Question about GE Kitchen Ranges
Oven Wont Preheat
I have a GE range. The stove burners will light just fine. The broIler will also start up after about 20 seconds. When I select the preheat bake selection nothing happens.
  • corkbarkgeck Feb 01, 2009
    The bottom element does not get hot as far as I can see.
  • 56 Answers
Does the bottom element get hot? could be a bad heating element.
Posted on Feb 01, 2009
  • shockman1157 Feb 02, 2009
    Look for bubbles or blackend marks on it, sounds like it is the element, contact the store where you bought it for parts,I thats not possible and a service center (maybe SEARS) can do it,If you want to tackle it yourself parts should not be to bad to find,MCM electronics used to carry elements but I dont know for sure any more,Thanks if i can help more write back. ( check for bad connections, burnt wires before buying an element,disconnect element and check with an ohm meter)
The problem is with the ignitor that lights your oven...
You will have to replace it because it has burnt out.
Here is a tip that I wrote about this problem...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Heatman101
Mar 03, 2010 | Kitchen Ranges
Broiler and top stove burners work, but oven doesnt
Your glowbar ignitor for the bake burner is bad.
Use the attached diagram to show location.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5221257
Dec 26, 2009 | GE Adora JGBP87SEMSS Stainless Steel...
Xl44 oven burner pulses, doesnt properly heat up.
it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
Jul 30, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven will not light
check the gas valve to make sure a mouse did not chew the wires.
Jan 31, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Bake and Broiler do not work
it sounds like you have a bad eoc which is electronic oven control that is the only thing it could be if your top burners are open
Dec 28, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven produces soot when running, broiler ok, stove top ok
Al, you need to seat the needle valve on the bake. Remove the bottom drawer, right below the bake burner you will see the nut just below the air shutter adjustment. Turn this nut clockwise a few times, it might seem hard but just do it. Then try the bake again, you should have a nice bluel flame. Tenbears.
Dec 20, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Kenmore Propane Range won't bake
The glow plug underneath the over floor need to be replaced
Dec 19, 2008 | Kenmore 36665 / 36669 Gas Kitchen Range
Oven wont work at all.
Convection oven and Bake will not heat past 200degrees. Broiler works fine and the range works fine.This is for the Model # MGR5875QDW, Gas Precision Touch Control 800, can you help. Thanks Kasz3
Dec 24, 2006 | Maytag MGR5875QD CleanDesign Gas Kitchen...
Kitchen Ranges Logo
342 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
