The remote stopped working so I changed the batteries. It only holds the display for a few seconds, then goea blank. When I press the reset button, the same thing happens
Point the remote control at the camera in your cell phone. Press a button and see if you can see the LED flashing. If it doesn't the remote is history. If it does, then the sensor on the main board of the TV isn't working. You canbget parts here : TV Parts Universal TV Stands DLP Chips ShopJimmy
To better answer your question it helps to know if the key fobs worked before and just stopped working, or if you bought a new key fob.
If you bought a new key fob you must program it to your vehicle. Here are the key fob programming instructions for a 2006 Chevy Monte Carlo:
NOTE: 2O11 & newer vehicles must be programmed by an automotive locksmith or dealership.
PROCEDURE #1
THIS PROCEDURE IS FOR VEHICLES WITH THE DRIVER INFORMATION CENTER. IT WILL BE A BUTTON TO THE RIGHT OF THE STEERING WHEEL WITH A VEHICLE ICON AND THE LETTER i.
Insert key and switch the ignition ON (just shy of starting vehicle without cranking engine)
Press vehicle information button until PRESS TO RELEARN REMOTE KEY is displayed.
Press the set/reset button (button will have a check mark) until REMOTE KEY LEARNING ACTIVE is displayed. Vehicle is now in programming mode.
Press and hold LOCK and UNLOCK buttons at the same time on first remote for approximately 15 seconds. An acoustic signal will be heard indicating successful programming.
Repeat step 4 to program additional remotes. You can have up to 8 programmed remotes for this vehicle. You must program ALL remotes including existing remotes.
To exit programming mode turn ignition OFF, remove key and test all remotes.
PROCEDURE #2
THIS PROCEDURE IS FOR VEHICLES WITHOUT THE DRIVERS INFORMATION CENTER.
Insert key into the ignition and turn to ON (Just shy of starting vehicle without cranking engine).
Press the trip odometer reset button until RELEARN REMOTE KEY is displayed.
Press and hold the trip odometer reset button for approximately 3 seconds until REMOTE KEY LEARNING ACTIVE displays.
Repeat step 4. to program additional remotes. You can have up to 8 programmed remotes for this vehicle. You must program ALL remotes including existing remotes.
If your key fob worked previously and it just stopped working here are a few key fob fixes to try:
Change the battery
Batteries don't last forever, you'll be surprised how often it's just a dead battery! Search our YouTube channel on how to change a key fob battery for your specific year, make, and model!
Wipe the board
The board inside your remote can get a lot more filthy than you think! When the board is dirty it can prohibit the contact to the circuit board when you push down on the button. Simply wiping the circuit board off can make your key fob like new again!
The old car battery reset trick
I know this sounds absurd, but it works sometimes and is worth trying. If you exhausted all of the options above, disconnect both terminals on your car battery for 10 minutes. Then reconnect them and try your key fob. This has worked for many people and I have no idea why.
t might be time for a new key fob! No need to dread over the expensive costs of a new key fob, at Keyless Entry Remote Fob Inc., you can get a refurbished one for a very affordable price! You won't even be able to tell the difference. Just search your vehicle make, model, and year to purchase a key fob or give us a call at 402-671-5100.
or'
quote
yes, press...press...hold the lock button should work with starting the car. Make sure the remote has fresh batteries and hold the button down for a few seconds as well. When you are doing this, do the signal lights flash when you hold the button down? (They should be) I would still recommend you stop by a local Toyota dealer and ask for help. Guys like me (Toyota salespeople) love to help out with things like this. Just remember, press press hold for a few seconds...dont press too slowly. The two press should be done in less then 2 seconds...then hold for at least 3-4 seconds on the 3rd press...good luck!
Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture).
When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote added to the system.
Press Menu Button from any Remote control ( RC) by which could turn on your TV, press menu , menu drop down list will be visible on ur screen then wait 4 a minute or more till ur RC stop blinking , then go to Preference menu , go to FPA lock, turn it off. enjoy. Deva
Press and hold the Menu button (located above the Channel Up button) and the Off button together for 20 seconds. The remote screen will turn off, then turn on again displaying the image of a remote and a circular arrow. After a few seconds your remote will be restored to factory defaults and you may sync again.
The following troubleshooting steps might get your Harmony Remote working again!!! It is what the Logitech customer care gave me to do and it worked perfectly!!! Hope it works for you too!!!
1) Remove the battery from the Harmony Remote for 10 seconds and reinsert it. If this does not resolve the issue, please continue troubleshooting. 2) Ensure you have the latest version of the Harmony Remote Software (7.7). 3) Update the firmware on the Harmony Remote. The following link shows how to complete this task: http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=10747 4) Try putting the Harmony Remote in safe mode and complete the firmware update again. The following are the steps to accomplish this: a) Remove the battery from the Harmony Remote. b) Press and hold the power button while reinserting the battery into the Harmony Remote. c) To get out of safe mode, remove the battery for 10 seconds and reinsert it into the Harmony Remote.
Use these instuctions if your Deville has an Analog Instrument Cluster 1.Press OFF and WARM buttons onClimate Control Panel (CCP) simultaneously. (Instrument Panel Cluster (IPC) will light all telltales, then go blank) System is now in diagnostic mode. Press PASSENGER COOLER button until “RFA” is displayed, then press FAN UP. If“RFA DATA” is displayed, press FAN DOWN. If“RFA OVERRIDE” is displayed, press FAN UP. 2.If“RFA 500 NO OVERRIDE” is displayed, press FAN DOWN. If“RFA 501 PROGRAM FOB #1” is displayed, Press FAN UP. 3.IPC will show “0” on right side of Driver Information Center (DIC) display. Press warmer button on climate control unit until “99” is displayed. 4.Press and hold TRUNK button on transmitter. While holding TRUNK button, press LOCK button and hold for one second. Hold both buttons for a total of 3 seconds. Locks cycle when programming is complete (if remote is not programmed within 30 seconds after entering “99” override display, system will default and you must begin again at step 2. 5.To program a second remote, press FAN DOWN button until“RFA 502 PROGRAM FOB #2” is displayed, then press FAN UP.Repeat step 4. To exit system, press AUTO, MODE UP, MODE DOWN, or RESET.
Use these instructions if your DeVille has a Digital Instrument Cluster
1.Press OFF and WARM buttons on Climate Control Center (CCC) simultaneously. Instrument Panel Cluster (IPC) will light all telltales, go blank then enter DIAGNOSTICMODE. Press FAN DOW button to scroll through system until “RFA” is displayed, then press FAN UP button. Press FAN DOWN button until “RFA OVERRIDE” is displayed, then press FAN UP button. When“NO OVRD RF 500” is displayed, then press FAN UP button. 2.When “PGM FOBL 501” is displayed, press WARM button and “99” will be displayed in left upper corner of IPC just below odometer. System is now ready to program remote. 3.Press and hold TRUNK button on transmitter. While holding TRUNK button, press LOCK button and hold for one second. Hold both buttons for a total of 3 seconds. Locks cycle when programming is complete (if remote is not programmed within 30 seconds after entering “99” override display, system will default and you must begin again at step 2.) 4.To program second remote, pres FAN UP button until “PGM FOB2 502” is displayed, then follow steps 2 and 3 to program second remote. To exit system, press RECIRC or RESET buttons.
