Question about Whirlpool LSR5102LQ Top Load Washer
Want to remove bowl from wirlpool washer
Have a wirlpool washer 8225E and having trouble removing bowl. A bra wire is stuck between plastic outer casing and drum which makes spin cycle noisy.The main holding nut has been removed however the drum will not budge. A washing machine mechanic advised me that the holding nut was definitely a left hand thread and to remove it in a clockwise direction. After much stress with a screwdriver and hammer I had to hacksaw off the holding nut only to fing that it was a right hand thread?????
I now suspect that the bowl is forced down onto the shaft and it just wont budge. Any solutions?
  • info205 Feb 01, 2009
    Brigadier General:
  • 5,158 Answers
Scary that they wouldn't know the proper direction of the thread... but that bowl most likely spins off in the opposite direction it normally turns... you'll have to work out which direction that is.
Robert
Posted on Feb 01, 2009
    Guru:
  • 859 Answers
Yes. Brute strength, a fulcrum and a really good vise grip wrench to take hold of the bra wire.
Should that have proved unfruitful already, then I'd cut the wire as far into to the tub as possible with the hope that it will fall out harmlessly; which I doubt due to the seal. Leak proofing techniques used in holding the tub to the drive shaft will probably lock the whole mess into place as it is now. [Just thinking out loud here.].
You may want to consider putting the washing machine on its back and work from the bottom. In cases where you do have to use a lot of torque to release a hold down bolt there is often a hole you can pass a Phillips head screw driver through to lock the tub and drive shaft in place compared to working on the nut. Give it a hard look to see if you can find that.
Also, a decent inspection mirror on a telescopic handle can give you some advantage but I bet you're using one already. You may find the locking pass through hole on the bottom of the machine where its between the transmission and tub.
I suspect that in the long run, in addition to this, you will find the water proof seal on the tub at the drive shaft is damaged and will leak so perhaps a visit to your local (or not) appliance parts store will yield you some good advice, they often have it I've found. You will probably want to replace parts as you resolve this and put it together again.
I'm 58 and was a helicopter systems mechanic in my youth and over the years have fixed more than my share of washer/dryers, dishwashers/microwaves, etc. etc. There is something to be said for we mechanically inclined Mr. Fix Its and experience. I normally don't work on washing machines, here, and leave it to the others who have worked in this field all their lives. I'm am surprised you haven't had a respnse from one of them yet.
Stick with this problem and don't give up. It may be that a day or two spent off the project will yield you an ephiphany. Give it a try and find something else to do as you're probably using a laundromat by now.
Best regards and luck in this, no kidding.
  • Glenn Rogers
    Glenn Rogers Feb 01, 2009
    You are also going to need to replace the drive shaft since you cut it with a hack saw. This makes the visit to the applicance parts store even more important. They're in the yellow pages and will sell to owner/operators and are willing to give all the advice you may need to do it right on the first attempt, so don't be shy with these poeple; they are really helpful and a treasure trove of knowledge.
  • 679 Answers
There are a plastic lock between them, so you also need to remove the locks.
  • rockfixya
    rockfixya Feb 01, 2009
    here is some pictures,,How To Open The Cabinet>>
    http://www.acmehowto.com/howto/appliance...
How do you access between the drum and plastic outer casing? Trying to remove a bre wire from within.
remove the four screws that hold the whole top on two might be under plastic caps then you can see the ring which covers both bowls which is either clipped or screwed into place remove thatand you can then see
Dec 01, 2017 | LG Washing Machines
Maytag Nuptune washer in spin cycle sounds like a plane taking off
Something small, like a paperclip or the wire from an underwire bra can get stuck in the holes in the drum, and rub against the outer drum. You will have to check carefully to find it.
Mar 16, 2012 | Maytag Neptune MAH5500B Front Load Washer
Hi my machine is making a crunching noise what could it be?
It could be a foreign object stuck between the drums. Have a very close look around the spin bowl for signs of a bra wire or similar sticking through one of the holes in the tub. There may be a coin or something else stuck where you cant see it and it will require removal of the spin bowl ( A very big job) If the machine is older ( 6 to 10 years old) the bearings may have failed. Grab the spin bowl through the door opening and see if the drum moves up and down. If it does, its a sign that the bearings have failed and /or the main shaft has broken or worn out... Another big job. It may be cheaper to replace the machine if either of these faults have occurred.
Jul 31, 2011 | Electrolux EW1000i Front Load Washer
I have got a Hotpoint Aquarius + WF740 1400 spin speed. When the drum is moving slow inbetween cycles there is a wereing noise, In the wash cycle it clunks but it's ok in spin mode. When I move the drum...
there could be something stuck between the inner and outer drum, eg. a bra wire a common culprit.
inside the drum you have 3 lifters ( blue pillars). remove one of these by pulling it towards you.this will allow you to see into the inner drum. get a flash lamp and have a good look rotating the inner drum around.
if you see anything get a pair of pliers to pull in out as you cant get a nasty cut.
replace lifter as u removed it.
if bearings were gone would sound like a tractor while spinning.
Mar 18, 2011 | Hotpoint Aquarius WF000 Front Load Washer
My washer makes alot of noise during the spin cycle almost like the sound of a jet engine.
Check the drum holes carefully, this often happens when something like a bra under wire gets caught in a hole and rubs on the outer drum
Feb 03, 2011 | Maytag MAH8700A Front Load Washer
How do I remove a piece of metal from bra which has got stuck under the insiden cylinder and drum
it completely has to be pulled apart and once you have done that you will probably find the bra wire while spinning around has ripped into the plastic outer tank so bad it will now leak and have to be replaced & this is the most expensive job to have done it sounds silly for a bra wire but you should honestly consider buying a new machine it often ends up cheaper to do so rather than spending 3/4's of the price of a new one fixing your one.
Jan 12, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
Loud squealing sound during spin cycle
Possibly a foreign article stuck inside the drum. When the machine goes onto spin this can rub against the outer drum causing such a sound.
This is commonly the underwire from a bra that has worked loose and lodged in one of the holes inside the inner drum. Have a careful feel round the whole inner surface of the drum to see if you can detect anything protruding. If you find a wire, grip it with a good pair of pliers and try to pull it out, remembering the shape that it probably has so it will need to be coaxed out accordingly. Anything protruding through the holes doesn't belong there!
I have removed three of these from our washing machine!
Mar 09, 2010 | Maytag MAV7700 Top Load Washer
Bra wire's trapped between inner and outer drum,
If you cant pull wire out from inner drum with long nose pliers, Remove heating element and use torch to inspect bottom of washer. Most of the time the obstruction makes its way to the bottom. Use whatever tool necessary to remove spring.
Sep 25, 2009 | Hoover AAA160 Front Load Washer
How do you remove underwire lodged between drum and outer case
hi to remove bra wire from between drums ? you might try this 1st ? if you diconnect water supply hoses and unplug power supply then remove rear panel from machine you will have access to the large rubber drain hose from outer drum down to discharge pump ? ok hose is held by spring wire clips both ends remove clips then hose you may find bra wire either in hose or close to drum drain if you need ? feel inside drom via drain hole ? or probe with a piece of coat hang wire ? you may even find the mysterious missing sock/ thong / etc when you disconnect the hose too?? any debri has to lay in bottom of outer drum and so a little patience will locate them using this method instead of removing the main front door sealto drum for access to same area also with rear panel off you can check belt tension ? hope this helps/inspires you ? best wishes from uk
Feb 26, 2009 | Hotpoint First Edition FEW12 Front Load...
Bra wire stuck
you may not have to take the washer apart, take a good ligtht and look around inside the spin tub, if a part of the underwire is sticking thru, try and pull it out. Do not use the washer until the wire is removed or it actually could cut the tub and then the machine will leak $$$
Let me know the make and model if you need more assistance
T
May 22, 2008 | Washing Machines
Whirlpool LSR5102LQ Top Load Washer Logo
74 people viewed this question
Dan Webster
Dan Webster
Sal De
