Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Win xp sharing connecion
Can u conf to me because iam using win xp 12 machine and enable sharing but only 9 machine connect at a time with main machine any other machine connection not connect  and i hv chk they allow only 10 maximum connection in a single time so can u conf i am increase this connection any option avilable in win xp machines
  • 4 Answers
For Windows XP Professional, the maximum number of other computers that are permitted to simultaneously connect over the network is ten. This limit includes all transports and resource sharing protocols combined. For Windows XP Home Edition, the maximum number of other computers that are permitted to simultaneously connect over the network is five. This limit is the number of simultaneous sessions from other computers the system is permitted to host. This limit does not apply to the use of administrative tools that attach from a remote computer.
Posted on Feb 01, 2009
VISTA Business cannot 'see' XP machine in same workgroup
Check that the two machines are in the same workgroup on network settings.
Oct 14, 2008 | Microsoft Windows Vista Business DVD...
I want to share an HP 7760 on an XP with Win 7
To get ahead of myself and answer your question first, your Win 7 machine may automatically load a driver for your shared printer.
Please have a look at the procedure below: (these instructions assume that your XP machine is sharing the HP printer and that your Win 7 laptop can "see" your network and the shared printer connected to your XP desktop computer)
On the Win7 machine, follow these steps:
1) In "Control Panel" click "Add local printer"
2) Create New Port > Local port
3) Port Name is "\\xpcomputername\printername" - without the quotes
(insert the XP's real network name and your printer's real name in the above location)
4) Click <OK>
5) Windows 7 should automatically load a driver allowing you to print on the HP connected to the XP from the Win7 laptop.
I hope this helps!
Mar 07, 2010 | HP PhotoSmart 7760 InkJet Printer
Just bought win 7 laptops wont connect to my lexmark x1180 printer connected to my desktop running xp any ideas?
Enable File and Print Sharing on your XP system.
Click Start
Click Control Panel
Click Printers
Enable "sharing' for the printer.
Click Start
Right-mouse click My Computer
Click Properties
Click Computer Name
to show the current "workgroup" name on your XP system.
On the Windows 7 system:
Configure it into the same workgroup.
Then, "Add Network Printer", connecting to your XP system, and pointing at the shared printer.
Dec 10, 2009 | Lexmark X1150 All-In-One InkJet Printer
Vista Laptop cannot connect to XP users
go to control panel>>add and remove prgrams>>click on add/reomve windows components on the left panel.
make sure you have the system CD.
put a check mark in "networking services" and "other network files and print services" install the addtional services.
check the share volume, make sure you have given the user rights to access the drive.
Jan 30, 2009 | Microsoft Windows Vista Ultimate Edition
Need drivers for 4930 windows xp
GO HERE http://www.vocidalweb.it/?p=1235&akst_action=share-this
This is the only place to get them all.
PLEASE RATE THIS A FIXYA.
Jan 21, 2009 | Acer Aspire 4930-6862 Laptop
Printer sharing
Appreciate the direct "Ask Me".
Initially, pls try enabling the Share feature of the printer in XP. Pls go to Start, Printers & Faxes, right click on the printer you want to share, click on Sharing...follow on screen instructions. A few suggestions:
  • verify that the Vista and the XP uses the same Workgroup;
  • verify that other shared folders and files could be viewed from each other;
  • verify that each could access the internet from a single connection.
A few questions:
  • do you have a router or a hub;
  • how are the XP and Vista connected to the network, LAN cables or wireless.
  • confirm that it is a HP > PSC 1510 All-In-One InkJet Printer that is connected to the XP machine.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 19, 2008 | HP PSC 1510 All-In-One InkJet Printer
Too many connections win xp
In Windows XP Professional the maximum is 10, but you can set this to a lower value. You can use the Shared Folders snap-in to determine the maximum number of users that are permitted to access a folder. In the Shared Folders details pane, click the shared folder for which you want to determine the maximum number of concurrent users who can access the folder. On the Action menu, click Properties, displaying the Properties dialog box for the shared folder. The General tab shows you the user limit. Remember Win SP the maximus is 10. You can also use the Shared Folders snap-in to determine if the max numberof users that are permitted to access a folder has be reached.
Determine the number of connections to the share and the max connections allowed. If the max number of connections has already been made, the user cannot connect to the shared resource.
Jun 14, 2008 | Microsoft Windows XP Professional
Adding additional computer problem
Yes, the xp machine connects to the net. DHCP is not enabled. The ipconfig/all command brings up the correct static ip address, subnet mask, and default gateway. But it does also say under the ip configuration that ip routing is not enabled. I did have the 2000 machine connected when I first set up the router yesterday, but I booted up my laptop to try to set up a wireless connection, and then I had to reinstall the entire router set-up.
Jan 12, 2008 | Linksys Wireless-G WRT54G Router
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
85 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
