the back panel,now you need to remove the 4 screws holding the duct on that the filter slides into and remove the pen and any lint that's in the duct,if the filter is inside remove the bottom panel,remove the filter and take off the duct and clean it out,next time send model number
Feb 15, 2010 | Kenmore 73952 Gas Dryer
Combination washer dryer full laundry center does not heat to dry clothes
1) check the lint trap, and reach way into the dryer to remove all lint.2) Look at the dryer motor, and make sure that it spins freely (toys and small objects fall into the lint trap and drop into fan. While there make sure you remove all lint
Aug 29, 2009 | Frigidaire Dryers
Dropped bleach pen into lint trap. How do I get it out?
its not too hard to get out.
you will need a #2 phillips screwdriver and or a 1/4" socket driver
remove lint trap
remove 2 screws at lint trap
unplug unilt
open the top (2 clips between lid and front panel in the crack, push them with a butter knife or putty knife to release top) opens like a hood
pull out dryer and pull off rear panel
on the left hand side there is a metal duct like thing lol
that leads to the lint trap at the top.
there should be 4 screws at the bottom where it gets round.
remove them, and wiggle the duct open. your pen should be there..
May 25, 2009 | Kenmore 62602 Electric Dryer
Dropped something in dryer trap
You can gain access or remove the lint trap by popping the top of the dryer up, then remove the front panel.
Apr 18, 2009 | Dryers
Dryer
forget dryer ck vent to outside look for kinked or flatened hose behind dryer find out side vent hood and ck air flow to verify vent problem try drying load without hose connected to dryer may get warm and a little dusty in room but worth it to verify fix
May 02, 2008 | GE WSM2420T Top Load Stacked Washer /...
Dryers Logo
135 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
