Question about Yamaha GX-505 CD Shelf System
GX50 mini system CD table will not close
The CD table is in the open position and will not fully close
The table does not open
Posted on Sep 24, 2010
2001 cadillac deville sunroof open and want close
Check the RAP fuse in the rear fuse box , this fuse powers the sunroof control module ! Fuse Block - Rear , Left rear of the passenger compartment, under the rear seat .
The sunroof module contains the logic for the opening and the closing of the sunroof. The sunroof motor assembly contains the reversible DC drive motor, the gear train, and the limit switch.
The sunroof module determines the sunroof motor direction based on inputs received from the overhead console sunroof switches. When the ignition switch is in the ON position or when retained accessory power (RAP) is active, voltage is applied to the sunroof module via the RAP relay. For a description and operation of the RAP system, refer to Retained Accessory Power (RAP) Description and Operation in Retained Accessory Power. The sunroof module controls the sunroof motor direction by changing the polarity of the applied voltage. The sunroof module remembers the sunroof position whenever the ignition switch is turned to the OFF position. The limit switch is used as an input to the sunroof module to indicate that the glass is fully closed, or in the comfort stop positions. The limit switch is grounded when the sunroof glass is in the fully closed or comfort stop positions, otherwise it is open.
The SLIDE CLOSE mode is initiated by moving and holding the sunroof slide switch (ROOF) forward. This applies a ground provided from the sunroof limit switch low reference circuit to the sunroof switch close vent signal input of the sunroof module. The sunroof module controls voltage to the control circuits of the sunroof motor. The sunroof motor will run until the limit switch contacts are closed. The closing of the limit switch will apply the sunroof limit switch low reference circuit to the sunroof limit switch soft stop signal circuit to the sunroof module, indicating the flush closed position has been reached. As the sunroof is approaching the close position the sunroof glass will force the wind deflector downward.
You need to have a factory scan tool hooked up an have it checked for DTC'S in the sunroof control module ! a code reader will not do this , a code reader will only check the engine codes for OBD 2 .
Important: The following must be completed before using the symptom tables.
  1. Perform Diagnostic System Check - Power Sunroof in order to verify that all of the following are true:
  2. ?€¢
    No DTCs are set.
    The control modules can communicate via the serial data link.
  3. Review the system operation in order to familiarize yourself with the system functions. Refer to Sunroof Description and Operation
your better off taking to the dealer !
May 09, 2015 | 2001 Cadillac DeVille
I took out all discs. When I tell it to play a disc the table moves back and forth slowly about an inch. After a couple trys "Table Error" shows up. Both belts are old but on.
Tray will prolly need retimed after the belts slipped off the pulleys.
Procedure is with tray brackets removed lift tray in back then push open button to let the cam gear spin around to open position. Then let tray down and try to close it with button. Reinstall brackets and may take a few attempts to get that gear in the right position!
Dec 16, 2014 | Sony CDP-CX300 CD Player
Whilst the cd drawer was in the open position I caught it with my knee leaving the drawer on an angle. When I press the close button nothing happens and any attempt to close manually is met with...
drawer is out of alignment...some players have timing marks to align the gears(similar to engines)...but without a service manual..it may be complicated...you can try to realign the drawer...there is a limit switch that tell the player when the drawer is fully open and one that tells the player when it is fully closed....a good way to try to realign is to move the drawer one tooth at a time and trying it..until it lines up
May 26, 2011 | Marantz PMD320 CD Player
CD Player Tray keeps opening and closing by it self
This is either caused by the drive belt slipping, the closed sensor being faulty or an obstruction to the tray.
Basically the tray isn't makeing it to or registering as being in the fully closed position.
May 02, 2011 | Tascam CC-222mkIII CD Player / Recorder
How to reset the CMOS on Dell GX50
Disconnect the power lead from the back of the case, open the side of the case and look for the CMOS battery, it looks like this >>>
Remove this battery for 20 minutes and the put it back, close the case, reconect the power lead and turn the machine on. You will however have to set the date and time and also set any BIOS options you want.
Regards.
Dec 14, 2010 | Dell OptiPlex GX50 (GX50SC1338420) PC...
Screen goes black when opened fully, reappears when closing it
The problem you seem to have is the thin wires that carry the picture to the LCD screen may be broken or making and breaking, you certainly wont be able to repair yourself, get it to a good camera shop for first aid.
Jun 11, 2010 | JVC GR-D850 Mini DV Camcorder
Dell Optiplex GX50 won't load windows OS
Which cdrom is it? Is it a windows XP cd? This is an older PC? Does it have a floppy disk drive? Try downloading from Barts a bootable floppy disk, set boot order to floppy in BIOS, change to cdrom drive letter after booting to floppy (D:?)
got to I386 folder and set up from there.
More info would be helpful.
Jul 09, 2009 | Dell Optiplex GX50 Intel Desktop PC -...
Technics SC-CH515 CD Tray Does Not Stay Open
I DO NOT think that problem related with CD cleaner
3 possibility here
1 The loading belt was lose it can not open fully to reach the switch open when the time limited was out as program design from system control it automatic close
2 The loading gear system out of position 1 tooth
3 Dry joints on switch open and close or connector from CD tray to system control intermittent contact
In any case it require a qualifier Tech from Panasonic to reset the timimg gear or service
I hope that give you some ideas if you need further info or service manual I am willing to help you out
Cheers
Dec 08, 2008 | Technics Audio Players & Recorders
Electronic repair
the drawer is not seating all the way with the disc, open to make sure nothing is blocking the disc when it slides in.
Oct 08, 2007 | Sony CMT-EX100 CD Shelf System
Yamaha GX-505 CD Shelf System Logo
184 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
