Question about HP LaserJet 1018 Printer
How to open cartridge
I have refilled so i canot open cartridge
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
Check here how
Posted on Oct 29, 2010
  • Anonymous Oct 29, 2010
    chech here how you can have a succes refilling
    with no need of special tools
My copier canot print the error code is E11 tell me the solution
What is your Canon Printer Model Number?
For information on North American ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP/Epson/Canon printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error bypass & printer reset methods, etc.), please visit Inkjet411: http://www.inkjet411.com
Jul 01, 2013 | Office Equipment & Supplies
Cartridges error on a lexmark
Error: "Invalid Toner Cartridge"; Error: "Invalid Refill"; Message: "Change Cartridge"
Solution
One of these error messages may appear on the printer display immediately after or shortly after a new toner cartridge is installed into the printer. Note: This may not be specifically a toner cartridge problem; the error may be due to a stuck cover open switch on the printer.
To see if the cover open switch is the cause of this problem, open the top front cover and observe the message on the printer's display panel. The display should read Close Door or Insert Cartridge.
If this message is not displayed, the top cover open sensor and switch will need to be replaced. In addition, the printer may have damaged the new toner cartridge. If the cover open sensor is not operating properly, a new cartridge can be incorrectly flagged as a refilled cartridge by the printer. If this happens, the new cartridge will continue to cause an Invalid Refill or Invalid Cartridge error even if you try reinstalling it or installing it into another printer. If this should occur, please contact the point of purchase of the cartridge to find out how to get the cartridge replaced.
Caution: If the cover open sensor is not operating, do not install another new toner cartridge until you have completed the directions below. Inserting another new cartridge can cause that cartridge to stop working as well. Should this situation arise, please take the following actions:
Place the original working cartridge (the empty or near-empty one) back into the printer. This should clear the error message.
Turn the printer off. Doing this will disengage the cover open sensor.
With the printer switched off, open the top lid and remove the old toner cartridge.
Now replace the old cartridge with another new Lexmark toner cartridge.
Power the printer back on. The printer should now read this cartridge as a newly installed toner cartridge and the error should be cleared. The printer and toner cartridge should function properly now, but the top cover sensor on the printer will still need to be replaced.
If your printer is still under warranty or covered under a service contract, please contact Lexmark Technical Support or your service provider for further recommendations and instructions. Until you can get the cover open switch replaced, remember to have the printer powered off whenever you replace the toner cartridge.
If the top cover switch appears to be working fine, or if you have followed the above steps and your printer continues to post an Invalid Toner Cartridge or Invalid Refill error, make sure you are using a new original Lexmark toner cartridge. A toner cartridge remanufactured or refilled by a third party can cause this error.
To help identify a refilled cartridge, look for the yellow label attached to the toner drum and the body of the toner cartridge. If this is damaged or removed, the cartridge may have been refilled.
If you are using a third-party refilled or remanufactured toner cartridge, it is recommended that you install a new Lexmark brand toner cartridge. Lexmark cannot guarantee the compatibility of any third-party toner cartridges with our printers.
OR
1 Switch on the Lexmark X83 printer.
2 Lift open the cartridge door at the front of the device, below the scanner unit. The printer automatically moves the cartridge carrier to the correct position.
3 Pull each ink cartridge toward you to unclasp it from the carrier. Lift the cartridge out of the cartridge carrier.
4 Clean the copper contacts on the bottom of each cartridge with a clean, dry lint-free cloth. Use a gentle, circular motion to clean the contacts.
5 Insert the ink cartridges back into the cartridge carrier. Push back firmly on each cartridge until it snaps into place.
6 Repeat each step in this procedure again. Close the cartridge door.
Oct 04, 2012 | Office Equipment & Supplies
Cannot recognized ink in my canon pixma ip2770
i am having canon pixma ip 2700 inkjet printer. it worked properly till. I got refilled both cartridge and fix it in my printer but the cartridge was not recognized. i had tried installing the cartridge many times and also tried switch off and on it again many times but the printer shows the same error that "An error occurred.Some ink cartridges cannot be recognized." and a message box is opened and it shows that "An ink cartridge is not installed properly.Open the printer's cover, make sure the ink cartridge is installed properly, and close the cover." help me to recover from this problem i can't afford to buy new cartridges. suggest me some ideas and procedures to
Aug 31, 2012 | Canon Office Equipment & Supplies
I don't know how to refill?
Refilling HP color printer ink cartridges saves money and time spent running to the store to find the right ink cartridge, which sometimes is out of stock. By having the refill kits for the HP ink cartridge, you can just refill the cartridge when the ink runs out. The refilling process is easy to do and anyone can do it in a few minutes. The ink kits come with directions and all the colors one will need to refill the ink cartridge.
1.Place a piece of paper towel on a flat surface. Remove the empty ink cartridge from the printer. To do this, open the cover and wait for the ink dispenser to move the ink to the open door. Lift up the tap that holds the ink cartridge in place and pull out the cartridge. Push the tap holder back down and close the cover.
2.Place the ink cartridge on the paper towel. Gather the ink refilling kit together with directions and place the ink jars on the paper towel along with the syringe needle.
3.Find the indents on the top of the empty ink cartridge. Poke these holes open with the pen. Sit the cartridge down and open the ink containers. The colors are yellow, cyan and magenta.
4.Read the directions to see where each color goes in the ink cartridge. Insert the syringe needle into the ink container and raise the stopper up until you have the recommended amount of ink to fill into the particular hole.
5.Insert the needle into the hole on the ink cartridge and slowly dispense it into the cartridge. Remember to go slow with this step. If you see the ink oozing out, stop filling and wipe with a paper towel.
6.Cover the holes with the tabs that come in the refill kit or you can use tape. Make sure the hole is sealed to prevent spilling or the ink drying up. Then replace the ink cartridge back into the holder in the printer.
I hope you find it very helpful. Thank you for using fixya.
Aug 22, 2011 | HP PSC 1315 All-In-One InkJet Printer
My cyan colour is finished, i have to print a black colour documents, printer is not allowing to print, please help
switch to black and white on the printer settings.make sure ignore colour warnings are turned off
if that doesnt work youll need to replace the cyan,get it refilled for less or order online to reduce cost
Mar 07, 2011 | Epson Office Equipment & Supplies
The colored ink cartridge was refilled once and it worked well, now I'm refilling it the second time and it seems to not be responding anymore, assistance please, if there is any.
It is not recommended to use the refilled ink cartridges...But anyhow you can use the refilled cartridge once or twice if it is refilled properly...
When refilling the cartridge, the cartridge will be opened for refilling the INK...In this phase the Circuit in the cartridge may be damaged due to improper handling...
In this situation the cartridge has to be changed, No other go...!
Feb 24, 2011 | Lexmark Z640 InkJet Printer
Does ink refile is possible in canon ip 2770 printer?
Yes, Canon ink cartridges can be refilled. Most Canon cartridges can be refilled up to 12 times. Canon cartridges consist of a sponge and an open ink reservoir, so they can be refilled using a syringe.
Nov 14, 2010 | Office Equipment & Supplies
Canot read after refill
You need to shop online for either a chip resetter or replacement chips. You can't refill Canon inks without a new chip because the chip tells the printer that the ink is empty even when you add more ink.
Jan 19, 2010 | Canon PIXMA iP1600 Printer
My yellow catridge still canot resetter after i replace & change
Hello sir; First thing have to do is make sure you put the cartridge in right way, after you installed the cartridge you have to press resume key.
Apr 17, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Help me replace the ink cartridge on my photosmart copier/printer
Step 1: Turn printer on -- open front door.
Step 2: Tilt cartridge down in front and remove cartridge.
Step 4: Refill cartridge with ink per instructions on refill kit.
Step 5: Reinstall cartridge by reverse of step 2, then 1.
Works for me -- I refill 6 or more times before replacing the
cartridge.
HP 1401 PSC
Aug 29, 2008 | HP Office Equipment & Supplies
Ben Johnson
