Question about Ovens
LCD panel shows small key. Oven won't turn on.
I have a westinghouse wall oven, approx 4 years old. The oven won't turn on and there is a small key showing on the LCD screen.
  • 2 more comments
  • plumbie33 Feb 01, 2009
    There is no error code and perhaps the "lock key" just locks the controls. The door still opens and I have no operators manual to tell me how to unlock it.
  • plumbie33 Feb 04, 2009
    Tried re-setting circuit breakers but no luck, Key symbol still in place and oven won't turn on.
  • plumbie33 Feb 14, 2009
    Thank you for the tip to reset the circuit breaker. It worked. Oven is now functional.
  • Maintunivers May 11, 2010
    I believe the key means "door is locked" or if you have an error code; what does it read? Also, have you tried re-setting the circuit breakers to the oven (somewhat forcefully)?
    Scholar:
  • 42 Answers
Great! Did I "Fix Ya?"
www.maintenanceuniverse.com
Posted on Feb 15, 2009
Westinghouse oven model WFE946SA, purchased only 4 mnths ago. No lights display
main control board,take it back,its expensive,1 year warranty
Jul 26, 2015 | Ovens
WHIRLPOOL double wall oven has a blank control screen the start button is the only button that beeps
Their is a small in line fuse going to the oven control. Service manual
6b484ffa-e6f8-4c65-aa67-df87a903038a.pngPage 4-2 shows how to get to it. Radio shack has the fuses
Nov 24, 2013 | Ovens
MY Jenn Air model WW2780W isn't coming on. When I click on the control panel it clicks then the display says 140 preheat on.. for about 30 seconds then it shuts off it has done it for awhile and it would...
I have the same double wall oven, and it will "turn on" and then shut off after about 30 seconds. The top oven stopped working 4 years, the bottom oven stopped working about 2 years ago. Both are doing the same thing. I'm interested in replacing the capacitors to see if that fixes the issue. There are 2 larger capacitors (1000uf 35v), and lots of smaller ones. Is it safe to assume it's the larger ones that need to be replaced? The only other 2 matching capacitors are very small (0.47uf 5v). I know this is an old thread but would appreciate any advice. Thanks!
Sep 27, 2013 | Jenn-Air Ovens
Double oven no model number Whirlpool 14 years old Door is locked after self clean and display is blank
Your oven has resetable high limit thermostat that tripped off on the self clean cycle,im not sure if you have free standing,or a wall oven if freestanding the t-stat is on back panel if wall oven its behind control panel on upper oven and for lower oven its behind the grill between bottom of upper oven and top of lower oven. In either case it has a small red button that can be pushed in to reset it
Hope this helps and if it does please give me 4 thumbs up
Gene
Jul 28, 2011 | Whirlpool Ovens
I set the oven at 350 degrees and after 3 hours it has only reached 185 and won't go any higher. The oven is approx. 8 years old.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jul 25, 2011 | Ovens
I have a westinghouse fan forced 600 wall oven and I need the serial or model number to get a new door for it, Thanks
There is usually a small sticker on the oven inside the door at the bottom edge of the oven. This usually has the information you require on it. If this is not the case then if you have the handbook for the appliance you can get it from there.
Failing this take a digital photograph of it and this will often be enough for a parts supplier to identify the item.
You don't say how old the oven is but a new door will be quite expensive, check out the cost first relative to .the cost of a replacement oven.
Dec 11, 2010 | Ovens
I have a 31-year old Caloric gas wall oven (Model RWD216) that finally died. I am ready to install a new unit, which means taking out the old Caloric. My question is, how do I unhook the gas line from...
first turn the gas off at the meter/ a oven this old may not have a shut off in the back. then you can remove the oven safely/ the line in back will hook to 1/2in or 3/4 pipe stub. . if you have a shut off in the back turn it off and reconnect new range to it . and if not make shure you put one in .. mm
Nov 22, 2009 | Ovens
Wall oven not working at all
mine is broken too. exact same problem. same oven. email me if you fixed yours, please!!! quinnalisen@comcast.net
Sep 25, 2009 | Kenmore Ovens
How to install built in oven
when they say 24'' or 27'' wall oven are they saying rough wall opening size or the front is 24'' 27'' across the front
Sep 08, 2008 | Frigidaire FEB27S5A Electric Single Oven
GE Profile 2002 Wall oven JCKP18BA2BB Code faults
Try my solution for the F7 problem at the following link:
http://www.applianceblog.com/manuals/Dreaded_F7_Problem.pdf
I have shared this with over 1500 folks and most report success.
Please let me know. Also, what is your model number, how old is your oven and where are you located? I am making a study of this problem. You can email me at: hutchipop@yahoo.com
Jan 08, 2008 | Ovens
Ovens Logo
113 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
