Question about Microsoft Windows XP Home Edition
How to write jdbc connections
How we have to write jdbc connections
  • 323 Answers
Http://www.jdbc-tutorial.com/
window.google_render_ad();
how to write jdbc connections - welcome_title_image.gif Java JDBC Tutorial Java JDBC Tutorial
The JDBC ( Java Database Connectivity) API defines interfaces and classes for writing database applications in Java by making database connections. Using JDBC you can send SQL, PL/SQL statements to almost any relational database. JDBC is a Java API for executing SQL statements and supports basic SQL functionality. It provides RDBMS access by allowing you to embed SQL inside Java code. Because Java can run on a thin client, applets embedded in Web pages can contain downloadable JDBC code to enable remote database access. You will learn how to create a table, insert values into it, query the table, retrieve results, and update the table with the help of a JDBC Program example.
Although JDBC was designed specifically to provide a Java interface to relational databases, you may find that you need to write Java code to access non-relational databases as well.
JDBC Architecture jdbc.jpg Java application calls the JDBC library. JDBC loads a driver which talks to the database. We can change database engines without changing database code.
JDBC Basics - Java Database Connectivity Steps Before you can create a java jdbc connection to the database, you must first import the
java.sql package.
import java.sql.*; The star ( * ) indicates that all of the classes in the package java.sql are to be imported.
1. Loading a database driver,
In this step of the jdbc connection process, we load the driver class by calling Class.forName() with the Driver class name as an argument. Once loaded, the Driver class creates an instance of itself. A client can connect to Database Server through JDBC Driver. Since most of the Database servers support ODBC driver therefore JDBC-ODBC Bridge driver is commonly used.
The return type of the Class.forName (String ClassName) method is “Class”. Class is a class in
java.lang package.
try { Class.forName(”sun.jdbc.odbc.JdbcOdbcDriver”); //Or any other driver } catch(Exception x){ System.out.println( “Unable to load the driver class!” ); } 2. Creating a oracle jdbc Connection
The JDBC DriverManager class defines objects which can connect Java applications to a JDBC driver. DriverManager is considered the backbone of JDBC architecture. DriverManager class manages the JDBC drivers that are installed on the system. Its getConnection() method is used to establish a connection to a database. It uses a username, password, and a jdbc url to establish a connection to the database and returns a connection object. A jdbc Connection represents a session/connection with a specific database. Within the context of a Connection, SQL, PL/SQL statements are executed and results are returned. An application can have one or more connections with a single database, or it can have many connections with different databases. A Connection object provides metadata i.e. information about the database, tables, and fields. It also contains methods to deal with transactions.
JDBC URL Syntax:: jdbc: <subprotocol>: <subname> JDBC URL Example:: jdbc: <subprotocol>: <subname>•Each driver
Posted on Feb 08, 2009
How to make a connection with sybase using jtds driver
hi,
the first thing you need is the correct JDBC driver, that must be included with your database.
Then you need to create a connection using the driver.
This link could help.
http://www.redmountainsw.com/wordpress/archives/jdbc-connection-urls
regards
Mar 13, 2009 | Sybase SQL Anywhere Studio for Workgroups...
How to connect from jsp login page to database
hey try this code......just found it on the net... Put the code in tomcat and test the application through browser. The browser should display the display the data stored in the table.
Here is the code of our JSP file
<%@ page language="java" import="java.sql.*"%>
<html>
<head><title>Read from mySQL Database</title>
</head>
<body>
<p align="center"><b>Following records are selected from the 'jakartaproject' table.</b><br>&nbsp;</p>
<div align="center" width="85%">
<center>
<table border="1" borderColor="#ffe9bf" cellPadding="0" cellSpacing="0" width="658" height="63">
<tbody>
<td bgColor="#008080" width="47" align="center" height="19"><font color="#ffffff"><b>Sr.
No.</b></font></td>
<td bgColor="#008080" width="107" height="19"><font color="#ffffff"><b>Project</b></font></td>
<td bgColor="#008080" width="224" height="19"><font color="#ffffff"><b>Url
Address</b></font></td>
<td bgColor="#008080" width="270" height="19"><font color="#ffffff"><b>Description
of the project</b></font></td>
String DRIVER = "org.gjt.mm.mysql.Driver";
Class.forName(DRIVER).newInstance();
Connection con=null;
ResultSet rst=null;
Statement stmt=null;
try{
String url="jdbc:mysql://192.168.10.2/tutorial?user=tutorial&password=tutorial";
int i=1;
con=DriverManager.getConnection(url);
stmt=con.createStatement();
rst=stmt.executeQuery("select * from jakartaproject ");
while(rst.next()){
if (i==(i/2)*2){
<tr>
<td bgColor="#ffff98" vAlign="top" width="47" align="center" height="19"><%=i%>.</td>
<td bgColor="#ffff98" vAlign="top" width="107" height="19"><%=rst.getString(2)%></td>
<td bgColor="#ffff98" vAlign="top" width="224" height="19"><a href="<%=rst.getString(3)%>"><%=rst.getString(3)%></a>&nbsp;</td>
<td bgColor="#ffff98" vAlign="top" width="270" height="19"><%=rst.getString(4)%></td>
</tr>
}else{
<tr>
<td bgColor="#ffcc68" vAlign="top" width="47" align="center" height="19"><%=i%>.</td>
<td bgColor="#ffcc68" vAlign="top" width="107" height="19"><%=rst.getString(2)%></td>
<td bgColor="#ffcc68" vAlign="top" width="224" height="19"><a href="<%=rst.getString(3)%>"><%=rst.getString(3)%></a>&nbsp;</td>
<td bgColor="#ffcc68" vAlign="top" width="270" height="19"><%=rst.getString(4)%></td>
</tr>
i++;
rst.close();
stmt.close();
con.close();
}catch(Exception e){
System.out.println(e.getMessage());
</tbody>
</table>
</center>
</div>
</body>
</html>
Feb 27, 2009 | Compaq Computers & Internet
What is use of Jdbc or odbc driver?
Go through these links to get an overview of JDBC and ODBC:
http://en.wikipedia.org/wiki/Java_Database_Connectivity
http://en.wikipedia.org/wiki/Open_Database_Connectivity
Jan 17, 2009 | Computers & Internet
I can't connect the ms-sql 2005 database with flex
hi this is jesica am expert to help you to fix this issue for you,kindly call me on +1(518)348-9393 and we will be glad to help you.
Sep 24, 2017 | Microsoft SQL Server 2000 Standard Edition...
I can't connect the ms-sql database with flex
It sounds like you don't have the proper authentication to access the SQL server from the error code you are receiving. I would ask you SQL DBA to check on the permissions within SQL and verify that you have the proper access rights to the database you are connecting too. It is SQL throwing that exception error...
Cheers!
J the Guru
Jun 27, 2017 | Microsoft SQL Server 2000 Standard Edition...
Hibernate configuration with windows authentication
When you login to your database (download the management tool) right click on server name->properties->security.
There you can choose mixed authentication.
Sep 05, 2008 | Computers & Internet
Oracle SQL Error
Does it connect after the error ?. First try to connect from your client to Oracle server using SQL plus client.
Second - Do a tnsping <server name>
This will give you the correct Host name, SID and Port number.
Make sure that your JDBC connection parameters match with the actual connection from TNS output
Sep 04, 2008 | Oracle 10g Database Standard (ODBSEONUPP0)
JDBC
steps to retrieve results.
create the driver.
Class.forName(" ");
create a connection.
Connection con_name=DriverManager.getConnection("Dbname","coloumn name");
create statement
Statement stmt_name=con_name.createStatement();
To retrieve resule fron DB use the below codes
ResuleSet rs;
rs=stmt_name.executeQuery("select * from DB name");
Mar 01, 2008 | Computers & Internet
MyEclipse6.0.1 connection with sqlserver 2000
hi
Try with MS SqlServer 2005 JDBC Driver,
i had a similar problem with 2000 jdbc driver
Dec 03, 2007 | Microsoft SQL Server Standard Edition for...
Microsoft Windows XP Home Edition Logo
373 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
