Question about Compaq Armada M700 Notebook
Slow Internet Connect
I have a DLink DIR-300 wireless router, problem is that when my desktop is connected to one of its lan ports internet connection became too slow while my wireless devices (eg, dell inspiron 8500, 2 psp units, 1 wirelss desktop) has no problem and connects instantly, if i directly connect said wired desktop to the modem it connects instantly, can someone help me with is problem, same problem happens with my other Linksys BEFW11S4 v2 wirelss router, i am using a broadband isp.
  • Joey Serrano Feb 01, 2009
    i just installed a fresh win xp pro on said desktop and i have not yet installed anything on it yet im just trying to connect it to the router, it has the built in lan and its a dell Inspiron 530s desktop, tnx for the help
  • 36 Answers
I have the same router. I recommend that you download a new driver of your lan card for your desktop pc, also if you have P2P and bittorrent applications, try to disable them first and see the difference, those programs slow down the your internet, because they hog your bandwidth and connects to multiple users.
Posted on Feb 01, 2009
  • spyzampinoy Feb 02, 2009
    have you tried the new Lan drivers?, are you using XP Service pack2 or 3? try doing a ping test, for example if your router IP is
    "192.168.1.1"  click start then run, then type "ping 192.168.1.1 -t"
    you should see continous reply from your router. it it displays any timeout. you might have a bad router, or a bad Network Cable.
My Dir 615 router always looses internet connection to my wired computer
Try to upgrade the routers firmware.
http://www.dlink.com/us/en/support/product/dir-615-wireless-n-300-router
Jul 19, 2013 | D-Link Computers & Internet
Reset my dlink dir 615 router and now internet light stays flashing orange
Do you have the Internet connected to the Internet port in the back of the DLINK? You will have to configure the DLINK for internet access. Open a web browser to your DLINK and check on the configuration under internet-setup. Select the type of internet connection you have i.e. DHCP, PPPoE, Static, etc. Once that is set up, you should have access to the internet like before.
Feb 13, 2013 | D-Link DIR-615 Wireless Router
How do I connect a Dlink wireless router to a Netgear WiFi Internet adaptor?
Hi there is two way to connect best is to connect via cable ,DIR 615 login to router setting by typing 192.168.0.1 enter user name and password uaser name will be admin and password could be admin or blank or you need to enter text " read the manual to access the router via internet explorer" make sure WAN connection is DHCP connect LAN cable from your main router to the WAN port of your Dlink it should be ready in 1 miutes also if it support WDS you do not cable it can find the main router signal and connect to it and boost it , should you need any help please post me your question to http://computernetworksupportindubai.com/
Jul 22, 2011 | D-Link DIR-615 Wireless Router
I have a DIR-600 router to connect my Cable modem and use wireless connection to connect to the internet. It was all working fine till my modem LAN port got damaged somehow.I have changed the modem and now...
Try following this order before you connect your computer to the router.
power off all your equipment (cable modem & router & your computer's wireless card)
first, power on the cable modem, give it some time to boot up and get an IP from the ISP, say 30 secs.
then, power on the router, again, give it some time to boot and obtain its internet IP from the cable modem
finally, enable wireless on you computer and connect to the router.
if this doesn't solve the problem try resetting the router to factory defaults by pressing the reset button at its back for about 10 seconds with the router powered on.
This your router's manual it may turn handy:
http://global.dlink.com.sg/site_support/DIR-600/Manual/DIR-600_B1_Manual_v2.pdf
good luck
Jun 12, 2011 | D-Link DIR-600 Router
My cable internet provider has provided me with an Ethernet cable which connects directly to my PC. My PC's MAC address is registered with the ISP. I use a PPPoE connection to access the internet with a...
put another lan card in pc
share your connection using ICS from network properties from first one
put a straight cable from pc to router
give the gateway of router to laptop
remember!! the class of ip's should be the same
you are done
Feb 04, 2011 | D-Link DIR-600 Router
Router page not available offline
You don't connect to WAN port, you need to connect it to one of the switch ports. The wan is strictly for modem configuration
Dec 17, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Wifi problem of DIR-300 dlink
just open the dlink ip homepage and configure the wireless settings
sagar
Jan 27, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
VPN problem with Dlink DIR-300
Update your firmware to the latest. I had the same issue and the issue is gone after the upgrade.
Dec 31, 2008 | D-Link / RangeBooster N 650 / DIR-635 /...
Dlink dir 300 internet problem
First you have to make sure that you connected it correctly. the cable coming out of the modem should be connected to the single port (Internet port) at the right when facing the back of the router.
All computers that are wired through it should be able to access the internet. if one of your computers cannot access the internet you may want to check the IP address that you are getting. (go to a command prompt and type ipconfig).
If you are connecting a wireless computer check the wireless security setting which you can find at the configuration (setup) page of the router. to access the configuration page check the owner's manual.
Oct 08, 2008 | D-Link / RangeBooster N 650 / DIR-635 /...
Compaq Armada M700 Notebook Logo
234 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
